#301 | |
Re: Attempting my first build 72 K5
Hey Brad, thanks a lot for sharing this. The same issue you had is the exact same for me. The spanner nut wants to push through past the threads in the housing. Is post #144 in the thread the one you are talking about in reference to the sequence? I haven't tried this yet, but I think I'll give it a shot tomorrow after work. Fortunately, the powder coat holds up well and I've managed to not chip it with all of the attempts I've made at it.
My Build Thread 72 K5 http://67-72chevytrucks.com/vboard/s...d.php?t=628612 Build version 2.0: 72 K5 6.0 LQ9, 4L80e, NP205 http://67-72chevytrucks.com/vboard/s...d.php?t=793192 ____________________________________________ 1972 CST K5 Blazer Dark Olive |
#302 | |
I'm trying....
![]() Join Date: Oct 2013
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." |
#303 |
I just got caught up on your build. Man am I jealous of all that solid sheet metal. I know I've said it before, but you're doing a great job on the build, but 3 weeks since an update? I hope you're just that damn busy and not stalled on the Blazer.
#304 | |
Thanks a lot. Appreciate the compliments I have been very busy (both work and working on the truck) I'm waiting to finish a couple of things before I do a big update. Hopefully, I wont be doing this weekend ![]()
#305 |
It's been a while since I've had any worthy update, but I believe I hit a milestone today.
I have a ROLLING CHASSIS! ![]() Earlier in my build thread I had issues with the Willwod calipers rubbing against the rim. I finally found a solution but it wasn't easy to figure out. I'll get to this in just a moment, but let me recap what I've been doing the last 4 weeks. So I had the front axle ready to go until I broke off one of the bolts that holds the dust shield to the steering knuckle (twice) Yeah, that right I managed to do it two times in a row.. The first time the bolt was really stuck in there so I had to grind some of the metal off and then drill it out. I put a heli coil in as a replacement.. Then I went to assemble the wheel hub and steering knuckle for the 37th time.. btw - I found how do seat the spanner nut and ball joint studs right the first time. I decided to read through the service manual very thoroughly this time around and in the fine print underneath the standard instructions it says 1. place the steering knuckle studs inside the C clamp. 2. Tighten the top king nut snug enough to keep the stud and steering knuckle from moving.. not torqued to spec, but just snug enough to keep the knuckle from moving side to side.. 3. Then torque the bottom to spec 70 lbs 4. torque the spanner to spec 50 lbs 5. torque the upper to spec 100 lbs Works like a charm. You will notice the steering knuckle starts to losing as you tighten the upper ball joint nut, giving it that smooth free flow with just a little bit of drag. So after I broke the 2nd bolt off the dust shield / knuckle, this time I welded a washer to make the surface flush again because last time I grinded it down after the first time. I then used a washer on the back side and two washer on the front and made the new thread size bigger and this time it worked. So after spending the last 2 weekends dealing with that I finally was able to make some progress. Remember the Wilwood Calipers that where rubber the inside of the wheel? I found a solution and it works. 1. I used a .250 (1/4") spacer. 5. Mounted the rims and had enough clearance
My Build Thread 72 K5 http://67-72chevytrucks.com/vboard/s...d.php?t=628612 Build version 2.0: 72 K5 6.0 LQ9, 4L80e, NP205 http://67-72chevytrucks.com/vboard/s...d.php?t=793192 ____________________________________________ 1972 CST K5 Blazer Dark Olive Last edited by 72K5CSTDarkOlive; 07-05-2018 at 10:38 PM. |
#306 |
Heres a couple pics of the axle . I added a set of Baer crossed drilled rotors
#307 |
I pulled a all nighter yesterday and installed the fuel & brake lines, leaf springs, shocks, stabilizer, steering rod, tie rods, front diff skid guard and now I can say I have a rolling chassis. I've been waiting for this day a long time.
My Build Thread 72 K5 http://67-72chevytrucks.com/vboard/s...d.php?t=628612 Build version 2.0: 72 K5 6.0 LQ9, 4L80e, NP205 http://67-72chevytrucks.com/vboard/s...d.php?t=793192 ____________________________________________ 1972 CST K5 Blazer Dark Olive Last edited by 72K5CSTDarkOlive; 03-21-2015 at 09:49 PM. |
#308 |
some more pics
#309 |
I'm trying....
