Old 02-07-2015, 04:22 PM   #1
68_Step
HEI Distributor question
I am on the process of rebuilding an HEI distributor. Took it completely apart and there was a clear plastic cover over the grease well - thing was so dirty I did not know it was there. So I poked a screwdriver thru it as I was cleaning it out. It is not in the rebuild kit. Is it something I need to replace? What do I call it?
Question 2: directly above the grease well there was a "coil" with 2 wires and plug. The wires are worn thru the insulation where they connect to the "coil" (what is it called?). I am guessing that it needs to be replaced. Is that something I can get at O'Reilly's or Auto zone?
68_Step is offline   Reply With Quote
Old 02-07-2015, 04:56 PM   #2
Wrenchbender Ret
Re: HEI Distributor question
You don't need the grease well. Just put a little grease were the pickup coil rides. That is called a pickup coil. You must replace it if it is in that bad of shape. It is about the second most cause for failures.
I have some new pickup coils. I can sell you one cheap.
George
Wrenchbender Ret is offline   Reply With Quote
Old 02-07-2015, 06:55 PM   #3
bigmac73
bigmac73's Avatar
do not get offended, but I would have just went down to NAPA and bought another dist, or upgraded to an aftermarket,
Unless you are just wanting the rebuild experience, to me it is not worth the time to completely do an overhaul when they are cheaply replaced these days
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 02-07-2015, 07:06 PM   #4
68_Step
For me the best way to learn how something works is to take it apart and hopefully put it back together. The rebuild experience is exactly what I am looking for. Sigh, I wish I had a NAPA nearby...
Old 02-07-2015, 07:32 PM   #5
michael bustamante
michael bustamante's Avatar
Yup thats how i learned about dist. Too.
1967custom
michael bustamante is offline   Reply With Quote
Old 02-07-2015, 08:01 PM   #6
71K20chevy
71K20chevy's Avatar
Keep in mind though aftermarket parts aren't always what they're cracked up to be. Nothing beats original GM parts in terms of reliability!
71 K20
64 GMC mud truck
71K20chevy is offline   Reply With Quote
Old 02-08-2015, 11:32 AM   #7
68_Step
do not get offended
No offense taken. If I had been in a hurry I probably would have headed to the parts store.
Old 02-08-2015, 05:03 PM   #8
68_Step
Is this how the capacitor mounts? It does not seem to fit in the square recess below it. Looks like I will deform the aluminum strip that goes around it. Is that correct?
