Closed Thread
Old 02-09-2015, 12:59 AM   #526
1971 GMC SHORTY
1971 GMC SHORTY's Avatar
Re: What did you do to your truck today part III
Originally Posted by jayoldschool View Post
It might be the pic, but that first 90 on the rear line looks kinked to me.
Went to Moms Today order Rust Stuff Took Picture of Rear Brake Line!!! Looks Good Right?
1966 GMC K25 V6 351E Original Utility Truck
2000 C3500 Hot Rod Utility Truck
2003 ROAD KING 100th 124ci 6 Speed
145CI M/P Pro Street FXR
2002 FXDP
2007 2500HD DURAMAX. DD
Studio Teamsters / Mechanic
Retired GM Master Tech 20 Years
Retired Ford Tech 15 Years
1971 GMC SHORTY is offline
Old 02-09-2015, 04:02 PM   #527
jayoldschool
Moderator
For sure, that line is mint. Nice work!
jayoldschool is offline
Old 02-09-2015, 08:26 PM   #528
LVPhotos
LVPhotos's Avatar
Weld, grind, weld, grind...
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline
Old 02-11-2015, 12:37 PM   #529
earl84
Originally Posted by Turtleman View Post
Great score eral84,, I'd be interested in any Mod's you'll have to do for it to fit in the C-10
Got the '89 C10 60/40 split bench seat installed yesterday! Soooo much more comfortable than the old stock bench with worn out foam. The center console/armrest is great as well. It fit perfectly. The forward outside holes, 1 on each side lined up, then had to drill 3 new holes for each side. The passenger side frame fit to the right of the trans hump. The passenger side inner frame under the console mounted on top of the trans hump, no spacers, no mods , just new holes. Took a total of less than 2 hours, with lots of measuring, and double/triple checking.
earl84 is offline
Old 02-11-2015, 02:44 PM   #530
CRGRS 66
CRGRS 66's Avatar
Nice!
Craigerrr
My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709
CRGRS 66 is offline
Old 02-11-2015, 06:27 PM   #531
Chevy Fleetside
Chevy Fleetside's Avatar
Is that really out of an 89? It looks more like a 99. Just askin..
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline
Old 02-11-2015, 06:31 PM   #532
Chevy Fleetside
I swapped out that steering wheel every loved so much and installed my old wheel back. It will do for now untill I really make up my mind on what I want.
Old 02-11-2015, 07:16 PM   #533
Slow Build
Slow Build's Avatar
Your right John. That seat wasn't available until 1995. Great seat. I'll be looking for that type seat when (or if) I get to that point but I'm going to try to use the back seat headrests (haven't tested to see if they fit yet) just because they're smaller and won't show as much through the BBW.
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline
Old 02-11-2015, 08:03 PM   #534
dwcardfan
dwcardfan's Avatar
Sprayed some paint on the roof.
dwcardfan is offline
Old 02-11-2015, 09:06 PM   #535
rickywideglide
rickywideglide's Avatar
yea looks like mid to late 1990s,had same one in my 64 ,then switched to 91 for a little more room
rickywideglide is offline
Old 02-11-2015, 09:06 PM   #536
rudyyloverboiii
finally got my wide whites!
rudyyloverboiii is offline
Old 02-11-2015, 09:15 PM   #537
Slow Build
Slow Build's Avatar
How much more legroom do you think you gained by using the 91 seat? I know the seat backs are a little thinner on the 88-94 bench seat. I'm 6'-4" so I like legroom.
Past GM Trucks:
Old 02-11-2015, 09:37 PM   #538
rickywideglide
hard to say,im 6'5" with the later 90s seat felt like i was all up on the steering wheel, switching to the 91 seat like you said is diffently thinner on seat back which got me off the wheel.so maybe a inch or so,ive seen where some guys cut a inch out of seat bracket as well to gain some room(88-94 seat)
Old 02-12-2015, 07:49 PM   #539
earl84
You guys are al probably right, I just went with what the guy I bought it from said. So, sorry for bad info that might throw someone off, but I am almost positive it's from a pre-1999, from the research I did, after that they took more work to install. This one was quite easy to install, and is VERY comfortable. I did lose about an inch of legroom. I had previously installed a tilt column, and when I did that I pushed it forward as far as I could, so I am quite comfortable with the steering wheel position.
earl84 is offline
Old 02-13-2015, 04:50 PM   #540
Chevy Fleetside
I loaded up the bike and the dog and headed for the hills.
