4 row radiator, gap @ bottom of shroud
I recently replaced the radiator in my '68 with a 4 row from a big block truck.
I also replaced the radiator holding cups, and top clamps, with the bigger ones. I had to slightly modify the core support, (a couple small notches) to accommodate the larger bottom cups. With this new setup, the bottom of the fan shroud won't bolt op tight to the core support, it leaves about a 1/2 inch gap. I have a couple questions. 1- Did trucks with 4 row radiators get different core supports, to accommodate the larger cups and shroud gap. or, 2- Were the core supports factory modified and a slightly different shroud used? It's not a big deal. nothing a couple spacers couldn't solve, I was just wondering |
Re: 4 row radiator, gap @ bottom of shroud
Look at the parts diagram in the LMC Truck catalog. It should answer all your questions.
Scotty Baccus |
![]() Join Date: May 2010
The core supports were the same but modified at the bottom much as you've done. On mine an inch or so of the lower vertical lip was bent toward the engine on each side to accommodate the longer cushions. As I recall my early 69 originally was screwed to the core support at the bottom. I don't know if mine was unique in that regard, but I think it was later that they started using a clip on each side that was an extended version of those used for the smaller radiators. I don't know if they are reproduced. Here are a couple of links.
Disregard those I mentioned in post 10 of this link. They are not the extended clips. http://67-72chevytrucks.com/vboard/s...d.php?t=469356 Pictures http://67-72chevytrucks.com/vboard/s...d.php?t=448040 |
Yup! That's the thing!
Sweet, thanks :-) Where do I get one? |
#6 | |
