Old 02-11-2015, 08:14 PM   #1
Jolseen
What kind of MPG's are you guys getting?
I want to do the LS1 swap in my 71 c10, and just want to get an idea of the MPG's, cost and power that comes with the ls1 swap.
Jolseen is offline   Reply With Quote
Old 02-11-2015, 09:31 PM   #2
69sinker
69sinker's Avatar
Re: What kind of MPG's are you guys getting?
I've just driven 1000+ miles (95% highway) in the last 3 days and have averaged 18 mpg.
I have a stock 5.7LS1, 4l60e and 3:73 gears. Average highway speed was 70-80 mph. The best fuel mileage I have ever got is 20 and worst is 16. The old 350 4bbl/ 350 turbo I swapped out averaged 11 and probably had half the hp. I've never met anyone who has regretted an LS swap. Go for it! Dave
My 69 cst lwb 2wd LS1 swap 5.7/4L60e build
http://67-72chevytrucks.com/vboard/s...d.php?t=589869
69sinker is offline   Reply With Quote
Old 02-11-2015, 09:51 PM   #3
Andy4639
Old member
Andy4639's Avatar
Talking Re: What kind of MPG's are you guys getting?
Mine is a 6.0LS 4L80e with 4:10 gears. I got 16-18MPG last year on the power tour. Depending on if I had the AC on and how much traffic we sat in!
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 02-11-2015, 09:58 PM   #4
TwinsSpeedShop
5.3/4l60e 228r cam and 3k stall converter. I get 16 in town driving and havent really checked hwy. About to do my T56 swap and hope to get closer to 20. Like stated above, i have never met anyone that regretted the swap. If you have to put money into your current setup, put it towards an LS swap of any sorts and you will thank yourself as soon as you take that first test drive.
Good luck with it
TwinsSpeedShop is offline   Reply With Quote
Old 02-11-2015, 11:07 PM   #5
Angryman117
stock 5.3 in 89 chevy 4x4 with nv4500 and I get 18-20 highway and city driving.
Angryman117's
47 Chevy Build
89 Silverado Z71 LS Swap (sold)
Angryman117 is offline   Reply With Quote
Old 02-12-2015, 01:06 AM   #6
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
about 19 hwy through a heavy drivetrain. 14-16 city. Within 1-2mpg as my dd Blazer (s15 style)
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 02-12-2015, 07:53 AM   #7
TwinsSpeedShop
as always, its obvious that manual trans really helps with the MPG's
Old 02-12-2015, 11:07 AM   #8
Wasted Income
Boosted Member
Wasted Income's Avatar
I never calculate it.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 02-12-2015, 06:53 PM   #9
solidaxel
solidaxel's Avatar
I am using Torque Pro and the speed and tach are accurate, so I believe the fuel mileage to be also, and it says I am getting 20 to 22 mpg 5.3/4L60E and 3;42
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 02-13-2015, 01:35 AM   #10
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Make sure its actually calculating based on the mileage. Lots of the scanners and apps use the injector pulse and guestimate. While in theory it could be accurate, mine never was.
Old 02-13-2015, 03:15 AM   #11
ls1nova71
ls1nova71's Avatar
I check my mileage on just about every fill up, I'm kind of OCD like that! Over the last 15k miles ive had the swap done on my truck, I almost always get 17mpg. Thats with a 2004 5.3/4l60e in my 71 swb with stock size tires and 3.08 gears. I was hoping it would get closer to 20 since I hear people say they get that, but mine never does. Even on long highway trips with the cruise set it only does slightly better.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 02-13-2015, 08:00 AM   #12
Marty68
ls1nova71, do you think your mpg would be better if you had a lower rear gear? say 3.73 or 3.42 is your truck at too low an rpm at 70 and not up in its power range?
i have read that 3.08s with od arent the best. i also have 3.08s and am curious what to expect.
Marty68 is offline   Reply With Quote
Old 02-13-2015, 08:41 AM   #13
A1971Blazer
A1971Blazer's Avatar
I've been kicking this around as well. I will be running a stock LS1/4L60E going in my '71 K5.
From the research I've done and advise from other members here......I concluded the same thing, the MPG will be the best if the engine is operating close to it's power range.
By observing various speed/RPM ranges on different vehicles, most seem to be geared to run at around 1700-1900 RPM at 65 MPH.
