Old 11-05-2014, 06:23 PM   #776
Xeen
Xeen's Avatar
Re: 1968 Chevrolet SWB Stepside Restomod
Originally Posted by jimbosprint View Post
Looks like a nice cab. What are you doing to clean up the surface rust?
Since I have a lot of surface area to cover I am using a Polycarbide disk on a side angle grinder to get the bulk of the surface rust, I still need to go back and hit all the cracks and crevices with a wire wheel to finish it off.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 11-05-2014, 06:31 PM   #777
Bennett68C10
Bennett68C10's Avatar
Nice looking cab Brian, wish I could have came across one that nice. I definitely wouldn't have wasted all the time on mine.
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 11-05-2014, 06:36 PM   #778
Xeen
Xeen's Avatar
Originally Posted by gdavis View Post
looks like you got your self a nice cab, to go along with the bed. good find man.
Thanks, yeah I lucked out on it, but like any other cab it has it's issues mostly because of the repair work, a lot of it was seam welded instead of butt welded so the cab corners will have to be cut out and replaced even though they are new, but the rest of it I can live with because it's all in the floor and will be covered up by carpet anyway.
Old 11-05-2014, 06:47 PM   #779
Xeen
Xeen's Avatar
One interesting thing to note, even though this truck is a 1972 it has no provision for a cargo lamp, which is fine by me because if it would have had one I was going to delete it anyway so less work for me.
Old 11-12-2014, 02:41 AM   #780
gdavis
gdavis's Avatar
Brian, it nothing that can't be fixed. at least you want have the issue with the doors not fitting right. Like mine. Like the other cab you have, George
Check out Patches
Cars I owned in the past.
1962 chev II Nova - 1965 Chevelle SS - (2)1966 Chevelle SS 1965 chev C10 57 belair chev
1967 Chevelle SS - 1969 Chevelle SS - 1972 Chevelle SS
1967 Buick electra 225 1995 Harley Davidson bager
What does not kill you will make you stronger
1968 c10 short wheel base stepper
gdavis is offline   Reply With Quote
Old 11-16-2014, 10:22 AM   #781
Xeen
Xeen's Avatar
Hey all:
It's officially winter here in Kansas so the tarps are on and the project is on hold until spring.
There probably wont be many updates this winter as all I will be doing is collecting parts and getting ready to hit it hard as soon as the weather turns nice again.
Old 11-16-2014, 02:43 PM   #782
SeTx67
SeTx67's Avatar
I don't know how you guys deal with all that cold weather. Y'all probably say the same about us and the heat down here. Can't wait to see you get back at it
67 SWB LS2/4l70e... http://67-72chevytrucks.com/vboard/s...d.php?t=587435
SeTx67 is offline   Reply With Quote
Old 11-17-2014, 01:39 AM   #783
gdavis
gdavis's Avatar
same here. I could not handle being shut up for all that time. I'll take the south. George
Check out Patches
Old 01-01-2015, 12:18 PM   #784
jkeating1
jkeating1's Avatar
Brian--I was reading a post of yours in GDavis' thread from a while back:
Originally Posted by Xeen View Post
"Im confused about one thing though, if the frame is a 68 why doesnt it have the dimple and why do you need spacers for the power steering box, mine is a 68 and has the dimple from the factory.
Are you sure its not a 67 frame?"
I don't have a 68 frame to look at, but is the "dimple" the same as would be on a '71-'72? I do have one each of those to look at.
I will be putting PS on my 67 (a new box supposedly for a 67). Do you have any input as to what hurdles I will encounter. How would you recommend dealing with them? I know PS was available on a '67, so there must be a factory-type solution.
JK
jkeating1 is offline   Reply With Quote
Old 01-01-2015, 01:12 PM   #785
gdavis
gdavis's Avatar
I found that the easiest way to solve any future issues is to just follow Brian's advice and just dimple the frame. I thought about just adding spacers, but where I was setting on my build was to dimple the frame. I don't know where you are with your build.
