Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 02-12-2015, 01:06 AM   #1
SFBay69
Quick solution for single sub in a box with an amp.
In a quick and dirty fashion:
I'm very tall and the seat will be all the way back. I moved the tank to under the bed. I don't need to upset neighbors or make dogs' ears bleed. I have an updated AM/FM original radio with 180W to power 2 3" dash speakers and 2 5" kick panel speakers. Is there a single sub (sealed), in a box, with an attached amp out there for a little low end upgrade? It's a 69 C/10 shortbed. Again nothing crazy on pounding bass, just a fuller sound. Price isn't a huge concern but the truck is mild and clean. I don't need the stereo to be the biggest feature. Thank you all in advance.
SFBay69 is offline   Reply With Quote
Old 02-12-2015, 03:13 AM   #2
Andy4639
Old member
Andy4639's Avatar
Lightbulb Re: Quick solution for single sub in a box with an amp.
I would try something like this. You could even put one on each side of the cab if you wanted.
https://www.mtx.com/car-audio-built-...oofer-packages
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 02-16-2015, 11:28 PM   #3
mattcrp1
mattcrp1's Avatar
Someone else had a similar question and posted this: http://www.retrosound.com/product-p/hot-sub-8100.htm , I have no experience with this product but it sure looked cool.
My Chevy habit is paid for by Ford diesels...
Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355
Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748
Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974
IG mattcrp1
mattcrp1 is offline   Reply With Quote
Old 02-16-2015, 11:29 PM   #4
mattcrp1
mattcrp1's Avatar
Check a few posts down and some of the other members had some good ideas.
IG mattcrp1
Old 02-17-2015, 12:56 AM   #5
Henney
I'm going with this. Fits just about anywhere and a small mono sub runs it great.
http://www.jlaudio.com/cs112lg-tw3-c...-systems-93305
Henney is offline   Reply With Quote
Old 02-17-2015, 08:49 AM   #6
Mike C
Mike C's Avatar
Crutchfield has several different powered subs that should fit easily.
Link to powered subs, sorted by price. Several flat 8's that should work.
http://www.crutchfield.com/g_51000/P...rs.html?tp=114
I just did the stereo in my short step with a Kicker 8" sub under the seat next to a Kicker 400.4 amp (front two channels drive mids/tweets and rear is bridged mono into the sub.) Both fit under the seat well in my truck, but you would need to do some tape measure engineering to make sure yours would have sufficient space. Mine sounds awesome with 5 1/4" mounted in the door panels and the single sub.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
