02-10-2015, 04:59 PM | #1 |
maintenance mod
I hear all these terms; Hot Rod, rat rod, restomod...none of these seem to fit my plan, or my budget.
So, I have coined My own phrase. Maintenance mod. What is this? Well, anything that needs fixed, it's fixed. While it's apart, it gets completely gone through and rebuilt ( if needed). If it needs upgraded, it gets upgraded. Systematically throughout the truck until the entire thing has been "maintenanced" back to dependability. how is this different? First, I keep driving the truck. This fact is paramount.I do not want to tear something apart, that would keep me from driving the truck for an extended amount of time.I truly enjoy driving the truck. Second, (for now) I will only focus my time and money on things that make the truck more dependable, more solid, or more enjoyable to drive.ie. handles better, runs better, doesn't leak this or that, quieter, smoother, etc. I will spend zero time on exterior aesthetics. Does this make it a patina truck, or a rat rod? No. I fully intend on painting in the truck... Someday But Why tear apart a perfectly enjoyable truck (for paint), and not be able to enjoy driving it. I don't have the time or budget for a good paint job right now.so, my theory is, AFTER everything is fixed, and the truck is completely sound and dependable, I can just drive it down to have a decent paint job put on it. In the meantime, it's making me smile, every day I get to drive it. it's like I always say about my old greasy Harley, "you polish yours, I'm riding mine." |
02-10-2015, 05:04 PM | #2 |
Re: maintenance mod
I don't know if its a patina or rat rod but I like the way you look at it. If over restored, expensive paint, and the like would you really drive it as much or would you be afraid of every little scratch or ding?
1971 Longbed BB Cheyenne Super 1972 Longbed SB Cheyenne Super 1972 Longbed Highlander Custom Deluxe 1975 K5 4x4 full convertible Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=645165 Greg Smyrna TN |
02-10-2015, 05:31 PM | #3 |
Re: maintenance mod
I like the idea. I think mine falls under that category as well. I've done a lot of work to it, but no frame-off restoration. Just constant improvement. I had it painted professionally a few years back, it looked great, but as time went on, I watched the paint job slowly deteriorate. I realized what I had, a truck built to drive. So I sanded it all down again, did minimal body work and sprayed it myself. Now I just touch up areas with a rattle can. I don't need anything more than that. I like seeing nature take it over, it has a personality now, character. Doing mechanical improvements to make it handle and perform interests me more. It's a sleeper.
My project: http://67-72chevytrucks.com/vboard/s...d.php?t=651651 |
02-10-2015, 05:46 PM | #4 |
Re: maintenance mod
or maybe reliable mod, driver mod.
Built not bought! My dad always tried to convince me HEI was pointless! Welding is a lot like sex, you don't have to be great with the rod as long as you thoroughly prep the surface and your good at grinding My build : 68 C10 Short Bed Conversion |
02-10-2015, 06:35 PM | #5 |
Re: maintenance mod
I like your idea, and my 72 sort of falls into that category. However, I will be eventually replacing some of the body (bed, driver door, rusty parts in the cab). But it's meant to be a daily driver, not a show truck.
72 K2500 Sierra Longbed Wideside 350/TH350/NP205 66 Plymouth Barracuda 225 Slant6 |
02-10-2015, 06:46 PM | #6 |
Re: maintenance mod
I too like the way you address the truck. If it needs fixed, clean fix and fix things around it.
Though mine has newer paint on it, trucks are trucks to me... I drive it and use it as such.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 |
02-10-2015, 07:01 PM | #7 | |
Re: maintenance mod
I will spot paint the repaired areas original blue. No primer spots on my truck. |
02-11-2015, 08:35 PM | #8 |
Re: maintenance mod
Same catagory but ready to start the body work stage shortly, thats why i called my thread "Rat repair"
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
02-12-2015, 12:16 AM | #9 |
Re: maintenance mod
sounds like ole dollor , a daily driver that I work on and fix things all the time . keep it safe and running...... and try and make it look better when I can.
