Old 03-08-2015, 03:04 PM   #1
Woodnears
Suggestions on tire size with porterbuilt
Hello all, I'm running full porterbuilt extreme front and back. It's time to get tires for the truck. I'm running the gm transits, as far as I know they are 22x9 with 6 back spacing. Any suggestions on tire size. I am not good at all sizing tires and could use some help here to keep me from ordering multiple tires. Thanks for the help in advance guys
Woodnears is offline   Reply With Quote
Old 03-10-2015, 05:53 PM   #2
Slick67
Sofa King Crazy!!
Slick67's Avatar
Re: Suggestions on tire size with porterbuilt
Hey there! I would play musical tires at the tire shop, most of them will work with you on that if it means a sale. They may also have a tire sizing tool which most tire shops have. It helps them determine exact tire size by bolting it to your lugs and measuring the entire area.
You found the Tater.
My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650
My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650
67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS.
1972 2wd Blazer "Porterbuilt and Sloshed"
Slick67 is offline   Reply With Quote
Old 03-10-2015, 11:41 PM   #3
andrewmp6
The dropmember is designed to lay frame up to a 28 inch tall tire.If your running any spacer or adapters for those wheels that can change things.
Old 03-11-2015, 12:36 PM   #4
Woodnears
I heard back from porterbuilt on this and they suggested 265/35/22
Old 03-13-2015, 04:04 AM   #5
cshetsky601
cshetsky601's Avatar
I have the extreme front and rear drop members as well and I'm running a 285/30/24 out back which is around 30.7" tall and a 265/35/22 up front which is right about 29.3" tall. I have issues with my front tires hitting my hood but my truck is body dropped as well.
cshetsky601 is offline   Reply With Quote
Old 03-13-2015, 02:11 PM   #6
nlped
nlped's Avatar
I'm subbed as I'm building something similar.
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 05-24-2016, 07:48 PM   #7
cook2199
so 22x9 is doable? I'm running extreme front n back with PB narrowed arms. Im ready to order my wheels just want to be sure before i ordered that I wont run into any problems up front. Thanks.
cook2199 is offline   Reply With Quote
Old 05-24-2016, 09:37 PM   #8
bbbc10
Diggin The SquareLife
yes
bbbc10 is offline   Reply With Quote
