Old 01-29-2015, 03:22 PM   #1
michael bustamante
michael bustamante's Avatar
tach wiring
SO i just purchased a factory tach cluster from a 67 for my 67
but i need the wiring harness. I bet i could make one but i thought id hit you guys up first to see if any of you have made any and want to share your knowledge.
with out a search feature i cant search and im sure someone has asked how to make a tach harness before.
also is there a difference in the 67 tach and all the other years?
1967custom
michael bustamante is offline   Reply With Quote
Old 01-29-2015, 07:48 PM   #2
FirstOwner69
FirstOwner69's Avatar
Re: tach wiring
I bought mine on eBay about 3 years ago from Roger Koop. He is now a board member as RogerKoop. You might want to PM him to see if he still sells them. Otherwise, Classic Industries sells them.
Their numbers:
67 w/o HEI- CT20645
67 HEI- CT39694
68-72 w/o HEI- CT20635
68-72 HEI- CT39695
Not sure what the difference is with the 67s, but I think the early years routed the wire through the grommet with the washer hoses or oil line and the later years used a dedicated hole near the fuse block with a grommet molded onto the harness.
FirstOwner69 is online now   Reply With Quote
Old 01-29-2015, 09:29 PM   #3
Wizo
Wizo's Avatar
Re: tach wiring
TBONE 1964 might be able hook you up. shoot him a PM.
1970 3/4 ton long box GMC
!968 C10 short stepside (Papa's Old Lorry)
2006 2500 HD Silverado Duramax/Alison
Wizo is offline   Reply With Quote
Old 01-29-2015, 09:51 PM   #4
hooverfish
hooverfish's Avatar
Re: tach wiring
when did the search option disappear?
Much of this site is useless without that.
Larry
84 Chevy SWB, "Roy", dark blue OG paint, 5.7 LS1, 4L60, Vintage Air, 96k miles.
"It's a sorry man who can't find his wife a good job"
hooverfish is offline   Reply With Quote
Old 01-29-2015, 11:46 PM   #5
SS Tim
SS Tim's Avatar
Re: tach wiring
The google site search works fine for most things.
http://www.google.com/custom?domains...D%3A1%3B&hl=en
SS Tim is offline   Reply With Quote
Old 01-30-2015, 12:16 AM   #6
swamp rat
swamp rat's Avatar
Re: tach wiring
Yes, i found that adding "67-72 chevytrucks" to my searches on Google is actually more powerful than the site search function, it pulls up related threads.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 01-30-2015, 12:29 AM   #7
davischevy
davischevy's Avatar
Re: tach wiring
I bought one from; TBONE1964
http://67-72chevytrucks.com/vboard/member.php?u=119465
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
Old 01-30-2015, 02:32 AM   #8
TBONE1964
Cluster King
TBONE1964's Avatar
Re: tach wiring
Yes, I have not been able to go to the location to search my listed threads for some reason as well. it says something like "search disabled". I have just recently noticed this. i like to go to that page to up date all of my threads because it is an easy way to find them.
With that said, the 67 is a 67 only tach harness. I can build one if I had a sample to follow. I think the key difference is the way it routes. It does not follow the harness under the dash and come out of the firewall to the drivers side of the junction block like the 68-72 tach harnesses do.
If there was enough interest in a 67 only tach harness, I would buy one to model from and make them like I make my 68-72's.
Hope this helps,
Take care,
Tom
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com
I am also a dealer for Counterpart for gauge cluster parts only.
Also see my facebook page, CG&C
TBONE1964 is offline   Reply With Quote
Old 01-30-2015, 08:34 AM   #9
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: tach wiring
Hope this helps,
Take care,
Tom
Tom you can find your threads by typing " TBone1964 " without the quotes in
the rectangular box by your private messages and check the dot by 67 to 72 trucks, then click Google. VV
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 01-30-2015, 11:41 AM   #10
TBONE1964
Cluster King
TBONE1964's Avatar
Re: tach wiring
Grasshopper thanks you Master Po
Old 01-30-2015, 12:04 PM   #11
jocko
jocko's Avatar
Re: tach wiring
consider the pebbles snatched from the hand and the length of the rice paper walked.. go forth and make tach harness, young kwai chaing tbone.
Old 01-30-2015, 12:30 PM   #12
Andy4639
Old member
Andy4639's Avatar
Talking Re: tach wiring
I type my user name in the box up top of the page and selct 67-72 and it pulls all the threads I have started and posted in. I have no trouble with the search on the site.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 01-30-2015, 12:47 PM   #13
michael bustamante
Re: tach wiring
great thanks guys. i figured 67 would be different. t bone what would you charge for a 67 hei harness?
1967custom
Old 01-30-2015, 03:29 PM   #14
ray_mcavoy
Re: tach wiring
You're right ... the wire routing is different between the 67 vs. 68-72 tach harnesses.
The 67 routing is sort of a carry-over from 63-66. The brown coil wire follows the line for the oil pressure gauge out through the firewall, sharing the same grommet.
ray_mcavoy is offline   Reply With Quote
Old 01-31-2015, 05:58 AM   #15
TBONE1964
Cluster King
TBONE1964's Avatar
Re: tach wiring
Young I am not, Master very wise
Old 01-31-2015, 02:13 PM   #16
michael bustamante
Re: tach wiring
i dont know about you guys.... quit huffing them fumes....
t bone if you get any specs, can you pm me a price for a harness? hei.
1967custom
Old 01-31-2015, 02:22 PM   #17
TBONE1964
Cluster King
TBONE1964's Avatar
Re: tach wiring
Michael,
I don't no about specs. Two things we can do. I can spend the money to buy an aftermarket 67 only tach harness to model from (You could just buy it and be done, if you wanted to)
Or,
I can build you a tach harness and you tell me how long you want the brown wire to be going to the coil on your HEI. From what I gather, the brown wire goes through the firewall with the oil pressure line.
I can crimp and solder the correct HEI end on it for you. The rest of the harness is the same as a 68-72.
Basically the 67 is the same as the 68-72 with the exception of no firewall grommet and a shorter coil (brown) wire.
Send me a PM on this and I will let you know what I can do for you.
Let me know
Tom
Old 01-31-2015, 02:39 PM   #18
michael bustamante
Re: tach wiring
ill contact you as soon as i get the cluster. its coming usps
1967custom
