02-03-2004, 03:32 PM | #1 |
wanted..gen 1 bat tray help
I am reassembling my '72 and having trouble w/ the battery tray. Where exactly does it go? The PO rigged a tray by welding it @ 3 points on the psgr side inner fender.
My assembly manual shows it backing up to the radiator support, but I can't see exactly where. Does anyone have pix that would help me out? I will also be going w/2 bats. Has anyone squeezed them both on one side, or have you put one @ each side? Thanks |
02-03-2004, 08:51 PM | #2 |
tray
This help any?
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
02-03-2004, 08:54 PM | #3 |
orginal tray bolts in here--nuts are welded on-2 in rad.support and one on inder fender.
02-04-2004, 11:45 AM | #4 |
batteries
I used 2 18-wheeler batteries. They won't fit stock trays, so this may not help. I made my own trays and welded them in where the stock trays originally bolted in: the uprights on either side of the radiator. I also turned them 90 degrees.
02-04-2004, 04:03 PM | #5 |
mister.freeze,
Wow!!! Is that to run winches or what? You need a fourcylinder generator to charge all that. I'm just joking around. I like the looks of your clean engine compartment. Dan
Marysville, WA (Dan72cst@hotmail.com) 72 4wd Blazer CST 350/350 72 4wd Chevy LWB 350/350 68 2wd Chevy LWB 327/400 |
02-04-2004, 04:15 PM | #6 |
Batts
Thanks! I've put a lot of hours under the hood. The batteries are charged by a 110 Amp alternator converted to a 1-wire setup so that I always have 110 amps on tap. I do have a 10 winch, so it helps. The extra power really is for those times I run the radio for a weekend or all my lights all night. Not too many folks can give me a jump in some of the places I can go.
'72 K5, known as 'the Fox.' |
02-09-2004, 04:01 PM | #7 |
Thanks for the info.
