Old 01-30-2015, 09:38 AM   #1
Ronw435
Ronw435's Avatar
Speakers in fresh air vents.
Was wondering how many have put speakers in the fresh air vents? Those that did , did you block off the fresh air from coming into the back of the speakers?
Thanks for any information.
Ronw435
Ronw435 is offline   Reply With Quote
Old 01-30-2015, 09:49 AM   #2
PGSigns
PGSigns's Avatar
Re: Speakers in fresh air vents.
I have the speakers in the kick panels. I don't have air conditioning so closing off the vents is not an option.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 01-30-2015, 10:55 PM   #3
Bret B
If you don't block off the top of the vent, you're gonna get water, dirt and junk in behind the speakers. Which means, you really don't have a choice if you intend to do speakers, and not do damage to them over the long term. I'm sure there are ways to fab an enclosure which would "encapsule" the speaker and still be a useable as a vent. I can see it, in my head, but I'd probably never be able to make it.
Bret B is offline   Reply With Quote
Old 01-31-2015, 08:52 AM   #4
Ronw435
Ronw435's Avatar
Bret B when you say "block off the top" what exactly do you mean? What I was thinking of doing is block off the back of the "box" that comes out when removing the screws and removing the insides.
Old 01-31-2015, 01:41 PM   #5
Maddoxdb
Maddoxdb's Avatar
Something like this could work also to protect your speaker. I would think you'd want something to prevent stuff from getting down there in the first place. These also would help to push the sound into the cab. As a small speaker box.
http://www.crutchfield.com/g_762/Foa...s.html?tp=2809
Maddoxdb is offline   Reply With Quote
Old 01-31-2015, 05:01 PM   #6
Ronw435
Ronw435's Avatar
Good idea Maddoxdb, I will look into those. I have some small oval pioneer speakers that the PO had put in it and it looks like it has the boxes for those as well. I'm just not sure those little speakers will do the job being down there. Thanks for the information Maddoxdb
Old 01-31-2015, 08:49 PM   #7
Hugh in NC
Hugh in NC's Avatar
The previous owner of my truck put speakers in the vent holes. He put some heavy duty plastic in the hole, then installed the speaker. The speakers sounded awful. I think the air pressure on the back of the speaker plus humidity was the problem. I took them out, sealed the vent with sheet metal, and mounted these surface mount speakers there.
http://www.crutchfield.com/p_068P661...RPOD6-612.html
I have had no problems with the limited space they require and they sound much better. Next I need to get a new radio to replace the Audiovox radio/cassette player currently installed.
Hugh in NC is online now   Reply With Quote
Old 01-31-2015, 10:07 PM   #8
Bret B
Ronw435, what I mean by "block off the top" is, using a piece of metal cut to approximate shape of the vent profile up where the wiper transmission arms are. Essentially a "D" shaped panel or similar, welded (probably difficult to weld in, I don't weld, so I wouldn't know) in, blocking off any water and junk from getting down behind the speaker. One would also have to drill some sort of passage for the water to escape from the vent. The other alternative is to encapsulate the speaker in a cup and then install in the vent. Making a cup to surround the speaker would allow all the water to still pass thru the drain slot at the bottom of vent box, in theory of course. I hope this makes some sort of sense. I can see it in my head, but how to explain it all isn't always easy.
Old 01-31-2015, 11:08 PM   #9
Chevy Fleetside
Chevy Fleetside's Avatar
I used the vents. I blocked off the back. I can't remember how I did it but I think Plexi-glass was involved. I know I used plexi where the speaker mounts. They sound really good.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 02-02-2015, 09:04 AM   #10
Ronw435
Ronw435's Avatar
Thanks for the photo Chevy Fleetside, looks like a good idea.
Old 02-02-2015, 11:55 AM   #11
Gooker928
I'm going to put some 6x9s in my vents. I'm thinking they should work just as well as the door speakers that most manufactures use and door get a lot more moisture and debris than those vents ever will. I'll keep you updated.
Gooker928 is offline   Reply With Quote
Old 02-02-2015, 02:55 PM   #12
Chevy Fleetside
I can't remember but I don't think they fit. I have some 6x9's behind the seat and I think I tried to fit them there but they were just to long. I am over 50 so I could be remembering wrong.
Old 02-02-2015, 03:37 PM   #13
64shortbed
64shortbed's Avatar
I took air vents out and took the flap out of each one. then welded patches front and back. And welded any other holes that needed it and cut a 6" hole in the front for speaker and put everthing back in. worked great. Seam sealed them up before mounting speakers.
