Old 02-25-2015, 05:34 PM   #1
appyacres
Smile 263HD Transfer Case Bearing Fail
What if 40k miles ago...local oil change the transfer case oil and put the green oil (Auto Trac II) instead of ATF.
Would this promote rear bushing failure in the transfer case?
- no side to side play with yoke installed but up and down with klunking!
Heard that bushing was a bear to get out. True?
Think it would be wise to change the magnesium housing out for an aluminum one when I go in to fix this? Any benefit?
It's coming out tomorrow and I was going to start ordering parts ASAP.
My dog is going to be pissed that there won't be any truck rides for a few weeks
2005 GMC 2500HD 6.0L Ext Cab
appyacres is offline   Reply With Quote
Old 02-25-2015, 11:06 PM   #2
95 S_Trucker
95 S_Trucker's Avatar
Re: 263HD Transfer Case Bearing Fail
Auto trac fluid is blue, not green. It shouldn't have atf in it either.
It should have
NVG 263-NP1 Manual Transmission Fluid GM P/N 88861800 (Canadian P/N 88861801)
Good luck with the repair.
95 S_Trucker is offline   Reply With Quote
Old 02-26-2015, 09:23 AM   #3
95 S_Trucker
Its up to you if you want to go with the aluminum case half. There are also some other ways to prevent pump rub.
I am pretty sure that a new case half from gm will have a new bushing installed.
