03-09-2015, 08:27 AM | #1 |
Upper Radiator Hose Mod
Saw this picture on the internet the other day and would love to mod my upper radiator hose like this. I really like the hard tubing idea. Any ideas how to achieve this or how to go about starting it?
Thanks, Casey 71 Chevy C-10 SWB 350/400 PS, PB The Build http://67-72chevytrucks.com/vboard/s...d.php?t=584045 The Brake Upgrade http://67-72chevytrucks.com/vboard/s...d.php?t=695699 |
03-09-2015, 09:13 AM | #2 |
Re: Upper Radiator Hose Mod
The 4x4 trucks come that way.
03-09-2015, 10:10 AM | #3 |
Old member
I went to Lowes and bought a piece of aluminum-conduit. I bent it like the rubber hose and cut the ends off the rubber hose to clamp it together.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
03-09-2015, 12:31 PM | #4 |
03-09-2015, 01:40 PM | #5 | |
I don't trust the homemade ones because I've seen them fail AT LEAST a half-dozen times and they make a huge mess when they do fail. The good kits will usually have a bead on each end of the tube, that way there is no chance of the hose clamp being able to slide off the smooth surface.
______________________ www.northeastrodrun.com |
03-09-2015, 03:27 PM | #6 |
The factory 4x4 used metal pipe in the middle but it was straight. I'm an electrician. How about an 90 degree emt from your local big box home improvement store? Radius might not be tight enough though.
03-09-2015, 03:55 PM | #7 | |
03-09-2015, 06:03 PM | #8 | |
20' Daredevil (Ret)
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
03-09-2015, 08:48 PM | #9 |
What i meant to say was the 4x4 pipe is more of a straight shot, original post photo was not an oem 4x4 pipe.
03-10-2015, 01:49 AM | #10 |
That's a pretty damn good idea!
03-10-2015, 11:50 PM | #11 |
1969 RS/SS Z10 Camaro Pace coupe 1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218 1979 Mazda RX7 1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary 1999 Honda Valkyrie 2006 Corvette Z06 2010 BMW 650i |
03-11-2015, 12:03 AM | #12 |
C/10 junkie
There are some cool hose mods here
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" |
03-11-2015, 10:05 PM | #13 |
I like mine better! Go to Summit Racing Vibrant, Jegs or whomever and buy a 1-1/2 in diameter 90 bend, 4 clamps and 4 hose elbows. I got mine at Vibrant Performance but there's dozens of vendors for steel or Stainless Steel exhaust pipe.
03-11-2015, 10:12 PM | #14 |
It's just pipe. You can take a coat hanger bent to your desired angle and your piece of pipe to the muffler shop. they can bend it in about 30 seconds. The ided of putting a few small beads of weld around it about an inch in would keep the hose from slipping off.
"Life is too short to drive a boring vehicle". Later, Wayne |
03-11-2015, 10:46 PM | #15 |
Great info all
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
03-12-2015, 10:26 AM | #16 |
Be careful of what type tubing you use, as some will rust us pretty quickly with antifreeze flowing thru it.
I am currently working on having a stock type 4x4 hose redone in stainless steel, but we could make one in pretty much any shape/direction.
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White |
03-12-2015, 11:29 AM | #17 | |
Lmk if you start selling them!! Thanks |
03-12-2015, 11:59 AM | #18 |
03-12-2015, 01:23 PM | #19 |
All about them K’s
Let Me know too if you start selling them!!!
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
03-12-2015, 02:25 PM | #20 |
How are them Gates power grip hose clamps working out. Thought about getting some of those.
03-12-2015, 03:46 PM | #21 |
Old member
Mine was on the truck for several years and never failed. I did keep the clamps tight though and checked them when ever I changed the oil.
03-14-2015, 09:05 AM | #22 |
That is the plan. We are making a jig to build the first one.
03-14-2015, 06:33 PM | #23 | |
http://www.gates.com/products/automo...grip-sb-clamps Probably the best price I found was at Rockauto.
