02-24-2015, 08:06 PM | #1 |
Building my c10 since I was 15 and in need of some advice
Hello fellas,
I am the proud owner of a 68 c10 stepside with a SBC 350 and a muncie 4-spd. I have access to both a edelbrock performer intake and a stock z28 aluminum intake manifold. I also have headers a comp cam XE-274 and a edelbrock 600cfm electric choke carburator. Any suggestions on which intake to use would be greatly appreciated. Ben |
02-24-2015, 08:11 PM | #2 |
Re: Building my c10 since I was 15 and in need of some advice
I don't think you will see a huge difference in the intake choice but I would use the Eddy, are they both setup for the same style carb, a lot of the Z intakes take only a factory Gm carb while the Edel is most common for their carb base but can come in the Gm style also. Any pic's of intakes.
1987 Green n Green machine. 5.0 4spd std. 7" lift w 35's. |
02-24-2015, 08:13 PM | #3 |
Yes, pics please. The Z/28 intake is more comparable to the Performer RPM and should be a standard square bore pattern.
With stock cam and Edelbrock Carb, the Performer intake should/would be your best choice.
02-24-2015, 08:18 PM | #4 |
I will post some pics once I get home, both intakes are set up for the edelbrock carb.
02-24-2015, 08:27 PM | #5 |
Active Member
Buy a performer, and put the z28 intake on Ebay. You will be $ ahead.
cascadeheavychevy 67 C10 327 4speed 69 C20 350 4WD 4speed 69 C20 350 4WD 4speed 69 C20 350 4 soeed 69 C20 CST 350 Auto 70 C10 307 4speed 71 GMC Supr 350 Auto 70 C10 350 Auto 67 CST 327 Auto |
