Old 03-11-2015, 09:38 PM   #1
class01
class01's Avatar
rotors rubbing on lower control arms
Im have a problem, Ive dropped my truck 4\6. im running 20's all around and i just installed a wilwood big brake kit in the front. I pulled it out the garage and I could hear grinding. the lower control arms are grinding against the rotors. I havent got it aligned yet. Could that be the problem? Please help
class01 is offline   Reply With Quote
Old 03-11-2015, 11:17 PM   #2
Sean1985
Sean1985's Avatar
Re: rotors rubbing on lower control arms
Same issue. 5/8 drop with 14" wilwoods. I just ground down the lca. It didn't take much. Just turn your wheel and make sure you you get it all in one shot
Sean1985 is offline   Reply With Quote
Old 03-12-2015, 09:44 AM   #3
class01
class01's Avatar
i ground down the passenger side, everything was clear when I had it jacked up. I put everything back together put it on the ground and now it seems like it still rubbing
Old 03-12-2015, 11:04 AM   #4
Sean1985
Sean1985's Avatar
I had to ground down the tip of the lca and then also just a little on the front and back around the outside. When I turned the wheel it would still bind. I guess it could change based on your alignment due to home much shim you have on the top lca. Is the rotor kicked in to the lca?
Old 03-12-2015, 01:10 PM   #5
class01
class01's Avatar
thanks for the help Sean. Ill have to check it out when I get off of work.
Old 03-13-2015, 01:04 PM   #6
class01
class01's Avatar
It worked! thanks sean, I got the fronts on drove around a bit everything was good.
Old 03-13-2015, 03:52 PM   #7
Sean1985
Sean1985's Avatar
Cool. Good to hear.
