Old 02-10-2015, 11:31 AM   #1
inkslinger1964
front clip
1964 c10 stepside with 283. I would really like to convert my front drum brakes to disk brakes. would it be better to buy a conversion kit, or swap the entire front clip with a newer model. if so what year models with disk brakes would bolt right up to my 64.
inkslinger1964 is offline   Reply With Quote
Old 02-10-2015, 12:38 PM   #2
urmyboyblue
Re: front clip
73-87 C10 front brakes are a direct interchange if you swap everything between the ball joints (including ball joints) or you can replace the entire front crossmember and suspension. See the FAQ section for some threads on this.
urmyboyblue is offline   Reply With Quote
Old 02-10-2015, 06:49 PM   #3
Chevy Fleetside
Chevy Fleetside's Avatar
Re: front clip
You can leave the 64 crossmember in and just swap out all the later model parts. The only differnce in the two crossmembers are the later model ones use a larger u bolt for the lower control arm. You can drill out the 64 crossmemer and use the larger u bolts. You will also have to redrill for the idler arm.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
