Old 03-15-2015, 04:21 PM   #1
rossboss
rossboss's Avatar
blazer top rail holes?
Bought a 72 blazer without a top. The top bed rails appear to have way too many holes for whats necessary to mount the top. I need to know what ones I need to fill to make it correct. The ones with the captured nut are a no brainer but how many others are there. A picture would be nice.
rossboss is offline   Reply With Quote
Old 03-15-2015, 04:24 PM   #2
jjzepplin
jjzepplin's Avatar
Re: blazer top rail holes?
One set is for a single wall and the other set is for a double wall.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 03-15-2015, 05:35 PM   #3
1rippen6
Most 72's have a single wall top that bolt from the top down so you need the ones with the caged nut. Double (had single here) wall top bolts from the bottom up and would need the thru holes so it will depend on which top you have.
1rippen6 is offline   Reply With Quote
Old 03-15-2015, 05:40 PM   #4
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
If you are going to use a soft top, you may need more of the holes. You should make sure you know what top(s) you are going to use before filling the holes.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 03-15-2015, 09:24 PM   #5
Dale99
My 72 has a double wall.
But agree, it could be multiple things. Single, double, or was drilled for a soft top.
2008 Sierra k3500 LMM
1994 s10 blazer 4x4
1991 Camaro Vert Rusted in Half RIP
1972 Jimmy 4x4 L05,4L60E,np205http://67-72chevytrucks.com/vboard/s...d.php?t=546364
1967 C10 L6/3tree(dads truck)
Dale99 is offline   Reply With Quote
Old 03-15-2015, 09:30 PM   #6
71swb4x4
71swb4x4's Avatar
I agree with the others. 1972's are unique, they have hole for both double and single wall tops.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 03-16-2015, 09:31 AM   #7
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
This ^^^^^
Tom Vogel is offline   Reply With Quote
Old 03-16-2015, 01:32 PM   #8
RED72blazer
urban fourwheelin
RED72blazer's Avatar
Not all 72's have this feature.
1972 K5 Blazer with Cummins 4BT, NV4500 swap in the parts gathering stage.
RED72blazer is offline   Reply With Quote
Old 03-16-2015, 07:20 PM   #9
rossboss
rossboss's Avatar
Are there pins in the top to help line it up with the bed rails and how many total holes are there for both type tops.
Old 03-16-2015, 09:51 PM   #10
Blazerowner
Blazerowner's Avatar
My 72 only has holes for a single wall. I've never see them with both unless someone modified the holes. More than likely it was done because they couldn't find a single wall so they stuck on a double wall which are easier to find and as simple as drilling some holes. The original holes are also oval shaped for adjustment.
Kirk
72 Blazer CST 4wd highlander
Blazerowner is offline   Reply With Quote
Old 03-17-2015, 09:28 AM   #11
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
My 72 has both from the factory. Owned it since 1990.
Old 03-17-2015, 09:51 AM   #12
briank
My 72 has both sets of factory holes as well.
briank is offline   Reply With Quote
Old 03-17-2015, 06:42 PM   #13
rossboss
rossboss's Avatar
How many factory holes are there so I can eliminate the ones that aren't needed.
Old 03-17-2015, 08:33 PM   #14
amashal
amashal's Avatar
My 71 with a double wall top has 6 holes on each bedside. Each 13" apart.
amashal is offline   Reply With Quote
