02-21-2015, 04:26 PM | #1 |
Shortening Axles- Dana 60 Rear and 44 Front
Hi, New here to the 4x4 section. I'm planning on building my 54 GMC into a 4wd. I have axles from a 72 GMC K2500. Dana HD 44 front and Dana 60 rear. These will need to be shortened from approx. 70" WMS-WMS to I think about 60".
What I'm hoping for is to wind up with an axle length that is not a custom length but an off the shelf part. Has anyone here done this or can give me some advice or tips about this? What might some options be? And what about shortening the rear by cutting off the hub, boring it out to fit the axle shaft and welding it. Is this a bad idea? Thanks, Rick |
02-21-2015, 05:07 PM | #2 |
Re: Shortening Axles- Dana 60 Rear and 44 Front
No 60 rear is that narrow factory. Front 44 can use waggy or EB...why so narrow?
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 4” SAS 1999 GMC Yukon 350/4L60 6" SAS |
02-21-2015, 10:13 PM | #3 |
He is right the jeep wagoneer dana 44 front is 60 and came in both side drops depending the years.And only big rear end close to that width i know of is a cab and chassis 14 bolt which is 63
02-22-2015, 09:10 AM | #4 |
Cab n chassis Dana 60 is bout the same width too, but dunno why wants it that narrow. Those trucks didn't use axles that narrow.
02-22-2015, 09:22 AM | #5 |
Thanks for the replies everybody. Not looking for axles. I already have them. Just need to shorten them. The 47-55.1 trucks had about 60" WMS-WMS front and rear. Way narrower than 55.2 up. And I don't want the tires outside of the fenders. What I'm going for is sort of a Napco clone. I may wind up getting custom length axle shafts from Moser or Dutchman. Thanks, Rick
02-22-2015, 09:29 AM | #6 |
Back then GM was using HO52s, so why not original rear from same truck?
02-22-2015, 09:34 AM | #7 |
02-22-2015, 09:57 AM | #8 |
For the price of one set of custom made axles you could buy and swap in different axles that are the width you need.And if you sell the ones you have that will give you money to re gear both axles.
02-22-2015, 10:39 AM | #9 |
Agreed. If you aren't going to wheel it hard, the Wagoneer axles would be ideal. Get a passenger drop and 6 lug bolt pattern you can still run GM 1/2 ton wheels. And with the right components, brakes.
But if you have to narrow it, Pirate4x4.com has lots of guys who have changed the width of the fronts by removing the c's on the front, cutting to width and re-welding. Rear is easy in comparison.
02-22-2015, 10:43 AM | #10 | |
As for the rears, Back in the day lots of rodder guys put narrowed full floater rears in cars. They cut off the hub flange, bored it to the shaft dia., and rewelded them. Cutting off whatever excess. I'm wondering if anyone does this anymore or does it weaken the shaft too much? Dutchman and others will respline your existing shafts too and it's not nearly as expensive as customs Thanks, Rick |
02-22-2015, 10:52 AM | #11 | |
I don't mind doing the work of shortening the tubes. Like you said, shorten the front at the "C"s. The rear tubes are usually shortened at the pig. I may even respline the shafts myself to save some cash. That is if they are resplinable. (is that a real word?) FWIW, I have a 350 with an SM465 married to a NP205 that I'll be using. It's pass side drop of course since it's from a K2500. Rick |
02-22-2015, 10:55 AM | #12 |
As already mentioned the front will be stupid easy. Not sure when they went to non tapered inners, but aftermarket waggy axles easy to get. Narrowing the rear won't be too hard, and getting shafts for that won't be that crazy either, since narrowing axles is pretty common these days.
I never messed with your body style truck, didn't realize they were that narrow.
02-22-2015, 08:03 PM | #13 |
HO52s also came in 4.10. Easy swap.
02-22-2015, 08:57 PM | #14 |
02-22-2015, 10:39 PM | #15 |
There are no newly manufactured HO52 gears. There used to be some 3.90's but they have not produced another run, and that was at least 10 years ago.
