Old 02-08-2015, 08:54 PM   #1
Jr55
1955 chevy 1300 project
Hi I am a newbie to this site,This is my 1955 Chevrolet 1300 1/2 ton project.The truck sat on a relatives farm in alberta ,Canada for 40 years.So far I have cut the frame and box to achieve the short bed dimensions.It is a six cylinder manual trans model.
Jr55 is offline   Reply With Quote
Old 02-08-2015, 09:46 PM   #2
59chev
59chev's Avatar
Re: 1955 chevy 1300 project
Welcome to the site, I am planning on cutting down my 59 longbed to a shortbed this summer. Do you have any pictures of cutting the frame down?
Click the link in my signature to check out my build thread.
My Build Thread: 59 Apache - Lifelong obsession
http://67-72chevytrucks.com/vboard/showthread.php?t=622133"]59 Apache - Lifelong obsession
59chev is offline   Reply With Quote
Old 02-08-2015, 10:34 PM   #3
Jr55
Hi Thanks,I cut 9.25 inches from frame,The cut starts at the cab mount bracket back.Then took the front of bed off and drilled out the spot welds holding the steak pocket on and then cut the same amount off the bed sides then spot welded the pocket back on.
Old 02-08-2015, 10:38 PM   #4
Jr55
This is the before.
Old 02-08-2015, 11:09 PM   #5
Kim57
Kim57's Avatar
Welcome.
Be sure and document your build as others will like the info on the changes you make.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 02-09-2015, 08:41 AM   #6
1project2many
Welcome.
I'm glad you're shortening both ends of the bed. There was a guy near my house when I was a kid that had a 58 with a "1/2 short" bed. He'd cut the rear of the bed but left the front at stock length. It just looked wrong.
1project2many is offline   Reply With Quote
Old 02-09-2015, 03:22 PM   #7
Jr55
Hi, thanks. One thing Iv come to understand is there must have been 3 different lengths of beds, I only shortened the 9.25 inches from the front.?
Old 02-09-2015, 03:25 PM   #8
59chev
59chev's Avatar
55-57 Longbed stepsides where only longer in front of the fender. 58-59 Longbed stepsides are longer in front and behind the fender. The shortbeds are the same length from 55-87.
Old 02-09-2015, 03:52 PM   #9
1-ton of fun
polishing a turd
1-ton of fun's Avatar
nice job on the frame shortening. i'm glad to see some people still know how to build things properly (not directed to anyone here)
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512
53 buick special - straight 8 sled - blow through turbo
47 gmc - flatbed hot rod build
99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van'
1-ton of fun is offline   Reply With Quote
Old 02-10-2015, 12:25 AM   #10
Jr55
Thanks, plan is to shorten the driveshaft and get the brakes working then drive it once before taking it apart and start on the rust repair . When I got it last summer I put a battery in it and a set of points and with a little fuel down the carburator it started. It hasn't run in 30 odd years. Plans are to do a full restoration with ifs suspension and a v8.
