Old 02-12-2015, 10:24 AM   #1
jomatt20
jomatt20's Avatar
72 c15 motor mount confusion
Hi guys, was curious if you guys could post some images of your 350 motor mount I'm just confused on the motor mount the parts store gave me compared to what I think goes on there.
jomatt20 is offline   Reply With Quote
Old 02-12-2015, 01:01 PM   #2
kwmech
Re: 72 c15 motor mount confusion
Should be a clam shell style mount, similar to the later models
Old 02-12-2015, 02:33 PM   #3
jomatt20
jomatt20's Avatar
[QUOTE=kwmech;7045316]Should be a clam shell style mount, similar to the later models
I attached some pictures
Old 02-12-2015, 03:30 PM   #4
JointTech
JointTech's Avatar
the one you are holding is the earlier style. The clamshell is the newer one.
72 C20 Long Bed
SB350 TH400 14 bolt rear end
Extremely boring build thread
JointTech is offline   Reply With Quote
Old 02-12-2015, 03:31 PM   #5
michael bustamante
michael bustamante's Avatar
yup thats 67-71
1967custom
michael bustamante is offline   Reply With Quote
Old 02-12-2015, 05:21 PM   #6
jomatt20
jomatt20's Avatar
Should this work on my 72? Went back to the parts store and said this is what fits the 72.
Old 02-12-2015, 05:26 PM   #7
JointTech
JointTech's Avatar
NO. that's for the earlier models. You need the clamshell style.
From what I have found you can ask for 73+ motor mounts but the word on the street is they are slightly different. I had to beat, pry and plead to get the motor to drop back in.
heres a thread that will make it clear as mud
http://67-72chevytrucks.com/vboard/s...d.php?t=634402
take a pic of your current mount and we can tell you which you have.
72 C20 Long Bed
Old 02-12-2015, 06:18 PM   #8
70 CST 4X4
Have A Nice Day!
70 CST 4X4's Avatar
In 1972 the small blocks still used a mount like the one pictured in #3 post. In 1972 the big blocks were mounted using a clam shell style mount like the one pictured in the above link.
1970 CST K10 350/350/205
Short Bed - Fleetside
Tach-Tilt-A/C-Tow Hooks
Front & Rear Disc Brakes
Front & Rear Posi 3.73 Gears
30 Gallon Stainless Fuel Tank
SOLD 01/18 !!!!!
2007 2500 HD Classic Crew Cab LT2 4X4 Duramax LBZ
70 CST 4X4 is offline   Reply With Quote
Old 02-12-2015, 08:34 PM   #9
kwmech
I've seen small blocks with clams, even on the spid
Old 02-12-2015, 09:21 PM   #10
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
My 1972 GMC C1500 has the exact same ones as in post #3. SBC 350 from the factory.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 02-13-2015, 09:57 AM   #11
67c10rustbuket
67c10rustbuket's Avatar
I think you guys are confusing the issue. The OP said an SBC 350,, not a BBC '72 only clam. The mount pictured bolts to the block with three bolts then it sets on the stands and one bolt retains the mount to the stands from the underside. I can take a pic this afternoon if needed. What frame stands/perches are you working with jomatt?
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
