Old 02-13-2015, 02:49 PM   #176
ClydeDale
Re: Avoid the Concrete
It's been a couple of months, show us some updated pics!!
ClydeDale is offline   Reply With Quote
Old 02-14-2015, 03:38 PM   #177
Low68
Low68's Avatar
Sorry, no updates right now. I haven't really worked on it since before Christmas. I got busy with the holidays and then did some work on my car. Finally have it back in the shop, but I probably won't be doing anything on it till next weekend.
Build Thread
Low68 is offline   Reply With Quote
Old 02-18-2015, 08:51 PM   #178
Low68
Low68's Avatar
I am continuing to work on getting the doors to fit like I want them to. When I shaved the drip rails, the a pillars stuck out too far for my liking. I decided to reshape the pillars slightly to pull it. There is also a little bit too much gap, so I am moving the outer edge back slightly to tighten that up. I have been working on the driver's side, which was the worst side. Once I get the pillar welded back up, I can finish the top corners of the cab and do some finishing along the top and back of the doors.
Before photo:
In progress:
Here is a good angle to show how the pillar is being moved:
I am letting the leading edge stick out just slightly.
Thats it for now. Need to finish up this side before I move on to the next one.
Build Thread
Old 03-01-2015, 10:33 PM   #179
Low68
Low68's Avatar
I got the driver side mostly finished. I am pretty happy with the way it turned out. It will need a little filler to smooth it all out, but overall, I think it will look good once it is done.
All welded
Smoothed
Corner in progress
Corner mostly done
Different angle
Build Thread
Old 03-01-2015, 10:58 PM   #180
bterry97gt
Looking awesome!
bterry97gt is offline   Reply With Quote
Old 03-02-2015, 12:26 PM   #181
Blown06
Blown06's Avatar
Looking good.
Me: Jarrod
My project: http://www.67-72chevytrucks.com/vboa...d.php?t=646563
Blown06 is offline   Reply With Quote
Old 03-02-2015, 02:39 PM   #182
Justin@EntropyRad
Justin@EntropyRad's Avatar
looks like a lot of work...that turned out really nice
* Call me NOT the website number*
Justin Novick
(773) 303-8251
Sales/Support
Entropy Radiator / Engineered Cooling Products
"The Sexiest Radiators For The Sexiest Hot Rods" - www.EntropyRad.com www.speedcooling.com
Justin@EntropyRad is offline   Reply With Quote
Old 03-03-2015, 06:14 PM   #183
Low68
Low68's Avatar
Thank you for the compliments!
Build Thread
Old 03-17-2015, 01:40 AM   #184
Low68
Low68's Avatar
Things are starting to slow down, so I am going to try to start getting a lot of stuff done on the truck again. I worked on it after work today and started on the passenger side A-pillar.
Before:
Cutting:
Welding back in:
Build Thread
Old 03-17-2015, 08:47 AM   #185
mcbassin
Still Learning
mcbassin's Avatar
Nice work on the cab. You are knocking it out!
Old 03-17-2015, 09:27 AM   #186
roushinator
roushinator's Avatar
Awesome work!!!
Ryan...
1972 C10 Stepside With 2014 Camaro 6.2L/6l80e drivetrain
http://67-72chevytrucks.com/vboard/s...11#post5532411
roushinator is offline   Reply With Quote
Old 03-19-2015, 12:35 AM   #187
Low68
Low68's Avatar
Thanks you guys. I am trying to get back on the truck as much as possible. I got my semi annual motivation fix from the Goodguys show in Scottsdale last week. My goal is to get the truck all primered and drivable by November. I have a lot to do by then, so I am going to have make this a bigger priority.
I spent a little time today working on it and got most of the pillar welded up. Still have some to weld on the inside edge. I didn't get any pictures tonight. I am will get some next time I am at the shop.
Build Thread
Old 03-20-2015, 10:30 AM   #188
Low68
Low68's Avatar
I got the outside of the passenger side pillar welded and smoothed. Only got one picture. I still have a little bit of welding on the inside that should go pretty quick and then I need to grind down the inside.
Build Thread
Old 03-20-2015, 01:07 PM   #189
knomadd
knomadd's Avatar
Lookin' good!
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 03-21-2015, 01:30 AM   #190
Low68
Low68's Avatar
Thanks Duane!
Build Thread
Old 04-03-2015, 01:28 AM   #191
Low68
Low68's Avatar
I have most of the sheet metal modification done around the top part of the doors. The cab skin where the window frame and door skin meet was a problem. The cab does not follow the same line as the door.
The door frame obviously was set in and didn't line up with the cab at all. I decided I would try something and see how it looks. I think it will end up looking alright once I get everything smoothed out. I ended up cutting the cab skin back around 3 inches and decided to continue the line from the door back and fade it into the cab corner.
I also got a new front pulley set up from a local guy Tom Korinek. He sells lots of stuff for these trucks and has several yards with truck parts. The kit is an American Billet serpentine set up. Very similar to vintage air and billet specialties kits. To compare it with my dad's vintage air front runner kit, it is not quite as high quality, but it is cheaper by quite a bit. Plus, they are a local company which I like as well. They have a silver line edition that has some machined accents that also looks cool. I decided to go with all black however.
Build Thread
Old 04-03-2015, 07:21 AM   #192
nlped
nlped's Avatar
The little section on the cab really looks cool and the serpentine setup is sweet. A+
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 04-03-2015, 08:22 AM   #193
Low68
Low68's Avatar
Thanks Ed!
Build Thread
Old 04-03-2015, 08:43 AM   #194
Stickman
Stickman's Avatar
Metal work is excellent as always. That serpentine is nice. It looks just like the vintage air product.
Stickman is offline   Reply With Quote
Old 04-03-2015, 02:36 PM   #195
Justin@EntropyRad
Yea man, pretty sweet stuff
Justin Novick
(773) 303-8251
Sales/Support
Old 04-05-2015, 12:50 AM   #196
Low68
Low68's Avatar
Thanks again guys. I appreciate the compliments.
I have been working on getting the door gaps to where I want them on the top edge of the doors. I did not realize how big of a pain it would be, but it will be worth it to have consistent gaps all the way around the door. I haven't taken any pictures of it, cause there is not really anything worth taking a picture of. I will get some when I get the gap finished up .
Build Thread
Old 04-05-2015, 01:06 AM   #197
fatgump
fatgump's Avatar
Low68 would probably be done with his truck if he wasn't always helping me. The all black kit looks great. Did it show the machine marks like it did on my kit? I think if it had not shown markings and all the components had the same flat or gloss finish it would be perfect.
fatgump is offline   Reply With Quote
Old 04-05-2015, 01:26 AM   #198
Low68
Low68's Avatar
It did have the machine marks. I read the description again and I think they leave them on purpose. I will probably spray some flat clear on the accessories that are gloss to make everything match a little better.
Build Thread
Old 04-10-2015, 12:36 AM   #199
Low68
Low68's Avatar
I have been working on getting the window frame gap right. I have the back and the top edge pretty much finished up. I still have to do the front edge.
Build Thread
Old 04-10-2015, 07:17 AM   #200
mooseknuckles
mooseknuckles's Avatar
nice work...
mooseknuckles is offline   Reply With Quote
