01-27-2015, 04:50 PM | #151 |
Re: Project Mr. Green Jeans (now 5.3 LS turbo build!)
The built 350 is for sale to help fund the 5.3 build. Details in the for sale section here. Video at http://youtu.be/D_jtkAfzvLs
- 1981 Sierra 454, NV4500 swap - 2006 Z06, 25k miles - 1973 Nova - Project CarNova Virus on Youtube |
02-24-2015, 04:35 PM | #152 |
350 sold at the end of January... Yay!
Ordered today: LS9 camshaft PN 12638427 (only $105!!!) LS6 springs (80-something for the set) LS2 timing cover PN PK12600325, EDITED:gear PN 12586481 is wrong! Use 12576407 for non DOD engines!, LS2 sensor PN 12591720 LS2 timing chain Summit Racing PN SME-143012 Full gasket set ($247 from Rock Auto) Hopefully this weekend I won't be sick (been sick since end of January) and can get the 5.3 torn the rest of the way down and cleaned. Been too long since I've been out to the garage to play!
- 1981 Sierra 454, NV4500 swap - 2006 Z06, 25k miles - 1973 Nova - Project CarNova Virus on Youtube Last edited by bnoon; 12-23-2015 at 02:13 PM. |
02-26-2015, 01:37 PM | #153 |
Ordered today: PSI harness with LS2 timing sensor mod and AC signal.
Also, spoke with Chris Lund at Lund Automotive out in Waukee, IA about their tuning services and dyno time. Since I'm somewhat familiar with the HP Tuners software, I should be able to get the base NA tune done myself, but once I add boost I'll need some help. The guys at Lund really seem to know their stuff!!!
02-26-2015, 05:06 PM | #154 |
Sweet man!
Current Build 89 s10 ecsb 2wd 4.3/700r4 50k OG Miles Instagram- shaggin_s10 '86 Chevrolet C10 Custom Deluxe - Gen V 454 - 4l80e - welded 12 bolt (Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=611611 ) SOLD |
02-26-2015, 05:13 PM | #155 |
6>8 Plugless........
The guys at Lund are great guys! Chris and his dad are nice to work with. We had a dyno day there years ago and they were very accommodating.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
02-27-2015, 09:41 AM | #156 |
Nothing to show that's new. All of the stuff I ordered will be pictured once it comes in LOL!
I've never had any shop do any work on any of my cars/trucks except for warranty work, so this is a big step for me. I can do very basic tuning for NA engines, but I knew I'd need a relationship with a tuner to get the turbo setup once it goes on later this year. Turbo won't be done by Power Tour sad to say, but a nice healthy 5.3 with a 4L65E will still be a nice cruiser for summer.
02-27-2015, 04:40 PM | #157 |
Ordered today: Monster SS 4L65E transmission.
02-27-2015, 05:07 PM | #158 |
Outstanding! Did the drive shaft work?? Mike
Instagram @HomeBuiltC10s Dads 79 GMC Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=642929 1978 Silverado Build http://67-72chevytrucks.com/vboard/s...d.php?t=756016 |
02-27-2015, 05:08 PM | #159 |
I don't know yet. Worst case is it should be the right length and I would have to use different U-joints if something wasn't right. Nothing is in the truck yet, barely ordered it. Once I get everything I will know for sure. Should be the right one though.
02-27-2015, 05:10 PM | #160 |
Didn't know which truck it was going into. Good luck.
02-27-2015, 07:47 PM | #161 |
Using in for this one. I'm hoping the spline is the same as the 700r4 and th350 slip yokes are, otherwise I'll have to swap that yoke out. Length should be right though.
03-02-2015, 11:53 PM | #162 |
Finally current.
03-04-2015, 03:14 PM | #163 |
Let me know how that Monster trans does.
03-04-2015, 04:59 PM | #164 |
I had one in my '03 Silverado SS and it was VERY nice! Had a 3200 stall and awd with about 500 horse. A 4500 pound vehicle has no business being as quick as that thing was! I only ever had one issue with it and that was the 1-2 accumulator kept cracking and it was a factory aluminum replacement/upgrade part compared to the stock plastic one. They later came out with a billet version that I had no issues with at all.
03-06-2015, 06:45 PM | #165 |
Think I might go that route, I don't know yet.
03-06-2015, 09:46 PM | #166 |
They're great to work with, will answer questions, what parts to avoid even if you don't buy everything from them. I called them probably 5 or 6 times before I got my first one even ordered. It was an easy decision this second time.
