Old 02-25-2015, 11:44 PM   #551
TJ's Chevy
TJ's Chevy's Avatar
Re: Project two tone.
So here's a tiny update on things for you all. Things will be picking up soon as I will be getting more hours of work. And once the weather gets warmer I'm a starting the tear down and the frame off resto begins( finally). So I'm leaving ya'all with this video. Enjoy, and catch everyone when I have a real update. TJ
https://www.youtube.com/watch?v=NAoDB3rjK1c
Old 02-26-2015, 06:28 AM   #552
Double check and make sure you have good grounds on your taillights. It'll do crazy crap just like you described.
Old 02-28-2015, 11:34 AM   #553
TJ's Chevy
TJ's Chevy's Avatar
Found my problem up in the circuit board. Either a loose connection or a bad ground some wheres. Luckily its all coming apart soon anyhow!
Old 02-28-2015, 03:47 PM   #554
Mikes66ChevyC10
Mikes66ChevyC10's Avatar
Happy you found the problem. Wiring can drive a person crazy! lol
1966 C10 Stepside swb
http://67-72chevytrucks.com/vboard/s...d.php?t=617778
Mikes66ChevyC10 is offline   Reply With Quote
Old 02-28-2015, 10:32 PM   #555
Ta2Don
Ta2Don's Avatar
Get to Wrenching...
DON
Proverbs 27:17
US Air Force Retarded errr Retired
My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920
My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266
My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD
Ta2Don is offline   Reply With Quote
Old 03-01-2015, 11:46 AM   #556
TJ's Chevy
TJ's Chevy's Avatar
HAHA! Yep!
Originally Posted by Ta2Don View Post
Get to Wrenching...
Aye sir!
Old 03-01-2015, 08:22 PM   #557
Ta2Don
Ta2Don's Avatar
Stoked about the news you called about...
DON
Proverbs 27:17
Old 03-08-2015, 12:09 AM   #558
TJ's Chevy
TJ's Chevy's Avatar
Bought another truck today! I have a Three Stooges Crew now. https://www.youtube.com/watch?v=QSk_ct9x-CU
Old 03-08-2015, 12:17 AM   #559
hotrod66
hotrod66's Avatar
Neet new gmc truck You going to keep the giant west coast's on it tj?
Between saying and doing many a pair of shoes are worn out
hotrod66 is offline   Reply With Quote
Old 03-08-2015, 12:45 AM   #560
TJ's Chevy
TJ's Chevy's Avatar
I want to but on one of them the arm that goes through the mirror is no good so the mirror turns back and forth with waaay to much ease. Can't weld it either cause its plastic on top, but I'm a find a set of mirrors that'll fit in those arms to use cause I like the big style of them. lol Rear vision ain't no issue.
Old 03-08-2015, 09:43 AM   #561
4dranch
Shloooooong bed member #2
4dranch's Avatar
Nice truck.
and you already named it Moe.
David,
Daughters 66 truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=484601
Learning to drive a 3 on the tree:
http://www.youtube.com/watch?v=CcCMvRgBo1Q
4dranch is offline   Reply With Quote
Old 03-08-2015, 11:52 AM   #562
TJ's Chevy
TJ's Chevy's Avatar
Originally Posted by 4dranch View Post
Nice truck.
HAHA! I was thinking curly!
Old 03-09-2015, 10:14 PM   #563
Ta2Don
Ta2Don's Avatar
A video, but no pics… What gives...
Diggin' the Patina...
Happy for ya Brotha!!!
DON
Proverbs 27:17
Old 03-09-2015, 10:21 PM   #564
TJ's Chevy
TJ's Chevy's Avatar
Hey brotha! I sent you pictures by email! And I have pictures on the 60-66 board! Thanks fer stoppin in!
Old 03-10-2015, 10:09 AM   #565
Ta2Don
Ta2Don's Avatar
Guess I need to open the brain windows...
DON
Proverbs 27:17
Old 03-11-2015, 04:09 PM   #566
markeb01
Senior Enthusiast
markeb01's Avatar
Was just watching your video on the tail lights, and I don't think you have a ground problem or a loose connection. I believe the issue is not identifying which is the "crossover" wire coming from the turn signal switch. I can't advise how to find the problem, but careful study of a schematic should help track down which wire goes to what at the back of the truck.
The crossover wire is what allows one brake light to work while the blinker flashes on the opposite side. My guess is the "dead" wire you've discovered probably isn't dead, it just has to be connected correctly to make both blinkers and both turn signals work.
Back in the days before internet, or even car manuals at the local library, it took me 12 hours to figure this out when installing a junkyard turn signal setup in my 49 Plymouth coupe. I discovered and solved the problem by pure trial and error. Perhaps knowing what you're looking for will save you some grief. Good luck, Mark.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 03-11-2015, 04:52 PM   #567
TJ's Chevy
TJ's Chevy's Avatar
Thanks for the info Mark. I'll be tinkering with it here again soon.
Old 03-28-2015, 11:24 PM   #568
TJ's Chevy
TJ's Chevy's Avatar
Alrighty so here's a small update. Got the bell housing painted. Another thing checked off the list. Will get the bell crank, and inspection covers done Sunday sometime. Slowly but surely.
Old 03-29-2015, 12:12 AM   #569
66Z71
66Z71's Avatar
Nice color.
"Always try to make the best part you can with the skills you have. If it isn't good enough throw it away and make another. Every time you make a part your skill will increase and you'll make a better part than you were capable of making before." Lil John Buttera
66Z71 is offline   Reply With Quote
Old 03-29-2015, 10:26 AM   #570
Ta2Don
Ta2Don's Avatar
DON
Proverbs 27:17
Old 03-29-2015, 10:18 PM   #571
TJ's Chevy
TJ's Chevy's Avatar
Thanks 66Z71!
Thanks Brotha!
Anyhow, finished the inspection plates and the clutch fork today.
Old 04-01-2015, 09:29 AM   #572
1963c-10
1963c-10's Avatar
Looks great TJ. I also painted all these parts, even though they can't be seen.....we know they are there and looking good.
1964 Short bed trailer
Old 04-01-2015, 10:38 AM   #573
TJ's Chevy
TJ's Chevy's Avatar
Thanks, I agree. lol Least I'll see something nice when I'm doing an oil change. haha
Old 04-02-2015, 08:45 AM   #574
dwcardfan
dwcardfan's Avatar
Nice color! Looking Good!
dwcardfan is offline   Reply With Quote
Old 04-02-2015, 10:28 AM   #575
TJ's Chevy
TJ's Chevy's Avatar
Thanks bud!
