02-18-2015, 05:22 PM | #1 |
Roadster Shop 69 REVO Patina build
Here is a 69 SWB build that we have been working on to debut a new bolt on REVO suspension line as well as be the R&D vehicle and general shop truck. We started with an incredibly nice truck, originally out of Georgia. Great patina and insanely solid! The only issue that we have found is a small dime sized rust spot in the back of the cab that is covered by the bed.
The plan is to keep the exterior and interior basically as is. We will upgrade the suspension with our new bolt-in REVO IFS crossmember and 4-bar rear. It will get a pretty healthy, injected SBC and 4L60 trans. Nothing too fancy, just a reliable, comfortable truck with a great stance that can be driven anywhere. |
02-18-2015, 05:29 PM | #2 | |
Re: Roadster Shop 69 REVO Patina build
02-18-2015, 05:30 PM | #3 |
I'm in...
02-18-2015, 05:52 PM | #4 |
i'm coming along for the ride
02-18-2015, 07:22 PM | #5 |
Laid Back
I'm in!!
72 chevy swb Direct dealers for.. Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body.. Kyle http://67-72chevytrucks.com/vboard/s...d.php?t=574629 |
02-18-2015, 08:01 PM | #6 |
Got 2 watch this one.
02-18-2015, 08:13 PM | #7 |
nice!...I'm in.
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
02-18-2015, 08:47 PM | #8 |
Sweet
______________________ www.northeastrodrun.com |
02-18-2015, 08:53 PM | #9 |
I was in your shop once and what a nice place....These guys build some top notch stuff!
02-18-2015, 08:57 PM | #10 |
Im in .
02-19-2015, 09:26 AM | #11 |
Ready to see what you guys do to this one!
02-19-2015, 09:56 AM | #12 |
got my interest
Grand Theft Auto https://67-72chevytrucks.com/vboard/...d.php?t=855961 Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
02-19-2015, 10:40 AM | #13 |
Thanks for all of the support!
After a little design work, we were able to come up with the finished product... Once the stock front crossmember is removed the new REVO crossmember will bolt directly in using existing frame rail holes. A few additional mounting holes are required to be drilled in the frame rails. If you are not familiar with the Roadster Shop REVO IFS, check out this link and read up on the "Overview" and "Standard Features" sections on this page. http://roadstershop.com/suspension/1967-72-c-10-revo/ (the green sections represent the stock frame rails) On the rear, we designed all of the brackets to again bolt to the frame using existing holes. A few additional holes are required to be drilled in the rear rails as well. In order to get the rear of the truck sitting low, a C-notch needs to be cut into the rear rails above the axle. We provide a template to trace and cut out. The new rear bracket extends forward and back of the c-notch for added support. It also has a boxed in section the fits into the c-notch to again add strength. The coilovers are mounted outboard of the rails and set vertical to optimize the motion ratio. You can run a 10" wide wheel in the stock wheel tubs with this set up. If you want to slightly mini-tub the bed, an 11" wheel will fit with a 305 tire. We have a few other pieces in the works for a center crossmember, exhaust ports, steering mounts, etc... |
02-19-2015, 11:07 AM | #14 |
Prestige Worldwide
I will be following along on this one!
02-19-2015, 01:24 PM | #15 |
Me too. Looking forward to the install plus features and benefits information.
02-19-2015, 01:35 PM | #16 |
In!
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
02-19-2015, 03:14 PM | #17 |
The completed front suspension
02-19-2015, 03:33 PM | #18 |
Nice setup.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
02-19-2015, 03:56 PM | #19 |
Junior Member
Watching. I would have gladly provided the truck. I have one very similar.
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
02-19-2015, 04:10 PM | #20 |
The completed rear suspension (with a few pieces of 1"x1" to prop it up for the pictures)
02-19-2015, 07:09 PM | #21 |
How is the alignment adjusted in this configuration?
02-19-2015, 10:32 PM | #22 |
The lower control arms have eccentrics to adjust camber and caster at the bushing end.
The link has a good diagram of the eccentric action. http://roadstershop.com/suspension/1967-72-c-10-revo/ |
02-19-2015, 11:18 PM | #23 |
cant wait to see this one
02-19-2015, 11:37 PM | #24 |
Subscribed
ANDREW 1972 Chevy SWB Cheyenne Super JANE http://67-72chevytrucks.com/vboard/s...d.php?t=462072 1972 GMC Jimmy PENNY http://67-72chevytrucks.com/vboard/s...d.php?t=735827 1968 GMC patina swb PEARL http://67-72chevytrucks.com/vboard/s...d.php?t=731315 1972 Chevy K20 BRUCE http://67-72chevytrucks.com/vboard/s...d.php?t=805788 |
02-20-2015, 10:33 AM | #25 | |
Here is a clip to illustrate the range of motion. |
