Old 03-08-2015, 10:37 PM   #1
MAC71
MAC71's Avatar
Oil filter help
My 69 396 that I recently got and just rebuilt the engine on has a strange oil filter adapter. Also the by pass valve had come apart.
This next photo is a old adapter from the 350 from my 71 c10. It spears this type will work. Am I missing somthing here.
Mike
1971 C10 350
1969 C20 396
1979 Corvette L-82
MAC71 is offline   Reply With Quote
Old 03-08-2015, 11:09 PM   #2
leadfoot067
horsepower junkie
Re: Oil filter help
yep the small block unit is the same..as long as the 396 block has the sealing surface for the filter..
67 short wide box,350/700r4/3.73posi
71 olds cutlass "S" mom bought new..12.30s@113MPH
leadfoot067 is offline   Reply With Quote
Old 03-08-2015, 11:16 PM   #3
FirstOwner69
FirstOwner69's Avatar
Re: Oil filter help
FYI... My 69 350 3/4 CST/20 came new with a cartridge type filter. I replaced it in the 70s with an aftermarket adapter and spin-on filter. The filter required with the adapter was actually a Ford part number. Perhaps the 69 396s were in the same boat and someone changed yours out. I THINK the 70s or 71s started using spin-on filters.
FirstOwner69 is offline   Reply With Quote
Old 03-09-2015, 02:48 AM   #4
mechanicalman
Re: Oil filter help
I think firstowner69 is right, but I find it confusing to see two oil filter adapters in the same picture, I don't know which one you had on your engine.
How about a picture of the mounting area without the adaptor installed on the 69 396 and tell us which adaptor came off that?
mechanicalman is offline   Reply With Quote
Old 03-09-2015, 07:17 AM   #5
Mike C
Mike C's Avatar
Re: Oil filter help
My '69 has the canister or cartridge type filter. I jacked around with the aftermarket spin on adapter for about 1/2 a day putting it on and taking it off 4 or 5 times. Never could get the POS to seal up.
Went back to parts store and got replacement filter and put the OEM back on. I wish you better luck with yours!
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 03-09-2015, 10:07 AM   #6
hamjet
hamjet's Avatar
Re: Oil filter help
Same style came on my W engine. thinking about keeping it, not that far yet. I suppose if it doesn't leak, I'll keep it..
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline   Reply With Quote
