Old 02-13-2015, 10:15 AM   #1
no1udknow
no1udknow's Avatar
more 5 speed questions.
ok guys, every time I ask about a 5 speed I get random suggestions like "just get a t56" or "just buy a gear venders o/d" I really am just looking for a list of transmissions I can search for that are 5 speed with o/d
here's what I have so far:
t5
wct5
nv4500
nv3500
any other suggestions would be apreciated.
Built not bought!
My dad always tried to convince me HEI was pointless!
Welding is a lot like sex, you don't have to be great with the rod as long as you thoroughly prep the surface and your good at grinding
My build : 68 C10 Short Bed Conversion
no1udknow is offline   Reply With Quote
Old 02-13-2015, 10:43 AM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: more 5 speed questions.
Don't rule out the Jeep AX15 or the Toyota Supra Turbo R154 5 speeds.(basically the same trans) There is an adapter kit available to bolt them up to the Chevy bellhousings and they are supposed to be a pretty stout manual 5 speed. The adapter is a little pricey but it is milled and the kit comes with a GM bellhousing locator/throwout sleeve and mounting hardware.
http://www.novak-adapt.com/catalog/kit_gmax15.htm
I bought the kit and I have a Jeep 2WD AX15 trans, and I ended up putting it in my '34 Ford Coupe behind a Chevy 377 Stroker motor...
If you need a bell housing adapter ring get it from here:
http://www.dennymac.com/muncie-bell-...g-adapter-ring
The Novak one is $32.10 plus $15 shipping and the Dennymac one was $28 shipped when I bought mine.
LockDoc
Leon
Old 02-14-2015, 01:22 PM   #3
no1udknow
no1udknow's Avatar
Thanks lockdoc, thats pretty cheap for an adapter.
Built not bought!
Old 02-14-2015, 01:29 PM   #4
no1udknow
no1udknow's Avatar
LockDoc
So in your picture, what is the bell housing off of? a sm460/465?
Built not bought!
Old 02-14-2015, 01:36 PM   #5
LockDoc
LockDoc's Avatar
No problem. Not a bad price compared to some of the bell housings. It has some CNC work done to it.
The bell housing is off of a later Chevy V-8, it doesn't have the cross member mount bosses on it. Any Chevy bell housing will work with the adapter so you can mount it by the bell housing mounts or the rear trans. mount.
LockDoc
Leon
Old 02-14-2015, 04:07 PM   #6
Ugly71C20
Theres the old getrags too, the pre nv3500/nv4500. The 3500s are known to have some issues, but the 360s are ok I believe?
You can find late model nv3500s occasionally, they came behind the 4.8 vortecs. They are supposed to be pretty beefy. Stay away from the s10 stuff though cause the shifter is 8" back.
Ugly71C20 is offline   Reply With Quote