Usually when a rear axle is narrowed, the tube is cut somewhere in the middle and sectioned and just welded back together. I have a housing jig made by Strange with multiple housing end pucks to re-align, and most racecar shops can handle that for flanged axles but not full floaters. I re-read your first post and am not sure about what you were talking about on the re-boring to fit the axle? If the rear is pretty straight, the tube itself can be used to align the ends. Sleeve it with a slight interference fit tube then weld penetrating into the sleeve. You can buy cut to length full floater axles, just not sure if you can get them splined far enough in for a 60" WMS. It looks like the Jeep J20 (or older J4000) full floaters were 65" WMS and is another option that is at least a little narrower.
02-22-2015, 11:12 PM | #16 |
My K20 with an D44/HO52 has 4.10's, verified it last summer.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
02-22-2015, 11:19 PM | #17 |
I'm using a 1955 h052 in my jeep at 63". Sounds like you could just use that axle with some heavy backspace wheels.
02-23-2015, 02:26 AM | #18 |
The only problem i know with the waggy 44 is its low pinion but that shouldn't matter unless you go bigger then 37s or a huge lift.You did get me thinking yukon and nitro both sell cut to length axles for the dana 60 you just need a good metal chop saw and grind the edge over.Do you have a good enough welder to shorten a axle tho?
02-23-2015, 08:36 AM | #19 |
I'm talking about factory ratio in later years. Was there an axle spline change somewhere along the line? I believe the HO52 went virtually unchanged through the tears, other than brakes which are interchangeable. I guess a check in the parts book would show where any changes were. If the axle spline count did change, you still would only need to modify the later axles, but keep the housing unchanged. And there would be no differential set-up requires..
02-23-2015, 04:56 PM | #20 |
They changed from ball bearing to tapered bearing at some point. There is also the load bolt that is always on the 72 and occasionally on the 52. Big long thread on Pirate. Good info. You can convert to 14 bolt shafts and 14 bolt Detroit and get away from the coarse spline axles.
There are a couple of threads over there as well on making an HO52 front axle and a few guys running them. http://www.pirate4x4.com/forum/chevy...aton-h072.html
44 Willys MB 52 M38A1 64 Corvette Coupe 68 Camaro 'vert LT1 & TH700 69 Z/28 355 12.6's @110 69 Chevy Short Step 4 1/2"/7" drop 72 Jimmy 4WD 4spd 4" & 35's 02 GMC 2500HD 4x4 Duramax Last edited by Mike C; 02-23-2015 at 04:56 PM. Reason: added link |
02-23-2015, 06:35 PM | #21 | |
Lots of good advice here. I'll have to join pirate and do some reading. I really don't need to go all the way down to 60" if it's not feasible. 63 or even 65 might be ok. I plan to run skinny tires and stock looking rims so that will help in keeping the tires inside the fenders Thanks very much to all who've replied. Rick |
02-23-2015, 08:03 PM | #22 |
Did you do a search of 4wd trucks your vintage? See what others have done, seeing pics may change your mind one way or the other....I see a truck like urs I believe in the Angry Orchard commercial, looks like 8 lug too.
02-23-2015, 08:25 PM | #23 | |
Pretty much all of the 47-55.1 4wd builds I've seen have axles that are too wide for my taste. The tires stick way out and it's not what I'm going for. Here's a pic close to what I'm hoping to wind up with. Rick |
02-23-2015, 09:07 PM | #24 |
You could narrow what you have, but wouldn't be cost effective. Do you want 6 or 8 lug axles? If you want 6 lug, go with waggy's front and rear. If you want 8 lug, then gonna havta narrow your set. If you use a waggy front and convert to 8 lug, it will widen it 1.5 IIRC, which is wider than what you want.
02-25-2015, 06:35 PM | #25 | |
As far as the rear goes, I may shorten the shafts and the tubes myself. I still want to explore the idea of shortening them at the hub flange and rewelding them. Rick |