So by using a gear ratio calculator, I have determined that if I run a 33" tire with the 4L60E overdrive ratio of .7:1........ I will run 4.11 gears. That should give it a lot of low end grunt as well?
go here and plug in your parameters.
http://www.4lo.com/calc/gearratio.php
A1971Blazer is offline   Reply With Quote
Old 02-13-2015, 10:10 AM   #14
ls1nova71
ls1nova71's Avatar
I have thought about it, and think it might help some but not sure how much. . All the other trucks ive built have had 3:73's, but I didnt check the mileage on them as much since I didn't drive them as much either. I would have already swapped it out if my truck didnt have a nice factory installed posi!(There's a problem to have, right? LOL) But on the highway I figured it would do really well, but it just doesnt do as good as I had hoped. It runs down the highway great and doesnt feel like its being bogged down by the tall gear.
Old 02-14-2015, 02:07 PM   #15
lynnfield
The Waco Kid
lynnfield's Avatar
Just got mine on the road, licensed, taged, and inspected with about 200 miles so far. I haven't figured the gas mileage, but holy crap what a difference. It's a lot of work and well worth it. Greg
You can check out what I did here: http://67-72chevytrucks.com/vboard/s...d.php?t=585899
lynnfield is offline   Reply With Quote
Old 02-14-2015, 05:11 PM   #16
cableguy0
Just as a test leave the transmission in 3rd gear instead of overdrive on the next trip or turn off overdrive if you have the ability. I bet you get better mileage. Your rpms are super low on the highway with that rear gear and an overdrive. These Ls engines seem to do best with 3.73's and overdrive.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 02-18-2015, 11:03 PM   #17
joeydurango
joeydurango's Avatar
'72 4x4, 2.5" lift, 33" tires, 5.3 LM7, 4L60E, 3.73 diff. I get 17-18 everywhere, in town, highway, 50mph or 75mph. Best of all, way fun!
1972 K10 Cheyenne Super | LWB, fleetside | 350/350/205 | KEEPER
1971 K10 Cheyenne | SWB, fleetside | LS Swap 5.3/4L60 | SOLD
1976 Trans Am | 400/4-spd | SOLD
1976 Trans Am | 455/4-spd | TOTALED
joeydurango is offline   Reply With Quote
Old 02-20-2015, 07:10 PM   #18
OneOffStroker
I got between 17-18 in my '69 Suburban with a 5.3/4L60E and 3.08 gears and 31x9.5-15 tires. I initially figured I'd be in the low 20's, but it was lower due to the high gears. At 55-60 mph it only ran at about 1300-1400 RPM. That was too low to make any reasonable torque, so the engine was working too hard and using too much fuel. With 3.73 gears, you can run 60-65 at 1700-1800 RPM, which would be perfect for cruising power and could probably get into the low 20's on the highway.
Either way, I didn't regret the swap. I actually kept the motor when I sold the Burb so that I can use it in my '57!!
1972 C10 "Shop Truck" Build - EFI, 5-speed, Posi, and Patina http://67-72chevytrucks.com/vboard/s...d.php?t=834292
1957 Chevy pickup - Twin Turbo 5.3/NV3500, Jag IFS & IRS, AirRide http://67-72chevytrucks.com/vboard/s...d.php?t=606987
Check me out on YouTube - "Tiny Garage Fabrication" http://www.youtube.com/oneoffstroker
OneOffStroker is offline   Reply With Quote
Old 02-21-2015, 10:54 PM   #19
85burb
85burb's Avatar
I have a 85 4x4 burb with 4.10 gears 33 inch bfg mud terrain 6.0 with cam, headers, tune with a 700r4 and I do not drive it nice. 2400 stall converter also does not help. I get around 12-13 mpg with mixed city highway. I am very happy with that. My tuner said I have about 425 at flywheel. It was a junk yard motor and for the total cost I have no idea. Worth every penny. Drive it to work every day.
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
Old 02-23-2015, 11:10 AM   #20
Clyde65
Clyde65's Avatar
I have a 4.8\4l60e with 3.73's in my 12 bolt. I do not drive mine daily, currently have the bed off for rebuild. But, I took it to Abilene a few months ago ( October I think) and went over 300 miles and got 21.3 MPG average. I probably got 23 on the way back, it seems Abilene is up hill to and down hill back. local driving I get around 17/18, mixed.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 02-23-2015, 02:23 PM   #21
Jolseen
I plan on using my truck as a daily driver.
