Vintage 4x4s
Would you buy new tires
So I bought a truck a couple years ago, and it had almost new BFG AT load range E's on it. I took them off since they are 285's and a tad to big for towing heavy with just a smallblock. Now that I've got the tires off the rim I see there are small patches on the insides of the sidewalls. Looking close, there is a 1/2" slice on the outside of each that was glued/sealed shut when the patch was placed.
So, would you worry about them? My brother worked in a shop doing tire repair when he was younger and he thought they would be fine on any truck that wasn't hauling heavy. I could run these on a occasional use truck but if there is any chance of a blowout I won't. I don't care if they would leak, but o only care if they would fail catastrophically. Being a heavier truck tire, it doesn't seem like they would under lightly loaded conditions. Thoughts?
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ![]() 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
Re: Would you buy new tires
I think the fact that you're asking answers your own question. Maybe as a spare to get you home, but that's about it. Replace them for regular use.
-Josh
1967 Buick Special wagon 1968 Jeep Wagoneer 1958 Chevy Panel Truck 2017 Suzuki M109R |
I agree with Josh, spares yes anything else no.
Racerface Wellington, Ohio ![]() GO BUCKEYES!!! Toys: 68 C-30 327-400turbo 68 C-30 Open Road Camper 327-400turbo 81 GMC Sierra 1500 250-350turbo Long Bed 83 K-10 4X4 Scottsdale |
Please scrap them for the safety of others------
Check out what the tire repair authorities say:
http://www.discounttire.com/dtcs/infoRepairingTires.do and who Discount Tire listens to: http://www.rma.org/wp-content/upload...lchart1111.pdf
1971 Bone Stock C10 project "Jake" 1997 Sierra SLT factory short bed "Silver Bullet" |
X3 what Josh said.
I call sidewall patches "time bombs" It's always easy to tell someone to just buy a new one when it's not your money! But I highly recommend a new tire. The damage it could do to your truck or someone else if you have a blow out on the hi way will far surpass the cost of a new tire.
The bitterness of poor quality lingers long after the sweetness of a low price is forgotten. |
The question that you need to ask is would you let your son or daughter drive the truck with those tires and not worry? You can think about that on the way to the tire store. I know I always have people ask me about the trucks I rebuild about checking this or that and I tell them I drive everything a good while before I sell it. I also buy things at the sale that I would want to drive. I know that limits my market but I buy every thing like it is gonna be mine forever cause you never know when it might be. It is the same about the safety of them I build every one like my girl or my son my drive it cause they might. Jim
This might[most likely would] be a different issue if it were in the tread instead of the side wall. Jim
![]() Join Date: Jan 2001
If you're only going at slow speeds for short distances, I might chance it, but I wouldn't risk it for anything more than that.
20' Daredevil (Ret)
![]() Join Date: May 2003
Run 'em only if you're putting around farm fields at very low speeds. For any other use, replace 'em.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
I am no authority, but I can speak from a sort of experience.
My last two punctures were in the tread but because they fell within 1" of the sidewall Costco wouldn't repair/patch them. The first time it happened I thought that Costco was trying to force me into new tires so I took the problem to a local chain tireshop, and they wouldn't do it either. Another time the flat was from clipping a curb with the sidewall and it wouldn't hold air, and then I was told flat out that the tire was a loss. The explanation I got is that the sidewall isn't constructed to be remedied by a patch. And like the posters above, a failure in the sidewall can be nasty.
'69 3/4t 2wd 350 V-8, LWB Auto trans, power steering |
I was in the tire biz for twenty years and you didn't repair sidewalls in passenger tires!. In larger truck tires you can do whats called a "sidewall section repair" but its not recommended. Sometimes people who have had their tires slashed by a person with a knife would bring them in for repair and we would send them out to the retread plant to do sections, but there would be no warranty given on the repairs. As stated ok or a bush buggy.
GM 502, 4L80E spd auto, Compushift II, 2500 Stall, mini tubbed, 12Bolt 3:73 Moser Axles, MSD, 345/55R15 BFG Drag Radials, 3" Flowmaster Exhaust. 4" Chop, frenched and shaved everywhere, custom Pearl Yellow paint. |
I blew a 285 out one night at 2am in the mountains near Clear Lake in Cali. My buddy had to reach over and help me hold my steering wheel to keep the truck from going over the mountain.(Ozzy reference) Every time it came back around it was hitting tie rod center link and would jolt toward the roadside which was a nice steep cliff sort of drop-off. This was the second one actually. The first one was on the San Mateo bridge and almost flew off that one. So NO! I wouldn't run em. In fact they should be destroyed so No one else can run them. Roll your truck around on them but once it's running do not be tempted to destroy all your hard work with a simple run around the block.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
What he and others said-only good for rolling around
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
#15 |
![]() Join Date: May 2013
Get new tires , sidewalls are not supposed to be patched , maybe with a small puncture you could get around that rule "I would not" ,but with a slice ,, no way ,, get rid of them .
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
#16 |
Vintage 4x4s
Wow,i didnt think there would be unanimous agreement to keep them off the road . I will use on my offroad farm truck, since they have great tread and are $300 each.
So now Im curious why a shop repaired them in the first place . Maybe because they are E rated truck tires? I can post a pphoto but it sounds like it not about the amount of damage, just that there is damege deep enough to possibly hit a cord.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ![]() 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 Last edited by Vintage Windmills; 03-03-2015 at 11:58 AM. |
#17 |
The Older Generation
When I get a tire like that I mark them bad with a paint stick and use them for rollers. LockDoc
#18 |
20' Daredevil (Ret)
The repair may not have been done by a tire shop.... some guys have mounting equipment at home.
#19 |
Well this may be a little different from some but when I go my wife of many years goes 2.
I think to much of her to risk it. She can not be replaced , tires are cheap, I would buy new ones. |
#20 |
Active Member
![]() Join Date: Oct 2009
Hi, I work for. discount tire for 33 years I wouldn't want the tires on my truck. The side wall Flexes to much. not safe at all.
#21 |
Vintage 4x4s
I was thinking about spray painting them to make it obvious unlike when i bought the truck and drove it home for hundreds of miles on these tires. Practically invisible from outside.
#22 | |
Spray paint whitewalls on them... ![]() LockDoc
#23 |
#24 |
any sidewall repair is temporary at best and unsafe
