Old 02-08-2015, 08:50 PM   #1
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
door latch
Anybody have dimensions of the rod that goes to the inside handle to the lock mechanism? Mine was a little bent but not sure which bends are correct. Thanks,
Jim
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 02-10-2015, 09:08 AM   #2
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Re: door latch
I think the factory bend is a "V shape" in the middle, anybody?
Old 02-10-2015, 10:50 AM   #3
joeydurango
joeydurango's Avatar
Re: door latch
Mine are extra bent on purpose - I had to in order to make the latches work. If you can get an eye on the latch (roll the window down and look through the top of the door), it's pretty easy to see what's happening when you operate the handle, and then easy to figure out whether the rod needs to be shorter or longer. Bend accordingly. Can't remember if there's a threaded fitting on one end for small adjustment, seem to remember that... but in my truck (if that fitting exists) it wasn't enough to make the door handles work.
1972 K10 Cheyenne Super | LWB, fleetside | 350/350/205 | KEEPER
1971 K10 Cheyenne | SWB, fleetside | LS Swap 5.3/4L60 | SOLD
1976 Trans Am | 400/4-spd | SOLD
1976 Trans Am | 455/4-spd | TOTALED
joeydurango is offline   Reply With Quote
