C notching the frame?
I've searched the forum looking for how low you can go without C-notching the frame and only came up with newer vehicles. There are some great reenforcement threads on how to beef it up. So looks as if you can 4 or so inches and still have 4 or 5 inches of travel. What have you guys done?
Jeff ![]() |
Re: C notching the frame?
IMO, the most you can take out of the frame without changing the top rail is 3 inches. That's what I did and boxed about 6" on either side of notch. Have about 3 1/2 inches of travel and you can see how mine sits. I did raise the bed 2 inches and could have modified the top frame rail to take advantage of that but didn't. I think BAM did. You might look at his build sheet.
How much did you lower it tho? I'm looking to lower mine 4" and want to if most or none are C notching at that distance. Sorry if my question was unclear. Mine is a 53'.
Mine sits rather high because it has 255-60 15 tires but you can see where the center of the axle sits and I have between 2-1/2 and maybe 3 inches of clearance between the axle and the frame.
![]() ![]() This is a stock 48 sitting at stock height for comparison. ![]() I'd say my truck is probably lowered 4 inches in back but without a notch the axle hits the frame way too often.
![]() Join Date: Jul 2012
Mine
Thanks guys!