Old 02-14-2015, 09:32 AM   #541
donthekawguy
donthekawguy's Avatar
Replaced the leaking water neck and looked at the header bolts but got too lazy to change the gaskets. lol Gassed her up and shortened the life of the tires.
66 shorty
donthekawguy is offline
Old 02-14-2015, 03:51 PM   #542
LVPhotos
LVPhotos's Avatar
Went a little too far. Pulled water pump, balancer, cover. Since I had headers and plugs out I figured I would find true TDC. Now all clean, painted and polished. Also posted parts in classifieds.
LVPhotos is offline
Old 02-14-2015, 05:54 PM   #543
Grizz1963
Grizz1963's Avatar
MINI ROAD TRIP !!
Well, it was a trip, and it was by road.
Got contacted by our import agent this week to say our bits had landed and been unpacked. Duties and shipping to be paid on collection.
So Martin and I set off early, also to meet up with Paul Y en-route before collecting our parts from Ron.
Spent about 90 minutes with Paul talking truck, especially his plans for Woody.
As always we spent quite a long time chatting cars, imports and the state of the nation before collecting our bits and setting off.
Managed to negotiate Ron out of a cool plate for my collection, from his wall.
On the way back one of the landmarks I always miss out on photographing was this pub.
One of the items we collected was our 67-72 rear bumpers.
NOW QUESTION TIME.... ???
I never realized that there were more holes in them than the two bumper bolt holes.
On top of that, I feel a bit pisssed off as there "extra" holes let down the chrome and the show...... It looks like the extra hole was laser cut, and the chrome around this hole is rubbish, or non existent.
Any advice on my perception here happily accepted.
This is the extra hole, and also there are two notches in the bottom edge on each side of the number plate recess.
Up close.
My total haul for today, included a load of window rubbers, and a set of door instep stainless strips as well as new door hinge pins.
Tabitha for some reason attached the carpet box with a vengeance.
After Martin left to go see to the dogs and Amanda, possibly in that order, I went to the garage to carry on figuring out the tow bar.
Managed to get to a point where I drilled more holes and cut some metal away.
Next up welding tomorrow.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline
Old 02-14-2015, 06:07 PM   #544
Lugnutz65
Lugnutz65's Avatar
Originally Posted by Grizz1963 View Post
MINI ROAD TRIP !!
Up close.
Is that an original 60-66 rear bumper? The extra holes do seem out of place.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline
Old 02-14-2015, 06:45 PM   #545
Grizz1963
Grizz1963's Avatar
Hi mate
There are little notches cut out on both sides too, that you can just see in the one pic.
This is the receipt, I think it shows clearly what we ordered.
Old 02-14-2015, 11:02 PM   #546
4shongo
I installed some sun visors(didn't even have one for the passenger side) and a nice set of aluminum sail panels (polished them up a little) on my 66 service truck today. Got lucky on the visors, they are period correct and match my seat perfectly. My upholstery guy happened to have this matching set on his shelf lying around for years.
4shongo is offline
Old 02-15-2015, 12:32 AM   #547
Lugnutz65
Lugnutz65's Avatar
Hi mate
Ok, I see you bought Fleetside/Suburban/Blazer rear bumpers for 67-72. I had heard they would fit the 63-66 Fleetsides.
Old 02-15-2015, 12:35 AM   #548
TJ's Chevy
TJ's Chevy's Avatar
Got it registered and insured( couple days ago) and today....drove drove and drove it again!
TJ's Chevy is offline
Old 02-15-2015, 11:21 AM   #549
CRGRS 66
CRGRS 66's Avatar
Big time Congrats TJ!!!
Craigerrr
CRGRS 66 is offline
Old 02-15-2015, 06:22 PM   #550
Grizz1963
Grizz1963's Avatar
Bumper and removable tow bar fitted.
Removable number plate fitting.
So all in a good weekend.
Closed Thread