Check out Patches
Old 01-02-2015, 04:06 PM   #786
Xeen
Xeen's Avatar
If your frame doesn't have the dimple for the power steering just simply add it, done and done.
Old 01-02-2015, 07:37 PM   #787
jkeating1
jkeating1's Avatar
yeah--looks straightforward enough. I had to put a return hose on my 72 this afternoon, so I got a closer look at the dimple than I wanted.
JK
Old 01-03-2015, 02:32 AM   #788
gdavis
gdavis's Avatar
My frame was a 67 frame so I had to add the dimple. George
Check out Patches
Old 02-13-2015, 10:30 AM   #789
502ms
502ms's Avatar
Looking forward to you being able to drive yours. Sorry that the winter kills the progress.
Best Regards,
Leon M.
502ms is offline   Reply With Quote
Old 03-04-2015, 02:25 PM   #790
Xeen
Xeen's Avatar
Hey all;
It seems like it's been a long winter and boy am I itching to work on my pickup again, according to the weather man there are some nice days ahead this week and I plan to take advantage.
I haven't even looked at it in 3 months but I know there is a lot of work to do.
First things first, I need to finish removing the surface rust on the Cab and seal it back up since I didn't have time to get it all done before the weather got too cold.
I need to look underneath at the exterior cab floor and see what has been done to it and if it hasn't been done undercoat it.
Once that is all done I will see what I wan't to do next.
Old 03-16-2015, 11:38 PM   #791
gdavis
gdavis's Avatar
Hey all;
Tomorrow I hope to start the engine. If not tomorrow then Wednesday. I will post a video of it running, and good luck with your truck. I know it's been a long hard winter up there, George
Check out Patches
Old 04-13-2015, 07:49 PM   #792
SaltyC20
SaltyC20's Avatar
Just read through your build thread. Looks great. Hope its going well for you.
1968 Chevy C20
SaltyC20 is offline   Reply With Quote
Old 04-22-2015, 01:15 PM   #793
Xeen
Xeen's Avatar
Hey all;
It's spring and once again it's time to start working on the pickup.
Today I took the 72' front suspension crossmember down to the sandblaster, I will have it back in a few days.
I've decided to drop the pickup another couple inches and I'm looking at the CPP modular drop spindle and 2" drop blocks.
That will give me a total drop of 4/6 which combined with the front and rear sway bar and 4-wheel disk the pickup should handle and brake well.
Old 04-22-2015, 10:29 PM   #794
SeTx67
SeTx67's Avatar
Sounds like you have a good plan. Can't wait to see some progress
Old 04-23-2015, 03:40 PM   #795
gdavis
gdavis's Avatar
glad to head that you are back working on your truck. I understand that the weather is a problem. Here in Florida we work all year long. But we all can't leave in paradise.
Check out Patches
Old 04-24-2015, 12:51 PM   #796
Xeen
Xeen's Avatar
Hey all;
I ordered the CPP Modular drop spindles and stock disk brake brackets, 2" drop blocks and Trailing arm crossmember.
The front suspension crossmember is ready to be picked up from the Media Blaster so I will go get that today.
Old 04-24-2015, 02:03 PM   #797
Orangetonicclicc
Orangetonicclicc's Avatar
Hey all;
I got those modulars! But I have a 1.5" lowering blocks but I got those from POL!
Orangetonicclicc is offline   Reply With Quote
Old 04-25-2015, 02:45 PM   #798
Xeen
Xeen's Avatar
Hey all;
The media blaster did a good job on the front suspension crossmember and I needed to get some paint on it fast so here it is a can and a half of krylon rust tough later.
It felt good to get something done on the old girl after being forced to take so much time off due to winter.
Stay tuned guys because there is going to be some thrashing going on, complete frame and cab swap, out with the old in with the new!
Old 04-29-2015, 11:27 AM   #799
SeTx67
SeTx67's Avatar
Good to see you making progress again Brian. When's the next update? Lol
Old 04-29-2015, 01:15 PM   #800
Xeen
Xeen's Avatar
As soon as my parts come in from CPP, so in about a week if we're lucky haha!
1968, chevrolet, restomod, stepside, swb
