Old 02-01-2015, 05:56 PM   #351
dwcardfan
dwcardfan's Avatar
Re: 64 C10 Stepside "Jaybird"
Looking good!!! That satin white is sweet.
dwcardfan is offline   Reply With Quote
Old 02-02-2015, 08:46 AM   #352
bj383ss
bj383ss's Avatar
Originally Posted by WhippinSaw View Post
Nice save on the paint, had to do mine a couple times too. I think our trucks look great with a white top and that satin looks classy
Thanks WhippinSaw. I agree I have always loved the two tone with White. The trouble I had was deciding how to paint the White as they are many different lines you can mask off. In the end I just went original.
Originally Posted by tune_1 View Post
Work looks good. Glad you backed up and did it again so that you would be happy with it.
Dwight
Thank You. You are right about that. I would have urked me everytime I saw it. I may even end up reshooting the top only as their is a light spot on the very front of the shelf.
Thanks Dwcardfan.
64' Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=586955
bj383ss is offline   Reply With Quote
Old 02-02-2015, 08:47 AM   #353
bj383ss
bj383ss's Avatar
Had another really nice 70* day today. Was warm enough I was able spread some filler on the back of the cab and finish up all the bodywork. I spent quite a bit of time on the outside back corners of the cab as this is all visible on a stepside. Both sides had their share of dings and I hammered and dollied as much as I could. Used the new Rage Gold filler I got for Xmas. This stuff is awesome lays down real smooth like peanut butter and has virtually no pinholes and sands real easy. The weather started to chill in the afternoon so I was not able to shoot primer. Couple of coats of filler primer and some blocking and the cab is ready for some Midnight Blue!
20150201_145452 by bjohnson388, on Flickr
20150201_145501 by bjohnson388, on Flickr
20150201_145520 by bjohnson388, on Flickr
Old 02-02-2015, 09:02 AM   #354
Grizz1963
Grizz1963's Avatar
Funny how these build threads are like a drug.
I am sitting having a quick coffee in a hospital before getting out to go hunting again and checked in.
That filler sounds like a rather good investment.
Progress is Progress.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline   Reply With Quote
Old 02-02-2015, 09:37 AM   #355
Mjminino
I agree Rian. I read people's build threads before I go to work in the morning and usually read them when I get home.
Mjminino is offline   Reply With Quote
Old 02-08-2015, 08:17 PM   #356
bj383ss
bj383ss's Avatar
Stripped my passenger door yesterday. Found some stuff I really didn't want to but that's how these old trucks are. Surprises around every corner. The front corner is rotten. That is a relatively easy fix. It appears the door check broke at one time and the door was allowed to swing to far and crease the door. The body man that fixed pulled some of the dent and then filled over with a 1/4" bondo. I swear I ground at least a quart of bondo off this door.
So I will have to cutout the two creases and weld in some new metal. There is also a crease running down the bottom middle of the top curve part. Not sure I can really do anything with this and it is not that deep so will probably just fill over it.
Does any of this look familiar Rian?
20150207_113752 by bjohnson388, on Flickr
20150207_113741 by bjohnson388, on Flickr
20150207_113746 by bjohnson388, on Flickr
20150207_113757 by bjohnson388, on Flickr
Looks like an ANGRY BADGER was riding shot gun and beat the hell out of the bottom of the door. I am really curious how this even happened as the original rocker had no damage in this area? Was going to bang this out from the inside since there is a speaker hole but there is another panel behind it so no access. Probably just cut it out at the edge and then hammer the edge square and weld in a new piece.
20150207_125046 by bjohnson388, on Flickr
Also the door check area is beat up as well. Must have been a violent wind whipped the door or something who knows!
20150207_125100 by bjohnson388, on Flickr
Old 02-08-2015, 09:35 PM   #357
Ta2Don
Ta2Don's Avatar
The joys of P.O.s
Small potatoes for you Brotha!!!
DON
Proverbs 27:17
US Air Force Retarded errr Retired
My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920
My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266
My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD
Ta2Don is offline   Reply With Quote
Old 02-08-2015, 09:35 PM   #358
Mjminino
You can look at THIS page about newer door checks.
Old 02-12-2015, 08:34 AM   #359
Mjminino
What have you decided about the doors, are you going to re-skin them up to the window frame?
Old 02-12-2015, 07:31 PM   #360
bj383ss
bj383ss's Avatar
My current plan is to make some wooden pucks that match the profile of the two outer areas I need patches for. Make some patches and then trace them out over the damaged area cut out and weld in the patches. I don't really want to replace the whole door skin. I found a tool online that I might be able to use to push the crease out from the inside.
Old 02-12-2015, 07:35 PM   #361
Mjminino
What tool?
Old 02-12-2015, 07:51 PM   #362
Mjminino
Hey bj383ss, do you have Facebook?
