Rear Axle Question
Idk if I'm blind or if the forum doesn't exist, but I have a question about a 76 2wd Blazer rear end. Would anyone know what the gear ratio for those typically was? It's a 12 bolt. I was looking in LMC's catalog but there was a handful of options.
Worst case scenario, I pop the cover, but I'd prefer that I didn't have to if at all possible. Thanks! |
Re: Rear Axle Question
The most common gear ratio I have seen for the 73 to 78 C-series with the 12 bolt axle was 3:42's but it really depends on engine, trans, and option levels. Plus if it was special ordered it could be anything.
You don't really need to open it up. Assuming nobody went in it and changed the ring and pinion there is a axle code you can get off the housing. It is on the right axle tube facing towards the front of the vehicle and generally a few inches out from the cast center section. The code will have 2 letters and I think 5 numbers. The 2 letters will tell you the gear ratio and if it was posi or not, the numbers are the built date. There are charts all over the internet for determining the letter code. |
You can also place a floor jack under the center section and lift both tires, turn the tire one full revolution and count how many turns the driveshaft makes.
Just under 3 1/2 turns + 3.42 (barely under ), just over 3 1/2 turns = 3.55 ( barely over ), right at 3 turns = 3.08, 3 3/4 turns = 3.73, ...you get the msg. Hope this helps.
Tim K. 84 K30 srw Silverado 454 auto 85 C20 350 C6P auto flatbed 94 K1500 lifted shortbed 350 4 bbl NV4500 Last edited by 68post; 02-11-2015 at 09:45 PM. Reason: kant spel |
Thanks guys! I'll check it out after work today.
Powertrain charts and link to GM Heritage Center generic info packet attached.
3.73 was considered standard; 3.07 or 4.11 were also available optionally. K https://www.gmheritagecenter.com/doc..._Full-Size.pdf
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
