02-26-2015, 08:25 PM | #1 |
Console Seat Belt fastener holder
Not sure If I could find a couple of the hooks that fit on the front of the console to hold the belt fastener when not in use ,(and not sure that the seat belts I have would fit them ither..).so,,,any one got any other ideas of where to put the fasteners so not to be banging my console dragging them over the top of it..? that's saying I put them on the floor behind the console..
When you learn a thing a day you store up smart. |
02-26-2015, 08:30 PM | #2 |
Re: Console Seat Belt fastener holder
Sorry, I have a console and seat belts but don't know what you're referring to about hooks, because I'm not sure what you mean by holding the belt fastener, because I don't know what the belt fastener is.
So I'm a couple of steps behind you, but if you can maybe reword or post a pic, I'll do my best...
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
02-26-2015, 08:32 PM | #3 |
he's talking about the part the seat belt hooks into i believe. you could always just tuck it into the crack between the best back and the seat bottom.
02-26-2015, 08:37 PM | #4 |
Old member
Find some elastic with velcro and slip it through the seat back and bottom where it hinges. Then just loop the seat belt through it. That will hold it up in place.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
02-26-2015, 08:48 PM | #5 | |
Andy ,,I need a picture drawn up for what you describe ,,it might do the trick but it is the buckle and it is heavy,, I listening,,just cant make a visial ,, lol
02-26-2015, 08:55 PM | #6 |
Are you looking for those shown on my console below? If so, I think it was the 68 and 69 Cutlasses, Skylarks, etc. that used them for both the front and back seats. I saw some on the parts board a couple years ago. These were for trucks with factory shoulder belts. All mounting dimensions are in the assembly manual.
EDIT: Post 41 in this thread shows installation location. http://67-72chevytrucks.com/vboard/s...=649257&page=2 More info in this thread with pics. http://67-72chevytrucks.com/vboard/s...d.php?t=267505 Last edited by FirstOwner69; 02-26-2015 at 09:04 PM. |
02-26-2015, 09:03 PM | #7 | |
Old member
On the side of the seat facing the center of truck. The seat seperation there should be a hinge to fold the back forward. Take some velcro elastic either or and wrap around it. Then take the seat belt buckel and slip through it like a noose and let the buckel dangle. then when you are geting in just lift it up and hook it. It will always be at the same spot no mater where the seat is.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. Last edited by Andy4639; 02-26-2015 at 09:13 PM. |
02-26-2015, 09:07 PM | #8 | |
02-26-2015, 09:12 PM | #9 |
The plastic tab fits tightly into the buckle slot the male seat belt end fits into. The buckle internals rattle like mad however. Did you see the edits I added to my post?
02-26-2015, 09:24 PM | #10 |
SWB 4x4 Collector
Vans of the same era had factory color molded rubber pockets that would work too. Trevor
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
02-26-2015, 09:39 PM | #11 | ||
After I get my seats set in place with the console sitting between them ,,I will know whether or not there is enuf room for cup which I think I'd prefer..
02-27-2015, 10:02 PM | #12 |
Here's asking if what I am about to do is copacetic with the most of of you.. ( my dad used to use this expression ,(copacetic )
Drivers seat outer front bolt hole is to be 1 1/4 inch straight out with from where the bench seat bolt was,, Passenger seat front bolt hole is it to be 3/4 inch straight out from the bolt hole from the bench seat To get the spot to drill the holes for the inner front bolt holes that I will use for the bucket seats ,,I take a straight edge and extend a line through the center of the existing bolt holes from the bench seat used and use that them holes as a guide to set my inner bucket seat bolt hole at.. do this on both sides (driver /passenger )for the front holes . I have a problem with the release of the drivers seat to move the seat forwards or backwards,, the wire running across does not pull the lever for the inner slide enough and there fore hangs up..I found that if I bend the wire that runs across between the inner and outer slides ,,then it releases and catches fine,,but,, is this a common thing and I will be have to be careful and keep it bent to work ,,or is there a fix better than the bending of the wire? One more thing..the drivers seat does not sit down with all 4 legs touching (3 up one down in rear )and to make this happen I can bolt just is down,, just wondering if this is common thing with these bucket seat frames for the drivers side? that should about do it ,,just checking with you who have been through this and can shed some light on my questions .. thx for reading this far ,I know its sorta long..
02-28-2015, 01:25 AM | #13 | |
You probably meant to post this in your thread on mounting the seats. Nonetheless, what you suggest regarding how to locate the holes seems logical/copacetic. All the front holes are alined. However, I cannot vouch for the measurements at this point. I assume you've gleaned this from the other thread and links provided there. After installing the front bolts, use the rear holes in the mounting brackets to spot the rear holes. Then remove the seats and drill away. I wouldn't worry about one leg of the seat not touching the floor assuming it's not a huge gap. Start the bolt and pull it down. I don't think mine all touch when loose, but the one that doesn't is probably less than 1/2" off the floor. Just bear down on the seat(or have someone sit in it) and tighten the bolt. I seem to recall just bowing the wire a couple times in 45 years to fine tune the center release on the driver's seat. It also helps to push the seat back as you pull the release lever. The spring under the seat is much stronger than required for the relatively light weight bucket seat. |
02-28-2015, 01:56 AM | #14 | |
02-28-2015, 09:12 AM | #15 |
The holders shown by First Owner were used on basic K/5s with utility seats or optinal bucket seats. The buckets are the same seat as the scrolled CST that came with console, but with a basket weave pattern such as on bench seats. Since utility seats and base buckets didn't include a console these plastic holders were screwed to the front inside bottom corner of the seats. The trucks with console have holders built-in because back then you just set your beer between your legs
Copaesthetic is the opposite of funkadelic, but I don't think your dad used that one
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 02-28-2015 at 09:17 AM. |
02-28-2015, 10:14 AM | #16 | |
02-28-2015, 10:35 AM | #17 |
Wikipedia:
"Funkadelic is an American band that was at its most prominent during the 1970s. The band and its sister act Parliament, both led by George Clinton, began the funk music culture of that decade." |
02-28-2015, 10:46 PM | #18 |
Hah, I remember the band. I think it was some guy I worked with at one time used copesthethic as alright and funkadelic for messed up. Also, hunkydory for alright and catawampus for messed up
