Old 06-01-2014, 03:56 PM   #51
Andy4639
Old member
Andy4639's Avatar
Wink Re: '72 Suburban - 2005 L59 5.3/4L60 swap
2.5" exhaust is plenty for the LS motors unless you have a lot of HP. Nice build by the way.
May I make a suggestion on your cold air intake.
90's model caddy air box. Seal up the factory opening and drill a 4" hole in the bottom of it. Buy one 4" ninty and 2 coupling from Lowes. Drill a 4" hole through the core support and bottom of air box then install the coupling from the front of the truck then the ninty and the other coupling through the hole in the box.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 06-13-2014, 07:57 PM   #52
72c10suburban
72c10suburban's Avatar
No real progress, i messed around and bought a daily driver yota and of course lift, tires and now a camper shell has sort of delayed progress. slowly getting back to it though. The engine and tranny is in but thats about as far as ive made it.
Andy - I like the airbox idea. May have to hit up the pull-a-part once i get it fired off.
72c10suburban is offline   Reply With Quote
Old 10-14-2014, 11:46 PM   #53
72c10suburban
Some progress. Got the alternator rebuilt and the belt drive on. I ordered a few odd and ends for the front clip and hope to have it reinstalled this weekend.
Old 12-20-2014, 10:31 AM   #54
tinsoldier
tinsoldier's Avatar
Any update? I am about to yank mine out to do a swap.
tinsoldier is offline   Reply With Quote
Old 12-23-2014, 12:02 AM   #55
72c10suburban
Yes and no on the progress. The complete engine and tranny is in as well as the cooling system. I still need to finish up the wiring and do the fuel systems then the drive shaft, exhaust and the tune. Its stalled out while i get through Christmas, then game on again first of the year. It at least looks like a complete Suburban now.
Old 01-29-2015, 12:43 AM   #56
72c10suburban
Finally getting started back. I finished modifying the harness and started installing it today.
Old 02-04-2015, 12:51 AM   #57
SierraMtns
SierraMtns's Avatar
Nice build. Thanks for posting up this picture. I was wondering if it was possible to not run AC. Did you just have to get a shorter belt?
SierraMtns is offline   Reply With Quote
Old 02-04-2015, 06:07 AM   #58
72c10suburban
The A/C runs off of its own belt on the truck motors. All I did was remove the compressor and bracket for it.
Old 02-05-2015, 10:50 PM   #59
hubba033
hubba033's Avatar
Any tips on how to remove those 2 stubborn plugs on the transmission?
72 C10 swb LS 5.3 LSA Blower/4l60 performabuilt
01 Pontiac Trans Am WS6
hubba033 is offline   Reply With Quote
Old 02-06-2015, 12:03 AM   #60
72c10suburban
Basically they're glued in. I've heard a heat gun will soften it up. I got lucky and mine came out without too much trouble.
Old 04-14-2015, 08:37 AM   #61
enduroride
enduroride's Avatar
What cam did you install in the 5.3 (part number, lift/duration) ? We are doing the same swap in a 72 LWB C10. Waiting on suspension parts to come in from Porterbuilt, figured I could do some motor work while we wait !
Thanks !
2016 Silverado2005 GMC Sierra
2002 Chevy Slverado Extra Cab (youngest sons)
2009 GMC Denali (oldest sons)
2015 Lexus 250i (wifes)
1972 Chevy C10 LWB, 5.3 / 4L60e swap "COLOR OF MONEY"
http://www.louisianaclassictruckclub.com
enduroride is offline   Reply With Quote
Old 02-25-2016, 12:05 AM   #62
72c10suburban
Wow. Been a while since Ive been on here. Finally getting back to work on the Suburban after almost a year with little to no progress. Ive ordered the fuel pump, and will be ordering a new tank and sending unit from LMC and will be using Dorman nylon fuel lines. Ive managed to get all the cooling in and plumbed up as well as the inner fenders. Thats been it for the last year as the remaining project fund ended up buying kayaks and a gun or two. Im back on it now.
Old 02-25-2016, 06:17 PM   #63
Average Joe
Average Joe's Avatar
Good 4 you!
1967 C10 Suburban 454/TH400/3.07's
An Average Joe and His 'Burb:
http://67-72chevytrucks.com/vboard/s...d.php?t=775843
Average Joe is offline   Reply With Quote
Old 04-25-2019, 07:35 PM   #64
72c10suburban
Been a while, and progress has been slow, but this project still LIVES!
It now runs, and moves under its own power. Well, from 1 carport to the other. Ill post some updates next week when I actually get some time off.
Old 04-27-2019, 08:32 PM   #65
Average Joe
Happy to hear this!
Old 01-02-2021, 12:00 PM   #66
kev2809
low n' slo
kev2809's Avatar
any updates?
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
