Old 01-30-2015, 09:52 PM   #1
Back row pupil
1/2 ton to 3/4 ton running gear
I need advice on choosing the right year of 3 / 4 ton running gear, to put under my '72 short box. I want an easy transition. Plus I am looking to disc brake the rear! Looking to run the new 37's or old school 38's.
Back row pupil is offline   Reply With Quote
Old 01-30-2015, 10:34 PM   #2
Back row pupil
I need advice on choosing the right year of 3 / 4 ton running gear, for my '72 short box. I want a relatively easy transition. Plus I am looking to disc brake the rear. I am wanting to run the new 37's or old school 38's.
Old 01-30-2015, 10:45 PM   #3
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: 1/2 ton to 3/4 ton running gear
This a 4x4?
Put a Corporate 14 bolt FF under it. Bomb proof.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 01-30-2015, 10:45 PM   #4
GASoline71
GASoline71's Avatar
No need to post this in multiple areas...
Gary
Old 01-30-2015, 10:53 PM   #5
Back row pupil
Does the year matter? Rumor has it that the '79 is best because of larger bearings?! How about disc'ing the rear, relatively inexpensive?
Old 01-31-2015, 12:14 AM   #6
Hi, welcome to the site. I answered in your other thread.
Old 01-31-2015, 12:51 AM   #7
Captainfab
60-66 Nut
You can get rear disc caliper brackets from either http://www.Ruffstuffspecialties.com or http://www.Diy4x.com. Reasonably priced and quite simple to do.
Old 01-31-2015, 11:51 AM   #8
whitedog76
You can also retrofit an older axle to discs w/parking brakes using factory parts.
http://s1074.photobucket.com/user/wh...90510598618083
Look into 2000 and newer trucks and 2003 and newer vans.
whitedog76 is offline   Reply With Quote
Old 01-31-2015, 03:45 PM   #9
Back row pupil
Wow! Thanks for the advice!
