Old 03-15-2015, 06:25 PM   #1
sabbey10
203/205 with long input?
I have a 91 v3500 with 4l80e/205 and have acquired a np203 off a th400.
I know if I swap the 205 input to the short style there is numerous adapters available, but is there a adapter which lets me keep the long input in the 205? I have tons of wheelbase to accommodate the extra few inches and with 8" lift the longer front driveshaft would be great.
1991 V3500, 350/4l80e, 8", 38.5 boggers
1969 RS Camaro, under construction, 12 bolt, M20 muncie, BBC TBD
1969 Camaro Convertibe, 350/th350, all original and numbers matching
sabbey10 is offline   Reply With Quote
Old 03-15-2015, 08:10 PM   #2
doubleclucker
doubleclucker's Avatar
Re: 203/205 with long input?
Try JEDS Machining he can make just about any configuration and it is made of steel so you have no worries of strength .I think it is 3" longer with that input .
I would also recommend a new output shaft as opposed to a cut and respline.
http://jedsmachining.com/index.html
100:1 low gear!
doubleclucker is offline   Reply With Quote
Old 03-15-2015, 09:28 PM   #3
franken
Is the output of the 203 range box 32 spline?
How far does it stick out?
Old 03-16-2015, 12:08 AM   #4
$20071k10
$20071k10's Avatar
Why would you want to change the 205 for the 203 any way
Brian
$20071k10 is offline   Reply With Quote
Old 03-16-2015, 11:51 AM   #5
snj8198
snj8198's Avatar
I bet he's using just the range box of the 203 in front of the 205 for a doubler combo. It's going in the OP's '91 with 38's so he's offroading this rig.
Steve
1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's
snj8198 is offline   Reply With Quote
Old 03-16-2015, 02:29 PM   #6
obijuan
thats alot of stress on the six bolts on the front of the 205 let alone adding 2" spacer to those bolts. just swap the input gear. it is a breeze of a job.
obijuan is offline   Reply With Quote
Old 03-16-2015, 11:31 PM   #7
sabbey10
Thanks for the input guys, It is a wheeling rig but I live close enough to work (5km) that I daily drive it in the winter and rainy days in the summer.
the 203 would only be a range box in front of the 205 , a few advantages being a extra low range and a bit of extra length in the front driveshaft
Old 03-17-2015, 05:38 AM   #8
andrewmp6
Talk to http://offroaddesign.com/ or http://www.northwestfab.com/
Old 03-17-2015, 09:16 AM   #9
doubleclucker
Here is a pic of a jeds adapter you are looking for -GM NP203 to a long input NP205 .
A short input NP205 adapter is only 3" case to case and will give you about 9" longer front driveshaft.
100:1 low gear!
Old 03-17-2015, 10:33 AM   #10
sabbey10
thanks doublerclucker, that is exactly what I am looking for. I sent a email to Jed's but will follow up with a call..
I have crossover steering from NWF and they have great products, I just would like the longer adapter and theres only works with the short input
Old 03-29-2015, 01:40 AM   #11
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Does anyone know what Jeds 203-205 adapter runs? Short and long versions for a figure 8 pattern 205.
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
