03-09-2015, 08:46 PM | #51 |
Re: How to make door panels
First pic, I've trimmed off the excess material close to the staples.
Second pic, I've trimmed the material, applied glue, waiting to tack up. Third pic, here I've pulled material in place, and then stapled and trimmed. Forth pic, trimmed and glued the large end and waiting to tack up. Fifth pic, here everything is glued down, stapled and trimmed.
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
03-09-2015, 08:50 PM | #52 |
I'm going to take a break now, to watch Street Outlaws and the Fat boys, will return later and finish up todays work...Jim
03-09-2015, 11:36 PM | #53 |
Late, but let me finish this up.
First pic, picture isn't to clear, but wanted to show how you need to keep these corners as smooth as possible, and no bulk, so it sets in the panel flat. Second pic, with everything we did earlier on checking the size (see post #42), this panel should fit inside the main panel. Looks good here. Third pic, now I take the old template, lay in place and outline the back of panel. Forth pic, here you can see the outline. Fifth pic, Now spray the back side of design panel and the wood area of the main panel, and let it tack up.
03-09-2015, 11:55 PM | #54 |
First pic, Now put the panel in the opening and attach to main panel, keep some weight on the panel until your sure the two are glued together tight. You should be able try to move it, but it shouldn't.
Don't forget to change from 1/8" staples back to the 1/4" staples Second pic, Now flip the panel over, put some weight on the back of the panel as you staple the back around the outline. Third pic, same at the other end. Forth pic, I check to make sure the panel was secure, I pulled on it a little, and nothing moved. Here I've taken the armrest template and screwed in place to help hold down a little. Fifth pic, here I've glued the two strips to the material . This is where I quit for the night, will start again tomorrow, till then...Jim
03-10-2015, 09:15 AM | #55 |
That looks really good Jim. Any idea on how many hours you have invested so far?
03-10-2015, 01:44 PM | #56 |
Ray, I have to apologize for not seeing your post, it was in between my posting an update. I always like to show anyone, anything I know, not the best but fair work...Jim
03-10-2015, 01:46 PM | #57 |
Thanks Doug, I would guess about 20 to 25 hours over about 5 days. Not being real fast and taking time for pic, etc....Jim
03-10-2015, 10:04 PM | #58 |
My day as been for sh!t all day, and now the system is packed, tried to upload a pic and was only 40% in 5 mins. Will try later or tomorrow, sorry...Jim
03-11-2015, 11:17 PM | #59 |
Let's try this again.
First pic, applied glue to the curved edge of strip. You can see how I've cut "V's" into the end to help it lay flat. You will have to check this dry and figure how you want to do yours. 2nd pic, here it's glued and stapled down (1/8" staples). 3rd pic, the entire strip is glued down and only a couple staples to hold in place.
03-11-2015, 11:41 PM | #60 |
Sorry I didn't take a pic of me placing the strip on the main panel. But it is the same as the large piece. Anyhow apply glue to the back side of strip, apply glue to the strip opening on the main panel. Apply pressure and hold in place till it's dry. Now flip the panel over.
First pic, while appling pressure where the strip is, staple along the line for the strip. Make sure to switch back to 1/4" staples. second pic, with the enod of the material on the strip, if we just fold it over it would be bulky. third pic, here I've cut down the material, now take a small blunt end and force the material into the little slot that were cut yesterday. forth pic. here it is glued and stapled in place, and no big bulk.
03-12-2015, 12:01 AM | #61 |
First pic, this is a side shot of the panel showing the two strips and how flat the panel is on the back side.
second pic, another shot, and here you can see how the design panels are raised just a little over the main panel. third pic again showing the difference in panels.
03-12-2015, 12:11 AM | #62 |
I'm showing the panel all by itself here. I still need to build the armrest, but I wanted to address a few items:
1. If a person wanted to do a two tone, or two different materials, you can see how easy it would be to have the design panels whatever you wanted. 2. If you wanted a more traditional look you could see pleats in you center design. 3. You could also add carpet to the bottom if you wanted. Well, that's is for Tuesday. Wednesday (today) I worked on my pickup, hopefully tomorrow I can do some more panel work...Jim
03-12-2015, 08:47 AM | #63 |
Jim, that looks really good! Again, thank you for sharing your knowledge in a simple to follow step by step process.
Doug |
03-12-2015, 09:43 AM | #64 |
Thank you Doug, appreciate you checking in out...Jim
03-12-2015, 02:06 PM | #65 |
Jim. Thanks for the lessons on here. I think most of us here can stretch and staple material on the door panels but its the little tips and tricks that turn that door panel into a professional looking piece. Very nice. I know I have learned a few things that I will use on another project. Thanks again for taking the time to show us.
Earl
You have to have patiences or you'll be one. |
03-12-2015, 02:15 PM | #66 |
It's coming together Nice
03-12-2015, 04:00 PM | #67 | |
03-12-2015, 04:02 PM | #68 |
03-13-2015, 10:49 AM | #69 |
looks really nice OldMan... I think I will tackle something like this in black and gray. Ill pic some pick when I get to that point. Thanks for showing just how easy it can be.
"Hey... its only time and money right? Just do it." 67 Short Bed under major construction http://67-72chevytrucks.com/vboard/s...=651356&page=8 |
03-13-2015, 07:12 PM | #70 |
Thank you, glad to see someone wanted to try this...Jim
03-13-2015, 07:27 PM | #71 |
I think I'll use some of the lessons and modify to change for my style. Like anything else I've learned on this site I can use bits and pieces of different projects to suit my needs. The nice thing about your lessons you tell us why you do things to make it turn out the way you want. I had a auto shop teacher in High School that taught the same way. I learned more from him than he thought he taught me.
03-13-2015, 07:47 PM | #72 | |
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> Last edited by oldman3; 03-13-2015 at 08:09 PM. |
03-13-2015, 08:08 PM | #73 |
Here are the pics.
first pic. here i"ve outlined the material I want to remove. second pic. material removed and ruler in place to hold material down. third pic. material pulled half way down, glue has been sprayed and setting up. forth pic. here I'm about half way going back up with the material. fifth pic, top half done, now the bottom half, sprayed with glue and ready to start attaching.
03-13-2015, 08:12 PM | #74 | |
03-13-2015, 08:33 PM | #75 |
Ok, my last update was Wednesday, worked on my pickup Thursday installing my seat. Finally got back to the shop today, work about 45 minutes to make the above pics. Have friends stop by, so nothing done till around 3:00pm, so heres what I have to show today.
First pic, glued and stapled the material to back of the panel. Second pic, Glued material to design panel, and here is the back side, all glued and stapled. Third pic, Front of design panel, ready to go on the drivers panel. So not much done today, will see how things go tomorrow...Jim
