01-26-2015, 11:08 PM | #1 |
Need some muffler recommendations
I'm trying to decide which type of muffler to put on my panel truck. I'm going to be running 2.25 tubing (unless you all suggest I go bigger) from my tbi 350. I want a good sound but I don't want it to be too much like straight pipes. I was considering Jegs Bullet muffler or there Deep Tone chambered muffler. I can only go about 9" in width.
What would you all recommend? |
01-27-2015, 01:46 AM | #2 | |
Re: Need some muffler recommendations
forget the mufflers, if you are going small diameter pipe get a couple glasspacks/cherry bombs and mount them at the collectors. the roadkill show swears its the best sounding exhaust and I tend to agree. I have a sound clip of my 65 donor with a 283, cast iron manifolds, small pipes and duals with glasspacks, skip ahead a little, at about a minute I walk around back of the truck.
01-27-2015, 02:05 AM | #3 |
Senior Enthusiast
Here are a couple of mine. 350/4 speed, Flowtech Terminator mufflers. 1st video with an H pipe (balance tube), 2nd video with H pipe blocked:
https://www.youtube.com/watch?v=V_xSu45o6kA https://www.youtube.com/watch?v=4Wdw-W3GyVg
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
01-27-2015, 07:32 AM | #4 |
I have the 40 series delta flow flowmasters on my 66 with an H pipe and the 2 1/4 pipe. Good bark when you are on it and no drone at cruise. Good option for a muffler with center in and offset out to get the pipes up and over the tailing arms. Had dynomax turbos on it for a short time with the same center in offset out and it ran like crap. Turbo muffler in this configuration just does not flow good.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
01-27-2015, 08:21 AM | #5 |
I had a pair of flowmasters on my 97 with a stock big block , after a while being a daily driver it was just a bit on the droney loud side ... i went with a 2 in 1 out and liked it a lot better , they did not offer 2 in 2 out otherwise I would have gone with that .. a muffler that merges the 2 head pipes into the muffler will help get rid of the drone .. you just have to search their site to see if they have one to fit your application ...
01-27-2015, 08:29 AM | #6 |
I use the Flowmaster 50 with my small block,,,love then but they cost alot..
i think a great choice would be the Summit , street and strips.....$29.99 and sound Great
Measure with a yard stick Mark with Chalk Cut with a torch Built it yourself, don't count on others to to do it for you or with you. It will never get done |
01-27-2015, 11:46 PM | #7 |
http://67-72chevytrucks.com/vboard/s...d.php?t=626510 I started this thread, but Kevins truck in post 9 has the ol'school sound
01-28-2015, 12:06 AM | #8 |
Moderator
Flowmasters (especially 40s) are loud/raspy/drone. Go with a pair of Summit Turbos. Cheap, and sound great.
01-28-2015, 12:40 AM | #9 | |
01-28-2015, 01:14 AM | #10 |
here what I had till i changed to the flowmaster 50.....deeper sound
https://www.youtube.com/watch?v=2AMi...YbUcnYtj3paF2Q
01-28-2015, 01:17 AM | #11 |
01-28-2015, 10:47 AM | #12 |
Magnaflows. They sound nice at idle, but come alive when you rip on it. No drone at freeway speeds like a Flowmaster. Stainless outer shell, reasonably priced, come in 12" and 18" lengths.
My opinion: Flowmasters are the most over-rated muffler on the market. Dyno tests have proven it, time and time again.
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
01-28-2015, 10:59 AM | #13 | |
01-28-2015, 11:41 AM | #14 | |
01-28-2015, 02:50 PM | #15 |
Interestingly, I have the same dilemma.
