Old 01-29-2015, 05:28 PM   #1
Adam Moyers
67 Suburban Diesel Conversion Ideas
Just in the dreaming phase right now. I'm still looking for a 67 Suburban to buy. It will happen sometime this year or the next though. I would like to get the opinion of some of the more experienced members if you have the time to respond.
1. What would be the best diesel/auto trans combo if MPG is the most important factor?
2. Is it possible to get over 25mpg with the right setup?
This would be a daily driver that would rarely be towing anything.
I'm sure I will have a 100 more questions once I find my Burb and get started.
Thanks for your time.
Adam Moyers is offline   Reply With Quote
Old 01-29-2015, 09:41 PM   #2
marvgarr68
marvgarr68's Avatar
Re: 67 Suburban Diesle Conversion Ideas
6.2/6.5 for mileage they run good if you fix the common problems. It will bolt right in use an overdrive trans the th400 isn't the best for mileage.
1976 k20, 350 built, 44/14 axles
1968 c10 6.5 turbo diesel,t5 trans
1977 gmc c3500 dually, crew, 4-53t, 5&3 trans
http://67-72chevytrucks.com/vboard/s...d.php?t=591188
marvgarr68 is offline   Reply With Quote
Old 01-29-2015, 10:28 PM   #3
ryanroo
ryanroo's Avatar
6.2 would be the easiest swap. i dont think you will see mid twenties with it, but i bet you could set it up to do well, assuming a lower 2wd truck. there are claims on the web of 4bt fullsize trucks getting mid twenties. i bet if you set it up specifically for mileage and not hot rodding or big power its doable with a 4bt. lifted 4x4s are going to get worse mileage. for the 6.2 i agree a 700r4 would likely do the trick. with a b series cummins you can pick from many. dodge, gm, ford etc. they are adaptable to most popular stuff.
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 01-29-2015, 10:43 PM   #4
Adam Moyers
Thanks for the replies. Would it be possible to get 25+ with a newer ecodiesel?
Old 01-30-2015, 12:30 AM   #5
HemiChallenger71
HemiChallenger71's Avatar
1/2 or 3/4 suburban? an honest 25mpg is pushing it, with any fullsize truck.
4/6bt would be my go to. The 6.2/6.5 might be easier swap wise, but I personally hate 'em. Unless you can get a 6.2/6.5 DIRT cheap its not worth the hassle.
HemiChallenger71 is offline   Reply With Quote
Old 01-30-2015, 01:13 AM   #6
Adam Moyers
I dont have one yet, but I won't have a preference when I find the right one. Thanks for the input.
Old 01-30-2015, 03:41 PM   #7
superduty_59
I have a 97 Chevy K3500 ( 1 ton 4wd) crew cab dually. It has the 6.5 in it. When driving easy and no load I can get 24-25 mpg range. Loaded or drive hard and likely will see 18-19 mpg.
superduty_59 is offline   Reply With Quote
Old 01-30-2015, 09:45 PM   #8
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
We've worked on 2 different 97-98 chevy 2500 extended cab long bed 4x4 trucks that had p-pump 4bt's in them. They both got 25-28mpg driving hwy and 20-22 in town. Pretty hard to beat IMO. It really depends what you want. A 4bt will require mods, the 6.2 or 6.5 will be a bolt in deal for the most part. Also, how much you want to spend will affect this too.
Ryan
1969 Chevy milk truck
Old 01-30-2015, 09:57 PM   #9
Adam Moyers
Nice to hear of a few getting around 25mpg. Since this is the dreaming phase, the cost doesn't really play a role to me right now. This is how I look at it, people are spending $60-70k on a new suburban that will be worth nothing in 10 years. I would rather put $40-50k in a 67 and have it forever or at least be able to recoup some of the money spent if I needed to sell it.
This thread could easily turn into a 67 C10 truck or 69-72 blazer thread if the right opportunity presents itself. I've got my eye on a a 67 truck thats only 30 miles from home.
Thanks again for the input.