03-09-2015, 10:31 AM | #167 |
Things starting to happen for the 5.3 now that Red Ryder is gone to a new home. I got the balancer off after breaking my old Craftsman 6" puller after 25 years of service. The center bolt broke right off. All Sears had in stock were 2 jaw pullers and one tiny little 4" 3 jaw puller for $49.99. I went to Harbor Freight not expecting much in the form of quality on this type of item, but they were actually really nice quality. Fine threads which were stronger than the coarse threads on the old Craftsman one. The set was $29.99 from HF and had 4 pullers... one 8", one 6", one 4", and one 3". Home run for HF!!!
03-11-2015, 10:37 AM | #168 |
5.3 disassembly. Rod and main bearings look brand new, but cam bearings are shot. Ordered new cam bearings and new piston rings today. I put a fresh hone on all of the cylinders to clean them up and help seat the new rings, shown with 2 done and 2 not done. I oiled everything down with straight 30 weight non-detergent oil to avoid surface rust and not attract dirt.
03-11-2015, 03:19 PM | #169 |
Not to bad, I've seen a lot worse!
03-12-2015, 09:52 AM | #170 |
Cam bearings are pretty toasted as mentioned though, which I guess is a pretty common problem on all LS style engines. I've got new ones coming, now I just have to make something to install them!!! No way am I buying a $200 cam bearing tool that's just a slide hammer with one end machined to fit the cam journals and bearing inside diameter. Nothing too special about that...
03-12-2015, 03:23 PM | #171 |
Ah specialty tools. If they weren't around what could we complain about? looking forward to seeing what you design for the install
Project NewType 1972 Chevy C/10 Cheyenne Super ( Daily Driven Showtruck ) http://67-72chevytrucks.com/vboard/s...d.php?t=507903 Project Great Grandpa's Legacy 1973 Chevy C/10 Cheyenne ( Current daily driver collecting big time parts ) http://67-72chevytrucks.com/vboard/s...89#post7084289 - Dylan (209)-985-7721 |
03-13-2015, 09:47 AM | #172 |
Harbor Freight has an axle bearing type install kit that I may modify to work. It's under 40 bucks, add in some all thread and a few nuts and I'll be under 45 total. We'll see. More pictures to add here in a bit too.
03-13-2015, 10:50 AM | #173 |
I got the pistons put into a 5 gallon bucket to try to free them up on the rods a little bit and to get rid of the carbon buildup in the ring grooves using mineral spirits. I looked up cheap parts soak ideas on Google since I didn't want to spend $$$ on actual parts dip (and since the EPA took all of the good chemicals out of those anyway, I thought I'd try something new). From the dark color in the bucket after about 10 seconds, I'd say it's already working. Covered with a plastic sack and electrical tape to seal it off. Mineral spirits stink unless you buy the double price stink free kind.
I also got the new rings and cam bearings delivered as I was doing the piston soak. YAY! The LS9 cam and LS2 engine cover came in the other day along with the new LS6 springs. WAHOOOO!!! Ordered today: Close out gasket kit closeout item from Amazon at only $110, last one on the shelf. Less than half the price of any other set I've seen. LS2 timing chain, single roller, from Sealed Power via Rock Auto. Closeout item as well that had an issue with shipping, so Rock Auto upgraded me to the Cloyes chain for the same price because they can ship that one today. Dakota Digital speedometer adapter driver ECD-100 to drive the mechanical speedo from the 4L65E that has a digital output. Got it from Amazon 20 bucks cheaper than from Dakota's own site and they are the seller on Amazon too. Yay me for checking!!!
- 1981 Sierra 454, NV4500 swap - 2006 Z06, 25k miles - 1973 Nova - Project CarNova Virus on Youtube Last edited by bnoon; 03-13-2015 at 11:02 AM. |
03-13-2015, 11:34 AM | #174 |
Ordered today: Airtex E8248 external fuel pump from Amazon (but researched on Summit Racing for specs). 70 GPH at 120 PSI capable for only 69 bucks. Should support in the neighborhood of 600-700 HP which is what I'm shooting for. May have to modify the stock pickup and run a second pump and line and larger fuel rails, but we'll see what our limits are here first with one pump and one line.
03-13-2015, 03:38 PM | #175 |
Your just ordering all kinds of parts.
