Old 02-18-2015, 03:58 PM   #1
1966FLEETSIDE
1966FLEETSIDE's Avatar
oil pan removal
hi ya'll i have a light oil leak looks like from the rear main,now my ? is do i need to lift engine up a bit to remove pan it looks pretty close to the crossmember,my engine is a 6cyl 292 on my 63 c10,thx for your help.
1966FLEETSIDE is offline   Reply With Quote
Old 02-18-2015, 06:15 PM   #2
Wrenchbender Ret
Re: oil pan removal
Yes. You will have to raise it quite a bit. Remove the flywheel cover also,.
Wrenchbender Ret is offline   Reply With Quote
Old 02-18-2015, 08:25 PM   #3
T2vigil
T2vigil's Avatar
Re: oil pan removal
I did this last summer on my 250. Take the motor mount bolts out and jack the motor up far enough to put a 2X4 between the engine block and the top of the motor mount. After that as said earlier the flywheel cover.
T2vigil is offline   Reply With Quote
Old 02-18-2015, 10:37 PM   #4
Wrenchbender Ret
Re: oil pan removal
Also the shroud & watch that the fan blade does not get into the rad.
Old 02-19-2015, 11:22 AM   #5
vince1
Re: oil pan removal
I tried the stop leak and it may be already sealed after only 60 miles of driving. IMO that stuff works as advertised.
vince1 is offline   Reply With Quote
Old 02-19-2015, 07:46 PM   #6
1966FLEETSIDE
Re: oil pan removal
thx fellas sorry for the late reply.i dont have to release driveline do i??thx
Old 02-19-2015, 10:14 PM   #7
TJ's Chevy
TJ's Chevy's Avatar
Re: oil pan removal
Nope you won't have to take the drive shaft off. Take the two engine block mounts off and stuff a 2x4 under them...or something thicker if you can. It'll be a tad tedious to get the pan off cause of the lip in the pan. You'll see when you get the pan off, but with some patience it'll come off.
