Old 01-29-2015, 01:11 AM   #1
rs74
rs74's Avatar
How hard to take the side trim off
I want to start taking the trim off as some of it is already off and the other is in bad shape. What has already been taken off left behind like a white foam tape backing. Will a rubber wheel take that off or do I need to try to get that off before using the wheel. Is there any certain process I should use to take the trim off and get all the adhesive off so I can order new trim. Will the wheel hurt the paint any? That way if I don't get around to putting it on for a while then at least it will look presentable.
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 01-29-2015, 03:39 AM   #2
andrewmp6
Re: How hard to take the side trim off
What i have used is a heat gun and a plastic bondo spreader to remove most stuck on trim.Just go slow and easy and you won't pull off any paint.And yes the rubber wheel will take off the tape and left over glue.
Old 01-29-2015, 01:11 PM   #3
Bigstevex4
Bigstevex4's Avatar
i just pride it of with a trim tool.But not to concernad about paint then used the eraser in a dril and a little minerial spirts on rag never tell was there .Mine was missing sections also.
Bigstevex4 is offline   Reply With Quote
Old 01-29-2015, 01:41 PM   #4
Shifty One
Shifty One's Avatar
I used fishing string, and the 3/M eraser with good results.
Old 02-21-2015, 07:15 PM   #5
solidaxel
solidaxel's Avatar
IS all aftermarket trim from the same manufacturer.
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 02-21-2015, 09:00 PM   #6
Super_Dave
Super_Dave's Avatar
To remove the tape residue, my wife's fingernail polish remover always works in a pinch, when acetone is not around. I second the fishing line to cut the tape loose from the trim/bed.
--Project BABA YAGA!... http://67-72chevytrucks.com/vboard/s...d.php?t=655783
--Project BABA YAGA!... http://67-72chevytrucks.com/vboard/s...ghlight=Belair
"Life is tough - wear a cup!"
"Old Enough to Know Better - Too Young to Resist"
"Junk is something you will need three weeks after you throw it away."
Super_Dave is offline   Reply With Quote
