![]() Join Date: Jan 2015
Bench seat adjustment missing a part?
I believe there should be a spring on the passenger side to hold this adjustment pin in a locked position once the tension is removed. I'm not sure that the adjustment rod is routed correctly because it seems rather loose.
1970 C20 350/TH350, LB God Bless our Troops ![]() |
Re: Bench seat adjustment missing a part?
I can't comment on the spring. I used this thread to modify my seat because my rod was all bent and didn't work right http://67-72chevytrucks.com/vboard/s...&postcount=263
![]() Join Date: Sep 2012
Here are a few pics from a original seat from a 71 c10.
Pics are of passenger side adjuster. Brian
1971 c10 custom deluxe fleetside swb LS3 w/BTR stage IV cam,4L85E w/3600 stall 67-72chevytrucks.com/vboard/showthread.php?t=558024 |
clemsonteg great fix, thanks!
brian1971 that's the image I needed, thanks! I believe the seat adjustment rod connects under the seat buy running through that metal clip in the middle which is why it's so loose now. Seems a strange way to do it. I may be missing something. ![]()
found this on the site. used to take up slack on the rod..
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. |
#6 | |
The Older Generation
One of mine had a "S" hook that hooked on the rod and on the back edge of the seat. Here is a scan from a parts book. LockDoc
Joe,
That one is from my Blue '67 Chevy. It works great with the "Z" bent connector rod but I think it would allow too much movement on the straight connector rod and wouldn't allow the passengers side to release. LockDoc
Great info, thanks!
Yeah Leon, I did a search but couldn't find the right one. I knew I saw it somewhere before..
Great info and pics. Having the same problem putting mine together.
Problem is now solved . Thanks |