Fantastic Mike...great progress, great job! Worthy foundation for that spotless tub. Way to fight through the bumps and snags.
#310 | |
Hopefully it's more down hill from here!
#311 |
Looks great. A few questions.
What Absorbers are you using and what Steering stabilizer? Looks like the body of it clears the front springs. On your Rear brake lines. The brass union between the 2 rear lines and the single hose, did you clean up your original or buy a new one? Why did you install the bolts on the top of the Engine cross member from the bottom up with the nuts on the top of the frame? I might be asking you some more questions about when you did your ball joints. I'm going to be tackling my front axle in 2 weeks and I'm not sure I totally understand the proper way yet.
Jeff. '72 Blazer K5 "Camshaft opinions are like belly buttons; everyone has one and no two are alike" My Blazer Build: http://67-72chevytrucks.com/vboard/s...d.php?t=626752 My Engine Build: http://67-72chevytrucks.com/vboard/s...d.php?t=637336 |
#312 | |
I'm using Skyjacker Monotube shocks and stabilizer. They are the stock stock height shock absorbers. You have to install the stabilizer first before you install the steering rod or else there is not enough room for it squeeze through. The reason I installed the bolts on the top of the Engine cross member from the the bottom up is because I looked backed through my pictures when I tore it down and that's how they where. I'm not sure if that is stock or not. I do know the OE replaced the motor at one point so he might have installed them that way. I cleaned up my original brass union.. When I took it apart, it had a bracket that sits inside one of the differential cover bolts so that's why I kept it just to make sure everything when back together. The lines came from inline tube and i had to fight with them a little bit to make em fit. The ball joint sequence is like this: 1. Slide the upper and lower stud inside the C-Clamp with the spanner flush at the top. 2. Next step is to tighten the upper king nut so it is snug fit.. Just enough so that the knuckle doesn't turn when tightening the lower. 3. Tighten the lower nut to 7o ft lbs 4. Take off the upper king nut 5. Tighten the spanner to 50 ft lbs. 6. Tighten the upper king nut to 100 ft lbs.. If the hole is not visible enough to slide the cotter pin keep tightening the upper until you have enough room to slide the cotter pin through. Hope that helps. let me know if you have any questions..
#313 |
Beautiful work and attention to detail, well done. Glad ya got past your problems. Will be a great truck when done...thanks for sharing and taking the time to post up
#314 |
![]() Join Date: May 2013
Looks amazing !
Mike as said before,your attention to detail is awesome. Congrats on hitting this milestone.
Tom 71 K2500 71 K5 Jimmy |
#315 |
The rolling chassis is a hell of a milestone and it looks great. If you think you're jazzed now, wait till the engine, tranny and transfer case are in. Keep up the good work. Looking forward to the next update.
#316 |
Wow! Chassis really looks good! Great project you got there!
#317 |
Carpe manana
![]() ![]() Join Date: Dec 2010
Looking fantastic!! Strong work. I will have a beer to celebrate on your behalf
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
#318 |
Thank you all. I really appreciate all the complements. It certainly helps keep me motivated.
TJ - I forgot to mention one little issue with the rear shocks. The bottom steel sleeve is about 1/8" or less of inch to long to fit inside the rear axle where the shock mounts too. It's a simple fix. All I did was shave off just enough of the steel sleeve..Check out the pics below
#319 |
![]() Join Date: Mar 2002
nice rolling chassis...this is when the fun really starts.
where did you buy your fuel lines? and, for the brake lines, what were the problems with inline tube? i'm about the buy all new lines or bend lines myself...just trying to decide which route is best. tom |
#320 | |
Currently, the only problem I see is the rear of the brake like does not line up with the bracket that extends out of the frame that connects the brake hose to the brake line. I'm going to mess it later tonight to see if I can make any adjustments to so it lines up straight enough to go through the hole without having to force it.
#321 |
I bought a used tank from 1rippen solely for the purpose of the using the filler neck. I then got a new steel tank and the Radiator shop I use lined in and swapped the neck for me. I painted it GM OEM gunmetal Gray..
#322 |
Carpe manana
That was an excellent way to go - tank looks great.
#323 |
I'm trying....
Tank turned out fantastic Mike...it'll pair well with that immaculate frame.
#324 |
Thanks, Pete and Brad.. Glad I finally came to a resolution with the tank.. Lets hope it actually fits
#325 |
The new tank looks great. What was the finish on it before you painted it?