64shortbed is offline   Reply With Quote
Old 02-03-2015, 01:00 AM   #14
wutnxt
Location: vancouver b.c....is the biggest place most people would know but I am actually out in the valley 45 mins away
If you put speakers into those fresh air holes if it's a daily driver you need to build a fiberglass bucket and put sound deading around it to keep it all clean/dry and from rattling . The other problem is that if you put them in flat the sound shoots across and just hits the other sound from the other side. If your putting out any power you need to aim your speakers back towards the seat and aim them up towards the top of the seat . You get a left and right clear sound that way and it's easy to do . I build kick pods and jamb them full of speakers and aim them like i suggested.....pull out the gas tank from behind the seat and build a rear seat box and stuff in 2 - 12" subs . Kick pods are easy to build and give great sound...I think on my Street Hulk thread i have some pictures of the pods i built if that helps you out for some ideas ?
1966 Pro street build http://67-72chevytrucks.com/vboard/s...?t=448089[
1958 LS 2 build http://67-72chevytrucks.com/vboard/s...d.php?t=527123
1966 SBFS low and go http://67-72chevytrucks.com/vboard/s....php?p=5799909
1966 SBFS street HULK http://67-72chevytrucks.com/vboard/s...=1#post5886625
Poject Low and go gets a 6.2 ltr LSA supercharged with 6 speed automatic
Aluinum Radiator Dealer pm for details
wutnxt is offline   Reply With Quote
Old 02-03-2015, 01:33 AM   #15
Chevy Fleetside
I did seal them off and insulate them. It sounds good enough for my old ears... haha
Old 02-03-2015, 08:18 AM   #16
corvettejim1968
corvettejim1968's Avatar
i went a different wrought . i did the plate with two 4in coaxial speakers in the dash. the sound stage is much better than down by your feet. i also used Fat Mat to dampen any surrounding metal.
Hand Made Factory reproduction A/C vents
text or call 602-361-6421
Website for A/C vents
https://coolc10.com/
corvettejim1968 is offline   Reply With Quote
Old 02-03-2015, 09:25 AM   #17
Ronw435
Ronw435's Avatar
Great ideas everyone. Wutnxt do you have a finished picture of your speaker install? And Corvettejim did you use the existing speaker louver in the dash for your install or did you modify the dash?
Thanks for all the ideas everyone.
Old 02-03-2015, 03:17 PM   #18
wutnxt
I did a similar thing on my 58 build and there are alot of pictures to give you a idea of where i was going with it ...You can stuff alot of sound down in those kick pods but i also have a pair of 4"stuffed up in the dash as well . The sub boxes it the 58 aren't anything fancy but i was in a big hurry to roll and I will redo those later .....But the sub box in the Hulk truck is very sexy and I have installed a bunch of sub boxes in other customers trucks since then .....
Old 02-03-2015, 03:18 PM   #19
wutnxt
http://67-72chevytrucks.com/vboard/s...=527123&page=8
check out page 8 on the 58 build....i forgot the link my bad
Old 02-03-2015, 10:08 PM   #20
corvettejim1968
i did not modify the dash at all. the plate came with a couple brackets and i used fat mat to help as well
Old 02-04-2015, 09:23 AM   #21
Ronw435
Ronw435's Avatar
I appreciate all the replies guys, Thanks a lot.
Old 02-04-2015, 02:27 PM   #22
MisterC
MisterC's Avatar
I have this photo in my stash of possible future projects. Looks like a solid way to go.
Poor and content is Rich...and Rich enough! - William Shakespeare
1966 C10 Custom Cab "Luigi"
Big Window - SWB Fleetside
350 V-8 - Powerglide
My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894
MisterC is offline   Reply With Quote
Old 02-21-2015, 05:58 PM   #23
Blue666(2)
Just today I bent up a 12 x 12 piece of 22 gauge metal. With just two bends you could mount the speakers in rear corner.
That's a 6 x 9 speaker. I need to cut just a bit off the door jam side so I can lift it up higher in the corner, I'm not sure if I will weld or use a body panel adhesive to hold in place.
I think if you used a 12 x 16 piece of sheet metal, you could probably fit it around that metal from the rear window area.
Blue666(2) is offline   Reply With Quote
Old 02-21-2015, 06:48 PM   #24
LDO
LDO's Avatar
that looks great! Does the rear of the 6x9 hit the wall of the cab?
LDO is offline   Reply With Quote
Old 02-22-2015, 01:09 PM   #25
Chevy Fleetside
Does the seat go all the way back? Is the seat in front of the speaker? Just wondering.
