Old 03-14-2015, 07:54 PM   #1
71K20chevy
71K20chevy's Avatar
14BFF Brakes Locking Up
Recently we swapped a 14 bolt out of a 79 K20 into my 71 K20, replacing the original Eaton HO52 that blew up. The HO52 had 1/4" brake line while this one has 3/16". The proportioning valve and everything is unchanged. The wheel cylinders were also leaking pretty badly, we replaced those, the shoes, and the hardware. But they still lock up if you brake hard! Do the shoes need time to break in? I was wondering if the smaller 3/16" line is causing too much pressure to be sent to the rear, since the proportioning valve is set for all 1/4" line. Also, the brake light is not on. I get my license in a couple days and definitely want everything working correctly so I don't wreck it. Thanks!
71 K20
64 GMC mud truck
71K20chevy is offline   Reply With Quote
Old 03-20-2015, 01:24 PM   #2
71K20chevy
71K20chevy's Avatar
Re: 14BFF Brakes Locking Up
Ttt
71 K20
64 GMC mud truck
Old 03-20-2015, 08:09 PM   #3
k_n_browning
Ok you need to measure the brakes on the 14 bolt then the ho52.also do the wheel cylinders.If the ho52 is larger then this will be the problem.The brake line needs to be the same size.Bottom line it has to be all the same size.If not you will need a porp valve if its close.
k_n_browning is offline   Reply With Quote
