Old 03-02-2015, 08:18 PM   #1
Bladeboy1998
manual trans with overdrive?
Are there any (reliable) manual trans for our trucks with an overdrive? I see the gearvendors overdrive for the sm465 but I wouldnt want to spend that much If I really only need it a couple times a year. I do about 500 miles both ways of highway 2 times a year to my cottage and am pulling a boat. I want a 67-72 but this might be a turn off. I still need a truck so I'm just voicing my questions.
Bladeboy1998 is offline   Reply With Quote
Old 03-02-2015, 08:59 PM   #2
hugger6933
Re: manual trans with overdrive?
Depending on how heavy the boat is a NV 3500 might do or the NV 4500 is very popular and it has a removable bellhousing and the T-5 would also be an option as well it your not gonna throw a lot of power at it. Jim
hugger6933 is offline   Reply With Quote
Old 03-02-2015, 09:01 PM   #3
farmallboy15
Check out advanced adaptors. They have a gear splitter giving you 1:1 and overdrive in all gears. Not too expensive either. "ranger gear splitter"
70 GMC K2500
82 GMC K3500
09 GMC 2500HD 4x4
farmallboy15 is offline   Reply With Quote
Old 03-02-2015, 09:12 PM   #4
Bladeboy1998
I don't know the exact weight, it is a 21' mastercraft prostar 190, full fiberglass, I want to say around 3k plus I fill it with food and gear. So I would say a total weight for 4 thousandish. My trailer isn't tongue heavy so not really a problem there. I am looking at the ranger gear splitter right now, it looks promising. engine wise I was thinking mild 350, not looking to win a race, but it needs to be 4x4 compatible.
thanks for the help guys, keep them coming!
Old 03-02-2015, 09:19 PM   #5
BLT gmc
If you want to use your SBC, SM 465 and current t-case, you could not go wrong with the Torque Ranger. Yes, you will have to move the cross member and lengthen/shorten drive shafts.
BLT gmc is offline   Reply With Quote
Old 03-02-2015, 09:21 PM   #6
Bladeboy1998
I'm liking the sound of that more and more. I can do the cross member, but how much would it cost to shorten the driveshaft(ballpark)? I don't think I could do that myself.
Old 03-03-2015, 08:45 AM   #7
Mike C
Mike C's Avatar
Is your truck 2 or 4 wheel drive? Small block or big block? Tire? Gear? SM465 or 3 speed?
May be another way to get there depending on what setup you have.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 03-03-2015, 02:23 PM   #8
Bladeboy1998
I don't have a truck yet, but when I do it will only have a mild 350, 4x4, 31 or 33" tires, 410 with a locker, and an sm465.
