Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 03-05-2015, 09:00 AM   #76
cmabolt
cmabolt's Avatar
Re: 72 chevy modern swap
[quote=SDfarms;7076712]
Originally Posted by cmabolt View Post
Lance, here are the pics your requested. There are 4 shots that show the frame clearancing and proximity of header outlet to hydraulic clutch slave.
Chris thank so much for the pictures! I would jump right on the big block hugger but im curious if the factory flange bolted to them as well?? I'm just trying to get away from cutting the frame and spending another 70.
No problem at all Lance. Good luck on your choice of header. BTW, nice couch in the garage. I think I need one of those in my garage.
Chris
Project Reno Build http://67-72chevytrucks.com/vboard/s...d.php?t=392636
Easier to beg forgiveness than ask permission!
cmabolt is offline   Reply With Quote
Old 03-08-2015, 05:36 PM   #77
SDfarms
SDfarms's Avatar
Got my fuel supplies!!! Went with a tanks inc fuel pump, supports up to 630hp just what i was looking for! Decided to go with russell braided fuel line. I asked around and everyone told me to try to get the least amount of connections in your fuel system so i went this route. It was within 50 dollars of using aluminum hard line with braided line on both end.
SDfarms is offline   Reply With Quote
Old 03-08-2015, 05:44 PM   #78
SDfarms
SDfarms's Avatar
The tank and the mounts i made for them. Pretty easy getting it mounted up.
Old 03-08-2015, 05:51 PM   #79
SDfarms
SDfarms's Avatar
I seen A guy do this on his build and I liked how it looked. Make sure ya keep the tap straight cause it like to tip.
Old 03-08-2015, 05:59 PM   #80
SDfarms
SDfarms's Avatar
Got the ram 1550 bolted up! And the Right bellhousing is here
Old 03-08-2015, 06:14 PM   #81
SDfarms
SDfarms's Avatar
Hydraulic master cylinder all mounted up. Looks nice sitting there.
Old 03-08-2015, 06:28 PM   #82
SDfarms
SDfarms's Avatar
My 6.0 was equipped with a steering reservoir for a hydroboost. Lot of people people like the hydroboost because its pumped up on psi so brakings a lot easier. I pulled mine out of a 89 1 ton, and i was looking it over and i took the mounting plate off. Stared at it awhile, turned it 180 degrees flipped it and drilled 2 holes. Would you look at that!
Old 03-08-2015, 06:38 PM   #83
SDfarms
SDfarms's Avatar
I took the old brake booster rod and cut of the threaded end. Then cut the hydros rod, and welding the threaded end to it. Worked really good, but you will have to round the hole in the firewall to get he hydros nut threw. Also the master cylinder off the 89 has the same bore as the 72's master.
Old 03-08-2015, 06:41 PM   #84
SDfarms
SDfarms's Avatar
more..
Old 03-08-2015, 06:47 PM   #85
SDfarms
SDfarms's Avatar
Pacific fabs crossmember mounted up. It moved the engine ahead 2 1/2 inches so that the tranmission would drop on its own crossmember.
Old 03-08-2015, 06:55 PM   #86
SDfarms
SDfarms's Avatar
Modification i had to make on the crossmember so the motor mount would bolt on. I got sick of the cab on the frame so the heck with it. IT GONE!
Old 03-08-2015, 07:02 PM   #87
SDfarms
SDfarms's Avatar
Fuel system assembled. Happy with what it looks like.
Old 03-08-2015, 08:39 PM   #88
rambler
MOVE OVER
rambler's Avatar
Subscribed
No matter where you are..... There you are...
Buckaroo Banzi
rambler is offline   Reply With Quote
Old 03-08-2015, 09:57 PM   #89
cmabolt
cmabolt's Avatar
Now your cookin with gas! By the looks of it, things should work great. Keep at it. I think this part of the build was the most fun.
Chris
Old 03-08-2015, 10:25 PM   #90
First c10
First c10's Avatar
Hey Lance looking good I have some of the same stuff going on as you thanks for the pictures Great Job...
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 03-09-2015, 11:45 AM   #91
SDfarms
SDfarms's Avatar
Threw the np205 on the transmission. All the bolts went in, but one.. Took me awhile to get it figured out. I had to oval out one of the holes. Nothing hard. Looks great and in the exact same location. The tcase cross shift bar had to be grinded down just a wee bit so it doesnt hit the adapter housing.
Old 03-09-2015, 11:53 AM   #92
SDfarms
SDfarms's Avatar
Got it cirlced
Old 03-11-2015, 10:30 AM   #93
SDfarms
SDfarms's Avatar
I'm having headers problems boys, I noticed on Chris' reno project he had tried hedman block headers. The thing i dont like about them 1/4 flange, 18 gauge pipes, and 3 inch collecter. Ive been looking at hookers block hugger which are a little better 5/16 flange, 2.5 collecter, but only 18 gauge pipes. http://www.summitracing.com/parts/hok-2313hkr/overview/
Old 03-11-2015, 12:45 PM   #94
First c10
First c10's Avatar
This is what I used on my C10 and bought a set for the K10
Ebay headers
GO GO!!!
Old 03-11-2015, 12:51 PM   #95
SDfarms
SDfarms's Avatar
Those are really nice, problem is theyll dump on my slave
Old 03-11-2015, 03:25 PM   #96
First c10
First c10's Avatar
OH Right I forgot you are a manual!!! I wonder if the make center discharge ones???
GO GO!!!
Old 03-11-2015, 03:30 PM   #97
First c10
First c10's Avatar
Lance what year gas tank is that out of? my tank is out of a 87-91 surburban and it has the in pump tank I just installed a walbro pump in the stock location. I like the in tank pump assembly you installed..
GO GO!!!
Old 03-11-2015, 11:24 PM   #98
SDfarms
SDfarms's Avatar
73-81 blazer 25 gallon tank, bought it off ebay $86 buck is what it cost me, i started out with a 40 out of a suburban an decided it was way to big. I love this one, and its just the right size. But 81-91 are the same other then they are made for efi. Unless yours is 31 gallon?
Old 03-11-2015, 11:26 PM   #99
SDfarms
SDfarms's Avatar
I talked to the guys at jegs, and they told me to try there set out. If they dont work send them back. Guess we'll see haha
Old 03-11-2015, 11:44 PM   #100
First c10
First c10's Avatar
I got a 31 gallon off eBay for 96$ shipped. So I bought the sender for the efi from Classic parts for 48$ Straps for 28$ and a walbro pump and kit for 80$. Since the picture I changed the clamps added a different rubber mount and screen.
GO GO!!!
