Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 02-01-2015, 01:44 PM   #1
Senorx
Senorx's Avatar
Get Home Emergency Tools
I've owned my 71 K5 for a little over a year. I'm still a newbie and trying to learn as much as possible about my truck. This weekend I learned that I should have had an Emergency Get Home Tool kit while I was stalled on the side of the road.
What would you put inside an Emergency Get Home Tool box? I have .50 cal ammo box, which measures 11L x 5.5W x 7H that I will be carrying in my truck from now on. This is what I'll be packing so far. Any suggestions? Constructive criticism? Dos and dont's?
1) Standard wrench set (5/16-1in)
2) Vise Grips (small and large)
3) Screw drivers (Phillips and Flat Head)
4) Duct tape
5) Electrical tape
6) Loctite
7) Fuses
What else would you have? Socket wrench/sockets?
Senorx is offline   Reply With Quote
Old 02-01-2015, 02:22 PM   #2
_Ogre
_Ogre's Avatar
Re: Get Home Emergency Tools
make it reliable
i don't carry any tools in 58 truk
not even a jack
shop air compressor timer
Old 02-01-2015, 02:32 PM   #3
Senorx
Senorx's Avatar
Originally Posted by _Ogre View Post
make it reliable
not even a jack
I hear that. She's been reliable so far, but I ran out of luck this weekend. I'm embarassed to say what it was, but I'll man up. It was totally my own fault. I purchased a new battery for it. My truck uses side posts. The PO used actual bolts and not actual battery side post bolts. The bolts the PO used were to long for the battery. I overtightened them and pierced the battey. Drove around all day with acid spilling everywhere until the battery took a dump. I walked to Autozone, replaced battery, bought correct posts and had to purchase a few tools to get the job done. Hence the Get Home Tool Chest idea.
Old 02-01-2015, 07:53 PM   #4
BruthaMan
US Army Veteran
BruthaMan's Avatar
Was going to mount a .50 cal box under the hood, but instead opted to use a water-proof military bag that you can pick up from any surplus store.
Have socket set, crescent, multiple pliers, some spare wire (in case I need to get my McGuyver groove on!), knife, duct tape, hand warmers, rubber gloves, work gloves, rope and tow strap with hooks. Also have a spare ignition module and coil.
The only time I ever broke down, was when the ignition coil went out. On the highway, 15 miles from no where, about 140 miles from home.
When I go on longer trips (up to 400 miles), I usually carry a blanket, water and some snacks for emergency only.
BruthaMan is offline   Reply With Quote
Old 02-02-2015, 12:54 AM   #5
53Sparky
53Sparky's Avatar
I would add a basic set of wire strippers and some wire nuts. That's a quick way to fix an electrical issue on the roadside until you can do it right at home.
We'll burn that bridge when we get there
My current project: Rust Therapy 62 C10
Numbers 6:24-26
53Sparky is offline   Reply With Quote
Old 02-02-2015, 09:15 AM   #6
cg285
A a a, (alright since this software doesn't like capital letters - triple "A")
cg285 is offline   Reply With Quote
Old 02-02-2015, 10:01 AM   #7
Senorx
Senorx's Avatar
Didn't think about that. I'll add it to the list. Thanks.
Old 02-02-2015, 10:09 AM   #8
Cash3481
Loves all GMC trucks
Cash3481's Avatar
I've learned on here (from others) about about fire so I suggest having a fire extinguisher. Being that I spent 24 years in the military, I believe its a staple for the vehicle.
This is a good reminder for me, as the wife and daughters gall ot new cars and I haven't replaced the ones in their cars.
P.S. Make sure you neutralize and rinse off the battery acid.
Mike
If your helping someone and expecting something in return... your doing business not kindness!
Cash3481 is offline   Reply With Quote
Old 02-04-2015, 11:03 PM   #9
motornut
78K & 79C Jimmys
motornut's Avatar
oil anti freeze and a 5/16 wrench,a small air chuck,some places leave the hose out and remove the end.
or you show up and the last customer took it....
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 02-12-2015, 01:13 PM   #10
fun in dirt
fun in dirt's Avatar
Adjustable wrench, pocket knife (if you don't usually carry one) & several big zip ties.
