03-07-2015, 02:56 AM | #26 |
1961 crewcab
Re: Top removal 63 C-20
"note mice nest on roof "
I think they all came with factory installed mice and a nest! those things have totaled more cabs......
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
03-07-2015, 02:02 PM | #27 |
03-07-2015, 02:06 PM | #28 |
I would look into some kind of auto body epoxy they use now instead of all of the welding....
03-07-2015, 07:10 PM | #29 | |
..again thanks for that. will have to weld up the holes in the drip rail i made when removing the original roof first then I plan on glue the new roof on .
My Spelling is Not Incorrect...It's 'Creative' . . 1966 C-20 .....Swap 91 G-30(5.7 FI)/4L80E http://67-72chevytrucks.com/vboard/s...d.php?t=789617 59 Viking Revival .. http://67-72chevytrucks.com/vboard/s...d.php?t=632341 |
03-09-2015, 08:32 PM | #30 |
Here's a trick for other people if they are replacing the outer skin.. If u use a cut off wheel with a thicker wheel on it u can grind the spot welds.. But that's ONLY on the skin that you are getting rid of u don't do it to the "new" skin.. Grinding them will take way less time than a normal spot weld bit... Im a collision tech and I do it once or twice a week on panels definitely saves time..just my 2 cents
1963 GMC swb sbw 5.3/4l60e porterbuilt From middle Tennessee 60-66 hood for sale or trade for bench seat rust free nose little pin holes on top message for more details.. |
03-09-2015, 11:00 PM | #31 |
used my flat hammer to remove some of the small dent in the doner top
some welding and grinding mostly the holes i made to remove the old top and the rusted front corners of drip rail . . . . .
03-10-2015, 05:59 AM | #32 |
It's alsways something.....
Kudos for doing this repair the right way- and for documenting the process for others
1968 RS Camaro 'Vert Matching number 327 and M21 Muncie 1968 C10 Black with red interior and orig paint. 5.3 / 4l60e,3:73 POSI 17" Torq Thrusts 1968 CST 514 Red with black interior. Buddy Buckets, Factory A/C, PS, PB- 20" AR custom shop TT, 5.3 and 4l60e |
03-19-2015, 08:22 PM | #33 |
Treated the underside of the top with rust converter Phosphorous acid
. then sealed it with Rust-loc . . . .
08-13-2015, 08:47 PM | #35 |
Haven't worked on this project in a while "no excuses"
I wanted to add this post link because some great advice and picture courtesy of LT1 Burb . http://67-72chevytrucks.com/vboard/s...d.php?t=679312 .
10-11-2016, 03:40 PM | #36 |
