Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 03-12-2015, 12:51 PM   #1
Longhorn 70
Longhorn 70's Avatar
Has anyone tried one of these boxes under the seat?
Found this on eBay. It looks like it may be a good solution. Just curious if anyone has tried one.
Length: 26-3/4" End to end.
Depth: 12-1/2" Front to back.
Height: 4.5-6.125"
At one time I had 2 8" boxes under my seat that fit well but they were stolen while it was at the paint shop. They worked well but the bass was a bit muffled.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11.
1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar
And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9
Longhorn 70 is offline   Reply With Quote
Old 03-14-2015, 04:41 AM   #2
king-918
king-918's Avatar
Re: Has anyone tried one of these boxes under the seat?
Will work well with a DD sl7
<----Christopher
Oh yeah I'm really a Toyota guy, but had some stuff sitting around.
Oklahoma
king-918 is offline   Reply With Quote
Old 03-16-2015, 10:50 AM   #3
Longhorn 70
OK I'll bite, what is a DD sl7 please? Is that the old Technics turntable?
Old 04-06-2015, 05:13 PM   #4
Longhorn 70
I'm hearing no one has tried one of these....
Are there better underseat boxes??
Old 04-06-2015, 05:49 PM   #5
crossfire84
crossfire84's Avatar
LIL ERV the 50-3600
396 BBC stroked to 415 cid
Richmond 6spd over drive
C4 rear
Porter built a arms
Never give the Devil a ride,because he'll want to Drive!
crossfire84 is offline   Reply With Quote
Old 04-08-2015, 12:40 PM   #6
Longhorn 70
AHA it took me a while to find what a DD SL7 was.....
DD Audio SL7(10 or 12)Google search plus searching on DD's site. That does look like a great driver.
I was thinking more of Pyle Audio or Fosgate.... I don't have the budget for a $400 sub plus box plus ..........
Maybe I should have structured my question better.
Will these boxes fit under our stock seats?
Do they perform well with moderate drivers?
Old 04-21-2015, 09:35 PM   #7
zach_carver
zach_carver's Avatar
Also wondered what could be used under the seat. I like this idea and put amp under other side.
1965 C10 LS2/4l70, WHITE, 5/7 DROP
LINK TO SUPER SNOOPY C10 BUILD---> http://67-72chevytrucks.com/vboard/s...d.php?t=689283
1977 C10 SILVERADO HAWAIIAN BLUE, 5/5" DROP, LS6/4L80E
1976 CHEVY K5, 350/350, YUBA GOLD/SADDLE
zach_carver is offline   Reply With Quote
Old 04-21-2015, 09:46 PM   #8
king-918
king-918's Avatar
I'm sorry I had just seen your reply.......
<----Christopher
Oklahoma
Old 04-21-2015, 09:54 PM   #9
king-918
king-918's Avatar
May seem kind of pricey but with normal shallow mount subs you will get a kick but the range will suffer because of the lack of suspension travel, also ferrite magnets tend to be huge in order to make the motor force needed where is neodynium can be just a fraction of the size and produced the same amount of power.
the sl is inverted but has full travel for sound while using neo for power
<----Christopher
Oklahoma
Old 04-21-2015, 09:56 PM   #10
king-918
king-918's Avatar
By the way Pyle is junk
<----Christopher
Oklahoma
Old 04-24-2015, 12:36 PM   #11
Longhorn 70
is the Fosgate OK?
Old 05-04-2015, 02:05 PM   #12
gramps77
Sundown Audio has some great small enclosure subs as well. For half the price of the DD Audio.
http://www.sundownaudio.com/index.ph...-3-series.html
Im running an Sd-2 10" in my 65 Nova and people don't believe its a single 10 til they see it.
Fosgate is starting to fall behind unless youre paying for their high end. As mentioned Pyle is just that.....
gramps77 is offline   Reply With Quote
Old 05-08-2015, 11:39 PM   #13
use2bnlp
use2bnlp's Avatar
Kenwood Excelon kfcxw1000f or the kfcxw1200f depending on doing 10 or 12 inch woofer best bang for the buck I sell hundreds every year
use2bnlp is offline   Reply With Quote
Old 05-18-2015, 07:31 PM   #14
jeffahart
jeffahart's Avatar
Historically I use small rectangle box type outdoor speakers under the bench seats of my old trucks. You can screw the brackets to the floor and point the front of them toward your feet. A couple of these with an amp and your ears will be ringing worse than they already are... if your old like me. Plus I like to keep the old radio in dash and mount the new fangled one as an auxiliary under the dash... you know like you used to do with the old CB radio. Because I now view all new electronics as a disposable flavor of the day. I like radios because I like to listen to the news.... keeps my dander up!
White K20
jeffahart is offline   Reply With Quote
Old 05-19-2015, 07:35 PM   #15
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I'm sure you guys considered this, but the reason that under seat boxes sound muffled...is usually the seat It sounds dumb, but not only does it directly block the path of the outgoing pressure waves, but it can block full excursion of the woofer if the sub is too close to the droop of the seat bottom. Its like listening to headphones through a hat/hoodie.
I've always tried to opt for a behind seat or console box. They both can suffer from muffling too, but usually you can aim them in a way so they have at least a somewhat clear path. A ported box and subs that like porting will give you more sound with less physical volume if calc'd correct.
I've seen some guys space their seat up slightly, then build a larger enclosure for sealed or in-firing subs.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 05-26-2015, 10:34 PM   #16
king-918
king-918's Avatar
one of the reasons i like the DD SL7 10 or 12 is you get full excursion like a normal sub and the magnet provides space for the to happen. me personly, il be doing a t-line blowthru to avoid all those issuses but most are not willing to go that far
<----Christopher
Oklahoma
Old 02-16-2016, 09:48 PM   #17
68 shotgun
I would love to see that speaker box King-918,
Because that would mean all the air would come out the middle which means big boom. Lol
68 shotgun is offline   Reply With Quote