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432
'85 K30 "Big Nassy"
[B]'85 C10 [B] "Corpse"
'01 2500 Suburban ...party wagon & tow truck
'06 Silverado SS...DD
'06 C1500 WT...DD
'07 Classic C1500 WT...DD
Built & sold cause can't keep 'em all:
'72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190
'55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938
'69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541
'86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619
fun in dirt is offline   Reply With Quote
Old 02-14-2015, 08:35 PM   #11
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
No need for Loc-tite in an emergency kit.
Huck some zip-ties, some kind of knife, baling wire and cutters, oh... and I took an old ball peen hammer and cut the handle short so it would fit in an ammo box as well. Never know when you'll need a hammer.
Oh... box of band-aids too!
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 02-16-2015, 11:21 AM   #12
Senorx
Senorx's Avatar
Stopping by at Harbor Freight today for some tools that I won't mind if they get stolen from the truck.
Old 07-03-2015, 12:23 PM   #13
ranger danger
ranger danger's Avatar
Spend just a little more and get some Craftsman. Busted knuckles are worse than no or stolen tools!
1969 C20 Suburban "Rez Dog"
Rebuild America one testicle at a time.
US Army 1977-1979 12B Combat Engineer
US Navy 1979-1983 Gunners Mate Guns (GMG)
NRA Life Member
Unrestrained Children in back seats cause Accidents.
Unrestrained Accidents in back seats cause Children.
ranger danger is offline   Reply With Quote
Old 07-03-2015, 03:08 PM   #14
cdowns
cdowns's Avatar
My get home emergency kit consists of a fully charged cell phone and a visa card with a 25000 credit limit
Old 07-04-2015, 02:01 AM   #15
PeterHall
Jumper Cables
Band Aids
Tools to change to a spare tire
Oil
Water
MRE or smaller food stuffs
Fire Extinguisher
PeterHall is offline   Reply With Quote
Old 07-04-2015, 09:09 PM   #16
In The Ten Ring
You guys should see what I carry just in my car!
First aid kit
Road flares
Reflective triangle (grabbed the trucker type set the other day when the wrecker pulled one off and forgot to pick those up)
Tow strap
2 quarts of oil
Water (for radiator)
2 screw jacks
Spare
Funnel
Black tape
Crow bar
Extra 1/2" ratchet (for lug nuts)
Cheater bar
Axe
Jumper cables
Rugs and towels
Rope
CO2 extinguisher
ABC extinguisher
I never travel (not even off my property) without 1 or 2 handguns and spare ammo, pepper spray, tactical flashlight, knife.....and yes I've had to use all of those at one point or another.
I have been wondering how I am going to carry all of that in my truck. Time to move the gas tank? LOL
If I were you, I'd at least put a 3/8 inch socket set into your ammo box.
In The Ten Ring is offline   Reply With Quote
Old 07-05-2015, 10:03 AM   #17
ranger danger
My kit is fairly in depth as well. This is what I carry when I go camping. Most of this I carry all the time.
Cell phone
credit card
knife
good flash light and spare batteries
first aid kit (a VERY good one Maxpedition)
Maxpedition bug-out pack
Fire extinguisher
fire starter and striker
Trash bags (always leave nature a little better than you found it!)
spare tire and 4 way tire iron
high lift jack
bottle jack
Rope
plastic tarp
Jumper cables
oil (1 gallon)
duct tape
bailing wire
zip straps of various sizes
spare distributor, wires, coil and plugs
hoses and belts
pry bar
shovel
blanket
blue paper towels and orange hand cleaner
water and mre's
quart of vodka
NEVER EVER WITHOUT A GUN AND SPARE AMMO!!! Usually a 1911
Electrical kit includes
Multi-meter
test light
wire of various sizes
butt connectors
strippers and cutters
Electric tape
fuses
light bulbs in film canister
Tool bag
2 of each type of screw drivers
hammer
open end wrenches from 1/4 to 7/8 (2 each of 7/16 through 9/16)
3/8 socket set with same size's as wrenches in both shallow and deep in 6 point with extensions
razor knife and spare blades
allen wrenches
spare nuts, bolts and washers in various sizes
JB weld
tin snips
spare u-joint with new u-bolts
I'm sure I'v forgotten something.
NRA Life Member
