Plow Trucks.
just picked up a Meyers period correct plow for my 84, I am looking for more info if any could please give me photos of their plow trucks and how the plow frames mount to your chassis.
If anyone can identify exactly what model I have here that would be extremely helpful. I will need wiring schematics and mounting hardware. Thanks in advance for the help. ![]()
1985 Custom Deluxe long bed 305 3 on tree 2015 Silverado "Great White"1987 K20 dump and plow 1968 K20 327 long bed 4spd big blue 68K20 SuburPan 4spd 79C30 L96 6L90e 86 K10 plow |
Robert Olson Transport
![]() Join Date: Oct 2002
Re: Plow Trucks.
Last year I bought a 79 with an existing western plow on it I have no real knowledge of plows but my plow frame you had to kick off the bump stops for the axels and it bolts through the frame under the bumper and in front of the engine crossmember. the brackets for the pump attach to this too and there are brackets so you can mount the OEM front bumper on it. The plow has a triangle part that you put pins in to to hold it to the bolt on frame and you then use a chain to the pump for up and down action
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
Re: Plow Trucks.
Looks like an Meyers E-47
1973 k20 Suburban 350 1974 Custom stepside c-10 250 1975 Chevy stepside 454 1986 K30 Crewcab SRW 350 R.I.P- glimmertwin01- board member and good friend, you will be missed |
Re: Plow Trucks.
Here is the Meyers Plow I have my 85 K5. Same blade and A frame as yours. The part that mounts to the truck has some similarities. Mine is a full hydraulic, has a pump that looks like a GM power steering pump a reservoir that holds a gallon of fluid and a valve body that mounts on the fender well with two long rods that go through holes in the firewall into the cab. I paid $200 for it and have about another $150 stuck into it with new hoses and hardware. Still have two hoses to replace yet.
Eric 2001 Ford F350 EC dually 7.3 1981 Chevy C20 to K20 350 1978 Oldsmobile Cutlass Supreme 455 Pontiac 1969 Pontiac GTO 400 |
Re: Plow Trucks.
thanks guys.
Bob? "kick off the bump stops for the axels" ??
Re: Plow Trucks.
I set up the blinkers/running lights to run with the normal ones. I then just wired two toggle switches with relays for the high and low beams. Meets the needs and is way less complicated than the switchover headlight harness normally used.
1986 K30 cab/chassis with 9 foot aluminum diamondplate flatbed. 454 (now a 350)/SM465/205/14b/Dana 60/IMT belt driven air compressor |
Re: Plow Trucks.
there are two for lack of better word L brackets under the truck that had concial rubber bumpers on them when you hit a bump they stop toe front axel from moving too far not allowing the truck to bottom out ont he frame I had to move those and I welded them tot he frame
Re: Plow Trucks.
Looks like the same plow frame I have with a Meyer E47. Check out some pics on the 1st page of my build thread (link in my signature).
It'll bolt on at the front of the frame horns and the brace runs up and bolts just ahead of the bump stops. Also there are some brackets to relocate the bumper ahead of the plow frame.
-400/400 1979 K25 350/SM465/205/44HD/14FF 1985 K20 400/400/208/10/14 1987 V10 TBI350/700R4/208/10/10 '85 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=643968 |
Re: Plow Trucks.
78K & 79C Jimmys
Re: Plow Trucks.
sounds like the setup my old 78 bronco had,
running off the power steering pump... It had plow supports to the frame(just see them a bit below)
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
78K & 79C Jimmys
Re: Plow Trucks.
my 79 western has the same kinda plow supports
Re: Plow Trucks.
yours looks similar to mine motornut
Re: Plow Trucks.
Here is few pics of how mine is mounted.
Re: Plow Trucks.
the guy I got the plow from said he unbolted it. (no welding, maybe drill a few holes)?
it apparently has brackets to attach the bumper in an extended position after the plow bracket is installed. we picked up the bracket and got it in the shop just before three feet of snow hit us. I won't be able to get to it for a few days. thanks for all the help and comments
#15 |
Re: Plow Trucks.
I had to drill the holes in the frame where the brackets mount above the leaf springs. The front frame work uses the bumper bracket holes. I made the brace that connects the upper and lower frame work together out of some angle iron I had laying around as I didn't get all the brackets.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