Old 02-13-2015, 08:02 AM   #363
bj383ss
bj383ss's Avatar
Originally Posted by Mjminino View Post
What tool?
Its basically a 1/2" bar with a right angle at the end with a rubber tip. They are pretty expensive. I may try to make one myself. I watched several videos on youtube of PDR and guys using them on newer cars. But they have thinner metal so not sure it will work on the older metal. Will find out.
http://denttoolsdirectusa.com/product-category/rods/
Yes I do and you are already friends with me. HA!
Old 02-13-2015, 09:38 AM   #364
4mulaSvaliant
4mulaSvaliant's Avatar
Haghaha.... 15 pages later and 2 cups of coffee! LOL Great build man! Nice work! Subscribed
64 LWB to SWB Step build. Daily driven!
http://67-72chevytrucks.com/vboard/s...d.php?t=647168
4mulaSvaliant is offline   Reply With Quote
Old 02-13-2015, 01:13 PM   #365
WhippinSaw
WhippinSaw's Avatar
looks easy compared to what you done but if your budget will allow it there are some straight doors over in the parts forum,
1963 Fleet Side cab, Converted Fleet Side Barden bumper, Step Side in the middle.
WhippinSaw is offline   Reply With Quote
Old 03-07-2015, 09:38 PM   #366
bj383ss
bj383ss's Avatar
Man my thread was back on page 4. I have been slacking. Had some truck time today and also spent about 4 hours talking truck with 66customcab. Studied a lot of things on his truck to see how they came from the factory. Got a real good idea of where to tape off on the front grill for the white, black and blue. I also discovered I have a Custom cab bench seat by the extra springs mine has. Same as his. Very cool getting to meet him and his truck today.
After he left cleaned the shop real good and started masking off the white and getting ready to spray the Midnight Blue. Very excited. It was 60* today and this coming week we have 3-4 days we are suppose to hit 70* so I want to have the bottom part of the cab ready to go.
Unmasked everything and pleasantly surprised to have no overspray of white onto the California Suede Metallic.
20150307_160530 by bjohnson388, on Flickr
The masking tape I bought is pretty awesome. Even for an amateur like me I got really good crisp lines. And the tape is see through which I didn't understand and first but now I do. It lets you see the previous tape line easy to see when you are masking to spray the second color. Awesome.
20150307_160557 by bjohnson388, on Flickr
I also got the back cab wall sanded so I can reshoot it.
20150307_160610 by bjohnson388, on Flickr
20150307_164814 by bjohnson388, on Flickr
Also had a bonfire and burned all the tree trimming from a couple weeks ago.
IMG_5247 by bjohnson388, on Flickr
Old 03-07-2015, 11:50 PM   #367
Ta2Don
Ta2Don's Avatar
Progress and Fire...
DON
Proverbs 27:17
Old 03-08-2015, 08:39 AM   #368
Mjminino
"FIRE FIRE FIRE FIRE" in my best Beavis voice
Old 03-08-2015, 12:40 PM   #369
62 Barnfind
62 Barnfind's Avatar
If you can't push them out I can help you with the door skin. I replaced my right side on my 62 and it only took a day. Before I did it I went to talk to an old body man and he showed me an easy way to do it. It's really easy.
John Z
1962 Chevy C10 Stepside
62 Barnfind
My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513
62 Barnfind is offline   Reply With Quote
Old 03-09-2015, 07:54 AM   #370
bj383ss
bj383ss's Avatar
Thanks for the offer John. I really don't want to replace the whole skin. Will see how I do on it.
Old 03-09-2015, 07:57 AM   #371
bj383ss
bj383ss's Avatar
Couple of rounds of high build and blocking on the back and she will be ready for some paint.
20150308_141903 by bjohnson388, on Flickr
20150308_141917 by bjohnson388, on Flickr
20150308_141928 by bjohnson388, on Flickr
20150308_141937 by bjohnson388, on Flickr
Old 03-09-2015, 08:23 AM   #372
clemdaddy
clemdaddy's Avatar
good work man. we're gonna get a few days of nice weather also and painting is in my immediate future. good luck to you with yours.
and i like the cab stand you made.
clemdaddy is offline   Reply With Quote
Old 03-09-2015, 09:48 AM   #373
mjh1965
mjh1965's Avatar
Looking good Bret
you will have it back on the chassis in no time ��
FINALLY PUTTING IT BACK TOGETHER AT LONG LAST
MY BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=611614
mjh1965 is offline   Reply With Quote
Old 03-09-2015, 10:27 AM   #374
Ronw435
Ronw435's Avatar
A quick question on the primer. Does everyone sand the primer everywhere before applying the base coat or SS?
Ronw435 is offline   Reply With Quote
Old 03-09-2015, 01:02 PM   #375
bj383ss
bj383ss's Avatar
Ron
The sealer primer shot right before color has to be wet. I let it flash for about 15 min before the color
