Trucks with rear disc brakes
For all of you all with rear disc brakes, how many of you are using an e-brake? I am in the process of smoothing my firewall and trying to decide to keep or not to keep the e-brake. I can't remember the last time I used mine in any of the trucks I have had in the past. Just wondering and looking for input.
Chip |
Re: Trucks with rear disc brakes
Bag it and set the truck on the ground
![]() Some caliper set ups have parking brakes built into them.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
I guess I was looking for a "poll" to see how many leave the brake intact.
If your state inspects cars a working parking brake is on the list.
![]() ![]() Join Date: Aug 2013
Leave it if possible...just adds that bit of comfort when leaving it running while not inside of it....
I'm just glad to be here!
I had a set up from a C5 vette with the drum in hat style parking brake that we adapted to the stock truck 12 bolt rear end. Worked well and passed the state inspection.
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
Look thru the link to Sunburn in my sig. I used some brackets I bought from a forum member, but I do not think he has anymore right now.
motor exploder
I used '97 Camaro z28 rear calipers that have a parking brake on my '69 (it has a 5 speed) - they just have a pull that locks down the caliper. I had to modify a set of factory parking brake cables to hook it up to the eStopp electric parking brake I'm using. I kept my ebrake AND smoothed the firewall.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac ![]() ![]() Use the SEARCH function on this forum - it is your friend!! Last edited by BossHogg69; 02-07-2015 at 07:57 AM. |
I use the Parking Brake in my daily driver all the time. I don't like the BANG when I shift into gear when parked on an incline. Not to mention it gives me some piece of mind when hooked to a trailer or loaded up.
On my project truck I have a 5 speed transmission. I'm using a caliper/bracket assembly I scavenged from an 03 van because I wanted something with a parking brake. The setup is disc brake with internal drum&shoes. It can be used on 6 and 8 lug trucks. http://s1074.photobucket.com/user/wh...40847759084066 |
![]() Join Date: Nov 2007
Im using them on mine.
meowMEOWmeowMEOW
To quote the immortal Mitch Hedberg. "The Emergency, 'make the car smell funny' lever"
I cut all the cables and removed the handle that made up my drum emergency brake setup, and ditched it entirely. I have an automatic, so I just put it in park.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
I think I am going to keep them and use the kit from Toms on ebay. The problem I was finding is that part store calipers didn't have the "clips" to hook up the cable. Toms appears to be complete. anyone used his kit? yea or nay?
Thanks for all of the replies. Chip |
#15 |
I'm using Tom's kit on my 56 truck rear end (67 Camaro 12bolt)
The kit was good and you get most everything but the instructions are lame at best. As long as you are experienced in suspension and brake work you will know about residual valves and using a disc brake master cylinder and related parts needed. They don't supply nor do they tell you what else is required to complete the kit, you are just getting those parts pictured... BTW the rear calipers are 80 Cadillac Seville rear calipers, he reason I know is I received 2 driver sides instead of a passenger side. I had to exchange it locally. All in all its on and works as expected....here are some pictures...good luck |
#16 |
thanks Joe for the reply, the undercarriage of your truck is sharp hope mine looks that good some day.
#17 |
Roto Reuter thats the name...
![]() Join Date: Feb 2010
In New York State we need to have emergency brakes. On my new build I'm planning to shave my firewall and do not plan to use the stock pedal E-brake. I'm planning to use the E-Stopp set up. Got good reviews. Check it out.
http://www.estopp.com
~ Dan ![]() My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
#18 |
meowMEOWmeowMEOW
I should mention, Hydraulic ebrakes are freakin AWESOME once you've used one....but they don't work quite the same.
#19 |
Old member
I bought the kit that uses the e brake. I like knowing it is working. I live on a hill so I use it all the time. I have caught 2 vehicles running down the drive way so far in 20 years living where I do.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