And have to approach it with caution as I like to spend sensibly. When I bought the truck, it was described as having Flowmasters fitted, exiting in front of the rear wheels. I like that a whole lot. The seller also described it as a 327, but the V5 license document states 350ci Unfortunately, the engine numbers were machined away, presumably when the engine was rebuilt at some time in the past. ANYWAY......... Back to business. I plan to fit a pair of 3" cutout pipes and and cutout valves to the truck, after which it will hopefully get a 2.5" dual exit setup, unless I can get the pipe sections made up in 3" flavour. So my question is this, (and I ideally want real life experience and advice, as I know there are quite a few UK based guys on here) In the UK Powerflow has been suggested. My friend Paul Y will be helping me too, but I like as much as possible info. What silencers will perform as will as Flowmasters, Magnaflows and various USA sourced equipment??? But at possibly more sensible pricing. I am planning to go Mild Steel from behind the cutouts, which are Stainless Steel. From a preference point of view, I do not want to alert Mr Plod from 200 yards, and do not want to get out the truck after a 100 mile motorway trip with the teardrop trailer behind me and end up with a throbbing headache. However, a nice sound is a nice sound. I will have the cutout valves to add the Anti Social Thuggery side of the trucks persona. This is what the truck sounded like when I got it. Coming down the side of our house. [video=youtube;x62zfyfLFGI]http://www.youtube.com/watch?v=x62zfyfLFGI[/video] Tight as a tight thing.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE. Last edited by Grizz1963; 01-28-2015 at 02:57 PM. |
01-28-2015, 07:05 PM | #16 |
How loud do you want in the cab?
I have Walker Turbo mufflers on my 64. Sounds very good outside, but won't drone you to death inside. Especially on your panel. You have a big echo chamber. I love the sounds of my Flowmaster 40's on my 94 350TBI, but the are a bit loud and if the 94 was a bigger cab (crew/extended) it would be more irritating for long drives than nice. My 02, has MagnaFlows and they, like the Walkers, are a very good compromise. Nice mellow sound inside, very tough outside...but the walkers are way cheaper.
Bill 1970 Chevy Custom/10 LWB Fleetside 2010 Toyota Tacoma PreRunner SR5 Double Cab - DD Member of Louisiana Classic Truck Club (LCTC) Bill's Gallery Life isn't tied with a bow, but it's still a gift. Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God! Last edited by Palf70Step; 01-28-2015 at 07:14 PM. |
01-28-2015, 09:53 PM | #17 |
Well after some pricing and a quick dwindling bank account I decided to be cheap and go with some glass packs for now. I got the main part of the exhaust down tonight and I actually really like the sound. If it drones too much when I drive it I will switch them out with one of the above mentioned mufflers.
Thank you all for the input. |
01-29-2015, 02:49 AM | #18 |
I dont think you will have drone unless you put the glasspacks all the way at the back. make sure you run the pipes out the side or back too, not under that echo chamber.
as a side note, that video I posted was for the for sale thread when I sold the 283 out of that bent frame, it was up for sale maybe 2 hours and the guy insisted on taking that exhaust glasspacks man, thats the snip snap.
01-29-2015, 03:20 AM | #19 | |
1966 C10 Short Fleetside 1988 Sportster, 2008 Street Glide Ken's 1966 C10 build "Red Ale" Follow on Instgram: @cv_performance https://instagram.com/cv_performance Harley Performance Parts: CV Performance (Harley related) Enjoying the ride! |
01-29-2015, 03:22 AM | #20 |
If you really want to quiet your cabin undercoat it, then dynamat then dynamat foam and a thick layer of jute plus your carpet and it should be dead quiet. The more insulated the cab is the less noise you will hear inside.
Custom Painter/Restoration Specialist 1965 GMC 3/4 Ton LB SOLD? 1964 Chevy El Camino in full restoration 1991 Chevy S10 288K+ miles 2nd Owner SOLD 2020 RAM 1500 Warlock |
01-29-2015, 04:38 AM | #21 |
Sorry. Double post.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE. |
01-29-2015, 04:40 AM | #22 | |
If you click on the first video, and then look in the menu below it, you can click on the other videos he has posted, including the one you mention.
01-29-2015, 09:56 PM | #23 |
Little tip:
The closer to the engine the mufflers are, the louder it will be. Likewise, the further back in the system you put the mufflers, the more quiet it will be.
'62 C10 LWB fleet side. 283 w/ a T5 |
01-29-2015, 10:15 PM | #24 |
One foot in front of the other
01-30-2015, 09:06 AM | #25 |
Here's how they ended up. About 2 feet from the rear end. Since I body dropped it about 4" the pipes are going to have to kick out to the side either before or after the axle.
